Question about Sony KLV-40ZX1M 40 in. LCD TV
Sony LLV-40ZX1M dark area right centr of monitor. Just started happening out of now ware
Acer AL 1912 (black) resolution issue
[u][b]LCD Monitor Shadow Effect[/b][/u]
This problem is best described as the LCD monitor "Shadow Effect".
The solution to this very simple. No software or hard ware changes required.
The cables that are connected to the LCD monitors are causing the problem. Its also called as electromagnetic noise or electrical noise.
[u][b]Solution: [/b][/u]Keep the two cables - (power cable and moitor display cable), that are connected to the LCD monitor as far away as possible with each other and also away from other electrical cables.
Thats it. Your shadow effect is fixed.
Thank you.
May 27, 2009 | Acer AL1912 19" LCD Monitor
The LCD does goes dark after power on
you mean few second the monitor goes in black. then its come. if it happen, it is ok
Jan 21, 2009 | Sony VAIO® VGC-LS37E PC Desktop
Monitor black screen
Try asking from your nearest service centre .
Mar 27, 2008 | Sony SDM-HS73P 17" LCD Monitor
Lg 1919s flatron monitor slowly gets dark
This problem is showing when the main PCB of the monitor failed. Contact the LG service provider in your area. They will change the full package assembly or PCB. check this link to get the service center info
http://www.lgservice.com/
Dec 13, 2007 | LG L1915S 19" LCD Monitor
Dimension of image change when displaying clear or dark image
Same problem Picked up this monitor about half a year ago, a Viewsonic A91f+, and have been having some issues for a while now concerning what appears to be shifting in the monitor image, but that is about the best I can describe it as. It is most noticable when a large dark area meets a light area, like text or window edges. This "shifting" only occurs on the right side of objects and seems to show most often after I switch resolutions more than a few times, usualy due to gaming. Ive also noticed it happening from running random programs that dont require resolution changing/flickers but this happens FAR less often. -photograph of the effect- As you can see, its pretty subtle on a darker background, but Ive had no luck carturing it on a light one. Anyone have any idea as to what is occuring on this monitor and how it could possibly be fixed? Possibly an issue with magnets? For a while, I did have a small headset hanging off the the monitor on the side that the images "shift" towards, but even taking those off and away havent fixed it. Currently the only fix I have found for this is to shut my monitor off for 5-30 minutes, depending on how bad the "shifting" is when I find a time break long enough to fix it.
Jan 12, 2006 | ViewSonic G790 19" CRT Monitor
Sony KLV-40ZX1M 40 in. LCD TV Logo
46 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
