Question about Welding Tools
I have a spoolmate 200 ser. JJ373378 stock no. 084878 with a spool gun. i pull tricker wire runs no arc. I don't think main contacts are kicking in.
  • 407 Answers
If you wire runs, then your problem is the power line, check first that you have in hook up to the psotive (+) side of the power source/machine. The spool guns is just a wire feeder, your heat comes from the power source.
Posted on Jan 02, 2011
Anyone know what spool gun I would use on a miller syncrowave 300(s) welding machine. I think it might need an adapter but not sure.
  • You can contact direct, but here are some links.
  • Miller Spool Guns for Aluminum and MIG Welding - MillerWelds https://www.millerwelds.com/accessories/guns-torches/spool-guns Spool Guns. Spoolmate™ 100 ... Reliable direct connect Spoolmate™ 150 spool gun provides 20 ft of cable reach and accessibility. ... Miller respects your privacy ...
  • AD/4.6 Syncrowave 210 Series - English - Miller https://www.millerwelds.com/~/media/miller electric/imported mam... · PDF file Syncrowave ® 210 Series TIG/Stick/MIG ... Miller Electric Mfg. Co. ... Spoolmate™ 100 Spool Gun #300 371 Includes 12-ft. (3.7 m) ...
  • Miller Spoolmatic 30A Spoolgun 130831 - Cyberweld.com store.cyberweld.com > ... > Miller Spoolguns & Spoolgun Adapters
    • 5/5
    • 11 RATINGS
    • $1,013
    Miller Spoolmatic® 30A Spoolgun is the professional's choice for ... connect to a Miller 300 pro we would ... spool gun plugged into our Miller ...
  • Manuals & Parts - MillerWelds https://www.millerwelds.com/support/manuals-and-parts ... operations/setup information, and maintenance to troubleshooting and parts lists, Miller's manuals provide detailed answers to your product questions. ...
  • Re: Miller syncrowave 180sd & MM 185 w Spool Gun weldingweb.com > ... > Shop, Trade, Sell Forum
    • 3 POSTS
    • FIRST POST: 2013-04-19
    2013-04-25 · Re: Miller syncrowave 180sd & MM 185 w Spool Gun ... The Syncrowave has about 300 hrs. run time and 350 Arc Starts ... Miller syncrowave 180sd & MM 185 w Spool Gun
  • Spool Gun Hookup Chart - MillerWelds https://www.millerwelds.com/.../spool-gun-hookup-chart Find spool gun hookup information for Miller welders. Determine which spool gun works with each ... Spool Gun Hookup Information. ... Millermatic® 300 without Meters:
  • Spool Gun Hookup Chart MillerWelds
    Jun 10, 2016 | Miller Welding Tools
    When I push the trigger I lose my voltage to run the feed motor, the motor works with other power source
    Had the same problem with mine but mine isn't miller and don't know if your's is built the same but if you access the inside of the machine there's there's a large copper spool inside and that wire feed handle is powered through it. The connection heats up over time and becomes a short. I re spliced mine then soldered it and then cut piece of copper tubing and crimped it around the connection and soldered that as well.
    Corrected the problem and I tried pretty much all listed solutions other then this first. Tried the new liner in the torch, the new tip and clamping the wire feed assembly with a clamp instead of the tensioner. All failed. I stumbled on to the fix accidentally when I was trying to install a more heavy duty fan. Hope this helps. Good luck.
    Apr 21, 2016 | Miller Spoolmatic 30a Mig Spool Gun 130831
    My wir burns up at the feed wheel before it goes to the sleve
    did you forget to reverse the wire .seems like I read that someplace . many newer ones thay added a switch for that purpose .
    May 07, 2015 | Miller Spoolmatic 30a Mig Spool Gun 130831
    Miller spoolmatic pro 30A, It still feeds, but won't arc. Less than a year old, what can I try?
    Run the first layer of wire of the spool you will see a color change. The wire gets a fine layer of oxidation and this causes a bad contact.
    May 02, 2015 | Welding Tools
    Miller 130 wire advances, fan runs, but will not arc as wire comes out
    Most of these machines (would have to have serial number to be sure) will not feed if their is no output voltage, since part of the motor voltage comes from the arc voltage.
    So, I would suspect broken wires, either in the work lead or the gun. If it arcs just a little, probably the gun. One place the work lead breaks is right at the back of the clamp. Pull on the insulation and see if it "stretches". If so, the wire there is broken.
    Feb 21, 2015 | Miller Welding Tools
    Spool won't turn
    are the rollers tightened enough, also maybe the wire is jammed in gun.
    Feb 02, 2013 | Hobart Handler 125 115 Volt 30 To 125 Amp...
    Miller 350p welder gives a "help 3" code.
    Code help-3 Indicates that the gun trigger was pulled and held during power up. Release gun trigger and clear fault condition. Also, this display can Indicate no open circuit voltage detected when gun trigger is pulled and no arc detected within 3 seconds, this means that the trigger was held without any metal contact. The machine will shut down in order to avoit the wire to continue to run freely.
    To fix:
    Turn on the machine without pressing the trigger on the gun. Then increase to the max the wire speed. Then turn off the machine. Press the trigger after the machine was turn off, then without releasing the trigger, turn on the machine and release the trigger after 2 seconds. That will take care of it.
    Nov 17, 2010 | Miller Welding Tools
    My little 110 mig welder is arcing without trigger pulled
    i believe that the trigger only send out the wire and does not control the arc the tip should be live as long as the welder is on
    Feb 28, 2010 | Lincoln Welding Tools
    No arc, fan works,wire feeds.......ect.
    wityh what little imfo you gave I would first go to the main contactor ,turn unit on pull gun trigger see if the contactor pulls in.that is where primary power comes from to create arc.
    Dec 14, 2009 | ARC Welding Tools
    Welding Tools Logo
    115 people viewed this question
    Top Welding Tools Experts
    Bill Boyd
    Are you a Welding Tool Expert? Answer questions, earn points and help others
