Question about Samsung HCN436W 43" Rear Projection Television
I have a samsung SP43W6HD and recently upgraded my Sky to SkyHD. However, the installation technican told me that my television does not have an HDMI socket to connect the cable to view in HD. How can I connect the HDMI from the SkyHD box to my television so that I can view in HD?
  • 375 Answers
SOURCE: Samsung HC-P4752W Blurry ONLY on HD Channels
if the convergence is ok in these modes then i would try to set the service menu's eprom
Posted on Aug 18, 2007
  • 375 Answers
SOURCE: Samsung HLP5063W-Picture Dropping Out Using HDMI
is the eprom settings set correctly for the input beeing used,you must enter the service mode to inspect and adjust the settings,call your local dealer for assistance.
Posted on Sep 12, 2007
tvtek
  • 1284 Answers
SOURCE: Samsung Rear Projection DLP HDMI Captions
The captions are turned on in the cable box itself. If you have a Motorola cable box, turn it off then hit the menu button for the cable box. You will then see where you can turn off the closed captioning. Anymore questions email me tvtek@msn.com
Posted on Nov 30, 2007
  • 375 Answers
SOURCE: Samsung SP43w6HD circuit diagrams
servicemanuals.net
Posted on Mar 28, 2008
sabreusa
  • 271 Answers
SOURCE: HDMI failure Samsung HL-R5087W 50 in HDTV
After reviewing the service manual for this set, the problem is is in the DIGITAL BOARD. To get the right Digital Board you will need the Version number of the TV.
Good luck
N Sabre
Posted on Nov 09, 2009
I have skyhd connected to Lght-805sh via optical connection but when i turn sky over from a hd channel to normal channel there is no sound
Not sure what you mean by "optical connection" but you need to connect your SkyHD box to your TV using both HDMI and SCART cables. Your Sky HD box will then send the signal via the HDMI cable for the HD channels and the SCART cable for the SD channels.
Hope this helps
BElectric
Nov 06, 2010 | LG Televison & Video
Sky hd remote code needed please
Sky High Definition SkyHD uses a new design of Slim line remote control. The Default TV code pre-programmed into the RCU is now for Phillips and is (0)065. The SkyHD RCU is programmed in the usual manner using either the instructions in the Digital Installation Manual or via the Sky Customer Service option in the Interactive on-screen menu.
The SkyHD RCU can also be programmed to operate Sky+ boxes as well as SkyHD:
Press the TV button.
Press and hold SELECT and i together until the LED flashes twice.
Press the number button 1 and then press SELECT.
(Obviously you can't have a SkyHD and a Sky+ Digibox both in the same room).
Note: To re-programme the RCU for Sky HD box operation only, repeat the above process pressing the 2 button in step three.
Keep pressing HELP and waiting a few seconds until you find the correct command that activates the AV source you require then press SELECT.
The HELP button will now directly activate the chosen AV source instead of toggling through the alternative options to reach it.
There are 18 AV source commands to be tried before the RCU blinks 3 times to indicate it is out of options.
The Sky Guide buttons (SKY, tv guide, box office, services & interactive) can now be directed to use the same AV source as the newly programmed HELP button.
Press SELECT and GREEN until LED flashes twice.
Press HELP then SELECT and the LED will flash Twice.
The Sky Guide buttons will now instruct the TV to switch to the desired AV source and the RCU will be in Sky Mode.
Discussion here: http://www.digitalspy.co.uk/forums/showthread.php?t=944054
You can also use a Sky+ remote to control a SkyHD digibox.
See codes page for SkyHD
Mar 17, 2010 | Televison & Video
LG HD 37 INCH TV GREEN LINE APPEARING ALONG THE BOTTOM
On a LX2R to remove the green bar at the bottom or the blue bars on ths side using the sky HD box go to menu and the pip menu at the bottom of the list, access input and make sure the HDMI input is on DTV and NOT PC.
Feb 19, 2010 | LG 32LG30 32 in. LCD HDTV
I have just had a skyhd box fitted and every time i switch my technika tv off and then switch it back on i am getting a blank purple screen .it is as if the tv is not reconising the hdmi input cable .the...
I have the same problem, i just bought a new Samsung 37" and am getting the "Purple Screen" on occasion when i switch from Blu-Ray back to Sky HD. I didnt have this issue with my older Samsung. Upon looking into this i have discovered that it is to do with the HDMI Handshake between the TV and Sky Box. One solution i have read is to buy a HDMI splitter that is HDCP compliant (ALL SHOULD BE IN THIS COUNTRY) what happens then is that Sky does the handshake with the splitter and all is ok. I cant confirm that this works as i have not had chance to try it, but it all adds up and makes sense. Hope this helps
Dec 01, 2009 | Televison & Video
LE40R74BDX HDMI input stopped working
I work for sky as an engineer (not a subby)
HDCP is the encryption that is sent down when a program is transmitted. I have had this several times over the years and have found out that you need go to the manufactors web site or call them to update your telly this will sort out this problem.
I would do this sooner then later... reason I am telly you this is sky have take the Component inputs off all the sky boxes now.... The box you have is a THOMSON (have a look.... make you smile)lol this was due to people connecting there sky HD box to there pc via Component and using programs like Copy+ and extract + to copy the content.
If your box breaks down. then you are snookered if you telly is not going to accept the skyHD through a HDMI connection.
Hope this helps
Cheers
Little Dish Fitter
Mar 04, 2009 | Samsung LE40R72BDX 40 in. HD-Ready LCD...
Ive just moved to a house with sky all ready and have not got a clue how to set the thing up. I have a 50in PS-50Q96HD Samsung HDTV Plasma. I have the sky cable and the normal tv cable, what goes were...
first of all you would need to have a Sky HD set top box.
The cables coming into the wall.. you said one was the terrestrial aerial and the other was a sky cable. In order for you to benefit from Sky HD you would need twin cable or two single cable running from your sky dish.(allows you to record a program and watch another etc.
summary:
skyHD box
two feeds coming from your dish,
there is only one place these can go as they are screw on ie F connectors. so they would screw onto input 1 and 2 on the back of the Hd box.
Run a HDMI cable from the back of the sky box from the HDMI port to one of the HDMI ports on the back of your telly. last but not least you would need to get a power cable (kettle plug) to power the thing.
In regards to your terrestrial aerial you can plug this directly into your telly or via your aerial in port on the back of the skyHD box. then you would have to run an aerial cable from the RF out 1 or 2 to the back of your telly this would allow you to record two things on your Sky HD box then switch to your built in freeview that your telly has.
Hope this has answered your questions
Cheers
Little Dish Fitter
Feb 28, 2009 | Samsung HP-R5072 50 in. Plasma HDTV
Picture Flashing
I have a similar problem but my picture flashes black and white and the sound goes at the same. Also sometimes it will flash pink and blue. I've read elsewhere that the issue is a known problem with compatability between Samsung tv's and sky boxes. Apparently the box needs to be replaced but I'm unsure what type of box. I've read perhaps a PACE sky box could fix the problem. I think the best option would be to contact Samsung - that's what I'm going to do.
Feb 14, 2008 | Samsung LE32R74BDX 32 in. HD-Ready LCD...
Samsung HCN436W 43" Rear Projection Television Logo
89 people viewed this question
Henry  Thomas
Henry Thomas
