Question about Senco SN60MC Full Head Framing Metal Connector Nailer
Sn60 rebuilt still leaking and not firing. I plug the air in and sometimes get 1 low powered shot, sometimes the driver just pops forward as soon as i give it air. all new orings, trigger assy and driver, looks good inside no scoring. any help would be nice.
  • jeepster67 Jan 21, 2015
    The two large o-rings are interchanged.
4 Suggested Answers
  • 1388 Answers
SOURCE: framing nailer, dewalt d51823 doesn't fire.
Generally, when you attempt to fire and only get an air sound at the trigger, the problem is air leaking past the orings in the head valve. Here are a few things to check and a simple test.
Remove the trigger from the gun so that you can have access to the trigger pin. Remove the nails from the gun. After removing the trigger and the nails, reconnect the air supply (check for 100psi) Place the nose of the gun against wood and with a very quick ****, depress the trigger pin all the way in. If the gun fires then the safety foot is not allowing the trigger to depress the pin all the way in. Make adjustments to safety and check for worn trigger and trigger retainer pin. If the gun does not fire, remove the head. Place the head on table and depress the headvalve all the way in with your thumbs then place a finger over the small vent-hole on the gasket surface and release thumb pressure. The headvalve should remain depressed due to vacuum in the valve and will pop up when you remove your finger on vent hole. If the headvalve does not stay in, air is leaking past the orings. Remove headvalve parts and use magnify lens to find small scratches on the surface where orings contact. Remove scratches with very fine sandpaper (300 - 400 grit) Make sure all the orings are not cut (use magnify lens) and fit snuggly. Lube with "Danco silicone grease" available at lowes in the plumbing department. It is used to lubricate orings in faucets. After re-assembly, do vacuum test as described above. If you have vacuum, head is ok. Make sure that the gasket seals around the vent hole where the head mates against the body. You should be good to go. Good Luck and email if you have other questions.
Posted on Mar 05, 2009
  • 131 Answers
SOURCE: bostitch s32 stapler. slight air bypass on trigger, will not fire
You need a new trigger valve TVA6.
Posted on Sep 04, 2009
jrox55
  • 66 Answers
SOURCE: i have a framepro601. at present it will sometimes
it is def a seal issue.
Posted on Feb 25, 2010
Nail gun leaking air at trigger
Worn orings always results in leaks/low power. On some nailers, better to replace whole trigger valve as seperate orings (very small) are hard to find and usually not in repair kit. Low power is usually worn driver oring. Easy test, remove nails and point nailer up then down again. If the driver seems to move up and down within the cylinder, time to replace oring/s. Look for repair/tune up kit that contains all the orings in the gun.
Jun 10, 2012 | Tools & Hardware - Others
Stalls when giving gas
Hi Boscha4, and the usual suspects are:
1. Idle speed improperly adjusted.
2. Inlet system air leak.
3. Leaking accelerator pump.
4. Loose low-speed jet.
5. Plugged low-speed jet.
6. Contaminated or plugged low-speed circuit.
7. Enrichner valve not seated or leaking.
For more information about your issue please visit the websites below. Good luck and have nice a day.
2004 Yamaha Motorcycle Service Repair Manuals
May 20, 2012 | 2004 Yamaha V Star Classic
Model sn60 wont nail
What is it doing when you try and shoot a nail? Is it leaking air? Is it jammed? Too many possible problems to address without more in depth information.
Mar 07, 2012 | Air Tools & Compressors
1985 maxim x 700 has trouble starting sometimes and wants to idle at 4000 rpm or stalls when adjusted, just rebuilt the carburetor still won't idle correctly
Hi, Dlmninja and the usual suspects are:
2. Air fuel mixture screws not properly adjusted.
3. Inlet system air leak.
4. Leaking accelerator pump.
5. Loose low-speed jet.
6. Plugged low-speed jet.
7. Contaminated or plugged low-speed circuit.
8. Enrichner valve/choke not seated or leaking.
For more information about your issue and valuable "FREE" downloads that you will need please click on the links below. Good luck and have a nice day.
bike idling high
82 1100i surging bit 4000 rpm
Yamaha XJ700N Service Manual
OEM parts for Yamaha
http://mybikemanuals.com/yamaha/yamaha-xj-owners-manuals
Jul 21, 2011 | 1985 Yamaha XJ 700 X Maxim
What causes it to shoot a double, or triple nail sometimes?
Make sure that orings are in good shape, lower bumper not cracked, (no leaks and the driver/piston stays at the top position, if piston drops a little or all the way down with no nails in gun, replace piston oring). Also check spring tension for feeder and two check paws in the door (feeder tension should be firm ). Adjust the timing screw up or down one or two turns and test (timing screw at the top of safety foot, head of screw pushes on the firing valve ). Test for lower bumper cracked. Remove nails and leave side door open. Hold the nose of the gun against coiled air hose or thick rubber and press and hold the trigger. The piston will stay down against the bumper until you release the trigger. No air should leak out the driver path. If air leaks past driver suspect bad bumper. Test action of feeder piston. Remove side cover to feed piston and clean debris. With air disconnected, move the feed piston back and forward. There should be a little resistance, if it moves very easy, suspect orings worn. As soon as you connect the air line. the feed piston should move forward with force, note the position of the feeder. Now with air disconnected, place nails on the feeder. The first nail should be well within the path of the driver. If not fully under driver path suspect worn feeder / feeder retainer pin, or debris inside feed piston chamber preventing piston from full forward travel (debris from inside of the gun will enter the feed piston chamber usually broken bits of lower bumper). Replace parts as needed. Good luck with your repair.
May 17, 2011 | Hitachi NV45AB2 Roofing Coil Nailer
I have the 2 1/2 Hitachi for nailing siding. The nail gun had not been used for a couple of years, but now will only drive the nail half way in. Sounds like an air leak when driving the nail. I have...
Remove the nails and air supply. With side door open notice position of driver. Driver should be at top position with tip not visible. If driver is down and it moves within cylinder when you tilt nose up then down again, time to replace orings. If driver is down, it should extend past the nose about 1/4 inch (if driver is broken at the tip the end will look rough and nail will not drive in all the way). If driver extends past the nose more than 1/4 inch then lower bumper may be breaking up /cracked. Easy test for proper function. With nails removed and side door open, connect air to gun and dry fire gun against hard rubber or old coiled air-hose (with air connected and trigger depressed, no air should leak from trigger area, if air leaks when trigger is depressed, look for fault at trigger pin). Feeder should move back then forward in quick motion almost matching speed of driver and driver should not creep down between shots. No air should leak from nose of the gun (push nose against hard rubber and depress trigger and hold in this position, driver should stay down with very little or no air leaking out of nose, when you release trigger, driver will return). If air leaks out of nose while holding in this position, replace lower bumper. If a quantity of air leaks from valve in front of trigger, cylinder orings may need replacing or outer part of cylinder has fine scratches (remove scratches with 400 grit paper). Parts are available at www.toolpartsdirect.com. Good lucki
Apr 16, 2011 | Nailers Hitachi Nv83a2 3 14" Coil Framing...
Two cylinders was not getting fire so i had head rebuilt. MY question to you is from driver side to passenger side which cylinder is considered to be the number one cylinder?
number one is next to the crank pulley, you can look at the #1 spark plug on the cap and follow the wire to it. Regardless if the head was pulled they would have rebuilt all valves and shaved the head or it would leak.
Nov 24, 2009 | 1992 Honda Accord
I have a 2000 alero that idles rough and smells like old gas
.A}.could be the fuel filter ..B}.converter is plugging up .C} a vacuum line has come dry-rotted and or is come unattached and is sucking air .D} .idle speed is too low ..E}.The firing order is incorrect ! ....F}.clogged air cleaner ? ...G} check all fluid levels for proper fill levels . or it could be the choke sensor ids sticking or faulty ....have you tried running any fuel injection cleaner and a good grade gas this is just a minor list of points to start with after all we all get bad gas sometimes .
Oct 15, 2009 | 2003 Oldsmobile Alero
Craftsman 1/2 inch impact air driver leaks air
put a bunch of hydraulic oil in it and this will lubricate the seals inside to form a more uniformed seal it will stop leaking air.
Sep 03, 2009 | Air Tools & Compressors
Senco SN60MC Full Head Framing Metal Connector Nailer Logo
233 people viewed this question
Top Senco Air Tools & Compressors Experts
John Trevino
yoopertech
Mike
Are you a Senco Air Tool and Compressor Expert? Answer questions, earn points and help others
