Question about Yamaha Audio Players & Recorders
My RX-V995 receiver has no output to the sub-woofer. Is it worth fixing? The subwoofer has been checked and is OK.
  • Yamaha Master
  • 6,771 Answers
This is a tough question, if you paid a fair price for the unit then I would opt for an estimate. But! if the item was low priced then I think it is clear that a replacement would be a better way to go.
Posted on Dec 30, 2010
Have jvc rx-2020v receiver with mono rca out for sub and trying to hook it up with polk audio rm 1000 w sub woofer with +/- terminals for both left ane right channels plus blue terminal(?). How to?
Your Polk Audio subwoofer is a passive sub and your JVC mono output is for connection to a powered sub. If the JVC does not have an amplified output for a passive sub, you'll either need to get an amplified sub, a different receiver, or buy a dedicated mono subwoofer amplifier.
Oct 14, 2016 | JVC Audio Players & Recorders
When i hook up my subwoofer it won't sound
Make sure that the Sub woofer power is on ,if so check the woofer after removing if the windings are intact.
If so the power amplifier is faulty as the power output is not working.It can be the output , possible that a fuse has blown or the driver but a voltage and continuity test is important to determine.
Sep 26, 2010 | Yamaha RX-V740 Receiver
Yamaha RX-V861 no sub woofer output
It sounds like you have switched off the sub channel.
Keeping pressing C Level on the remote till you see SWFR.
Press D l / h to adjust the speaker output
level.
Jun 25, 2017 | Yamaha RX-V861 Receiver
How to install klipsch sub woofer to yamaha reciever rx-v559. everything working properly but sub wont be adjusted with volume. i got my stuff moved out here but had a mate help me set up. didnt pull it...
Does the sub work at all? How is it hooked up? The sub needs to be fed by an RCA cable from the Subwoofer Output jack for the receiver to control its output.
Mar 01, 2010 | Yamaha RX-V559 Receiver
AV receiver single line output to two line input on sub woofer
You are trying to connect the powered sub output of the receiver to a standard (unpowered) subwoofer. Can't be done.
May 05, 2017 | JVC Audio Players & Recorders
RX-V995 Earthing issue
your main lead wire contains only two core, could be brown, black, anyway..open the cover of the unit, and change the cord, get three core main wire, and take the old one off, replace the other one, which should have earth, you can screw it to the transfomer base, try this
Nov 09, 2009 | Yamaha RX-V995 Receiver
HUM noise at PSW3000 if i connect the Yamaha RX-V995
the conections some where are dirty you need to unplug everything clean all connections and the hum will go away
Nov 06, 2009 | KEF Audio PSW 3000 Subwoofer
I am trying to hook up a powered sub woofer to a yamaha rx-v461 and i dont know what cables go where on the back of the sub there are two speaker ports and there are two plug ins but each speaker port has...
Your subwoofer probably has both high-power inputs and "normal"low inputs. The first are for receivers, which don't have link-level output for sub, so they are able to take already amplified signal as input.
You need to use link-level input of your sub and connect it to subwoofer-output of your receiver. The output is marked as OUTPUT - Subwoofer and is black-color RCA plug (don't confuse with subwoofer INPUT under MULTI CH INPUT).
Receiver has only mono output for subwoofer. If your sub has stereo input (white/red RCA plugs), connect just the left channel to the receiver, it will still work.
Don't connect anything to the speaker output on the sub, you don't need that.
Sep 28, 2009 | Yamaha RX-V461 AV Receiver
Yamaha RX-V995 receiver turns on & then powers off 2 seconds late
I suggest you run self diag.  press [FM/AM] key + [Input mode] key and press the [power/standby] switch.
ps prt = power supply problem
dc prt = shorted output or leakly cap in channel
tmp prt means to hot on heatsink
you'll likely have to measure the resistances of the output FETs to find a short,
Jan 02, 2009 | Yamaha RX-V995 Receiver
No subwofer operation 2year old system
Some systems don't send signal to subwoofer if speakers in SPEAKERS SETUP are set to LARGE, they redirect signal to center and front speakers. Maybe that's problem.
Oct 07, 2007 | Yamaha RX-V1500 Receiver
102 people viewed this question
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
