Question about Spar SP-22HI Commercial Planetary Stand Mixer
Whow u start thismixer sp22hi - Spar SP-22HI Commercial Planetary Stand Mixer
My mixer wouldn't start right away it start at the 3rd speed I'm afraid some day it would start at please help!
How old is your mixer? What type of mixer portable or does it stand by itself?
Jun 07, 2017 | Food Mixers
My Mixer won't start. Please help
if i t whont start brig it to a repare shop or try to spin the shap thing then start it
Mar 03, 2015 | Butterfly Desire Mixer
It wont start
Check the carbon brushes under those black screw caps on the side. If not that then look for broken wire under back cover.
Dec 14, 2013 | KitchenAid KSM150PSOB Mixer
I have a hobart mixer 80 quart .The motor makes a noise and would not start. It only starts if I turn the shaft and turn the on switch at the same time
Most motors of that type have a capacitor that puts the stator out of phase with the rotor. They are capacitor start induction run motors. These also have a centrifugal switch inside near the end ot the shaft to put power to the start winding for a split second to determine the direction of turn and to increase horsepower until it is up to speed. So if it fails to start either the centrifugal switch needs cleaning (or replacement if damaged) or the capacitor needs replacing to give it its original power, or the start winding has failed from overheating. There may be a thermal cutout on the start winding that may need to be replaced if it did overheat. If the start winding burned then the motor would require rewinding or replacement.
Oct 10, 2013 | Hobart M-802 80qt Dough Bread Bakery Mixer...
Hi, my Hobart D300T is making a really loud buzzing sound on start up, pls help
Could be a problem with the start windings.or start switch.maybe a capacitor .on the older models the start switch sticks just needs freed up and contacts on start switch cleaned.
Apr 15, 2011 | Hobart D300 Stand Mixer
Our Hobart D-300 was overloaded with bread dough and now it will not start even without any load whatsoever. Is there a reset button? PS The Gears are not jammed...you can move the mechanism by hand....
Is it a problem of the motor not starting, or does the motor start but does not mix?
If the motor starts, then you've either broken a gear or a key inside the transmission from overloading it, or stripped the brass worm gear (also in the transmission).
If the motor doesn't start, I'd say you probably burned out part of the motor starting circuit if the motor was overloaded severely enough to re-engage starting components.
Dec 19, 2010 | Hobart D300 Stand Mixer
Hobart A 200 Mixer
There are four possibilities to look at here. Assuming your mixer has a normal capacitor start motor (older a200's used a different style motor), possibilities are, in order of likelihood:
Motor start capacitor
Start switch (electronic or mechanical)
Burned wiring
Motor start winding
The start capacitor is located at the rear of the mixer. Remove the rear cover (4 screws) and pull the cover towards you. Disconnect one wire from the capacitor and test with any multimeter.
The start switch, if electronic, is able to be tested, but not very easily. Once you've eliminated the other possibilities, it's time to replace the (electronic) start switch. If the motor has a mechanical start switch, it's easy to test: Remove the two wires at the rear of the motor and test for continuity with the motor stationary. A multimeter should show near zero ohms for a good mechanical start switch.
Burned wiring should be easy to spot with some careful inspection around the motor, capacitor, and start switch.
Start winding: Look closely at the stator (stationary part of the motor). If some of the copper windings look significantly darker in color than the others, it's likely the start windings were overheated (the start windings are the thinner copper wires - if you look closely, approximately half of the wires are thinner than the other half). Look for a wiring diagram behind the power switch and determine which wires leading to the start switch and/or capacitor are for the start windings and test for continuity across the start winding. You should read a fairly small value such as 5 - 15 ohms. Values significantly outside this range could indicate a partially open or partially shorted start winding.
Jun 09, 2010 | Hobart A200 Stand Mixer
Have a A200 Mixer, when turned on, you have to spin it by hand then it runs fine. Whats wrong
The answer is clearly in the starting circuit which doesn't have too many parts, but depends on the type of starting circuit your mixer uses (electronic or mechanical start switch). I'm assuming your mixer isn't very old, as the old units used brushed motors which did not have starting circuits.
The parts of the starting circuit are the motor start winding, the start capacitor and the start switch (probably electronic in your case which is a small silver box with four wire terminals on it). The capacitor should be tested with a multimeter after verifying it's not holding a charge (check with multimeter set to DC Volts, mixer unplugged, should read zero volts).
Start winding should be tested with the meter to measure ohms. Locate the wires leading to the motor (hopefully only three wires) and you should get a reading for all three combinations of measurements (wire 1-to-wire 2, 2-to-3, 1-to-3) if meter indicates open on any of these, motor stator is bad(this is pretty rare and quite expensive).
Electronic start switches are not very simple to test, but if the capacitor and motor test out OK with the meter, and all the wiring is intact (look closely for loose wires, burned wires, poorly crimped terminals, etc.) then it must be the start switch.
May 19, 2010 | Hobart A200 Stand Mixer
My Hobart mixer is hard to start. I have to keep
take off the side cover where gear shifter is, you probably have the original arrow hart contactor in there ,that part is obsolete but you can get a kit from hobart to upgrade the control circuit
Nov 29, 2009 | Hobart H600 Stand Mixer
Spar SP-22HI Commercial Planetary Stand Mixer Logo
67 people viewed this question
Top Spar Food Mixers Experts
eyecam
Are you a Spar Food Mixer Expert? Answer questions, earn points and help others
