Question about Cell Phones
LG VX 8300 TELEPHONE
I can not ear mp3 music in my telephone I already enabled the mp3 function and the front buttons as well, but when I press the play button the display says NO SONGS FOUND IN MEMORY.
I already recordered some mp3 music in the MICRO SD
In menu hit "0", after hit six "0" for the access code, you will get the configuration menu.
Check each one of the options, there is an second option called MEDIAPLAYER
When you get it, there are some options including AUTOPLAY option.
All that you need to do is enable this option.
Posted on Jul 08, 2008
Tip
How to Block a Phone Number With AT&T
<a><img src="block-phone-number-at_t-200X200.jpg" /></a> Call blocking is an easy way to deflect unwanted calls. <span></span> jQuery(document).ready(function(){ jQuery('.intro .thumbnail a:first').attr('href','http://i.ehow.com/images/a04/th/aq/block-phone-number-at_t-800X800.jpg'); }); <p>If you're an AT&T customer and you're tired of receiving calls from companies that try to sell you things you don't want or from people who simply pester you over the phone, the solution is simple. AT&T has a call-blocking service that you can activate in a few simple steps so you won't have to ignore the phone or hang up on people.<br /> jQuery('.intro .thumbnail').each(function(i,e){ jQuery(e).find('img').one('error',function(){ jQuery(e).remove(); }); }); <span>Difficulty:</span> Easy <span>Instructions</span> <ol> <li> Dial "*60" and listen to the voice instructions.<br /> </li> <li> Press "3" to turn your call-blocking service on.<br /> </li> <li> Press the "#" button.<br /> </li> <li> Dial the telephone number that you want to block.<br /> </li> <li> Press the "#" button again to block the number<br /></li></ol>
on Jan 12, 2011 | AT&T Blackberry Curve 8300 Smartphone
My mp3 sunglasses w Bluetooth work good but can't figure out how to use the blu tooth
learn how to pair devices,a combination of buttons must activate the pairing seqvence,search the device in the pair mode by phone or other,pair it and then play music by your telepphone if mobile telephone can play via bluetooth,if not u only can enjoy hands free function or come up with a most performant tphone
best regards
Oct 28, 2014 | Audio Players & Recorders
Computer does not recognise speedstream 6300
you try form USB or LAN interface \\Ethernet connection (recommended)
  1. Plug one end of the RJ-11 telephone cable into an unfiltered telephone wall jack (enabled for Sympatico High Speed Internet service).
  2. Plug the other end of the RJ-11 telephone cable into the DSL port on the back of the modem.
  3. Plug one end of the RJ-45 Ethernet cable into your computer's Ethernet port.
  4. Plug the other end of the RJ-45 Ethernet cable into the Ethernet Port 1 on the back of the modem.
  5. Insert the rounded end of the power adapter into the Power port and the dual-pronged plug end into your power outlet.
  6. Press the power button to turn on the modem.
USB connection
  3. Plug the small, square end of the USB cable into your computer's USB port.
  4. Plug the wide, flat end of the USB cable into the USB port on the back of the modem.
May 28, 2012 | Efficient Networks Speedstream 6300...
Printer laserjet 3055 give fax problem problem is fax comm.error 322
Good day.
A fax comm.error 322 usually means:
Telephone line conditions were too poor to send a fax.
Solution:
1. Reattempt the fax transmission at a different time when telephone line conditions have improved.
2. If the session fails after transmitting several pages of a large document, retransmit the document as several smaller documents.
You can also try disabling the ECM feature:
Reconfigure the local fax machine to use different configuration settings, toggle the ECM state and/or select a slower reception speed.
To Disable ECM, perform the following steps:
1. Press the or > button until the front display reads "Fax Setup".
2. Press the ENTER/MENU button.
3. Press the or > button until the front display reads "All Faxes".
4. Press the ENTER/MENU button.
5. Press the or > button until the front display reads "Error Correction".
6. Press the ENTER/MENU button.
7. Press the button until the font display reads "Off" and then press the ENTER/MENU button to save the setting. (Off disables ECM and On enables ECM).
TIP: It would also be helpful to check physical conditions of your phone cord and telephone filters if you are using one.
Jun 26, 2011 | HP LaserJet 3055 All-In-One Printer
Canon MP530 receive fax issues
Receive Mode Settings Select from the following receive mode options to suit your needs. Once you've decided on which receive mode to use, follow the below instructions to set the receive mode using the operation panel. Receive Mode Setting
  1. Press the <FAX> button to enter Fax mode.
  2. Press <Menu>.
  3. Press the right or left arrow button to select [Receive mode settings], then press the <OK> button.
  4. Press the up or down arrow to select the receive mode that best suits your needs, then press <OK>.
Types of receive mode
Select the receive mode according to your needs.
Receive mode
Purpose
FAX/TEL AUTO SW When you want to receive faxes automatically as well as voice calls. FAX ONLY MODE When you want to receive only faxes automatically with your machine, or have a dedicated telephone line for FAX use only. DRPD When you have subscribed to a DRPD service with your telephone company. MANUAL MODE When you receive mainly voice calls and sometimes faxes, or want to receive faxes manually. ANS.MACHINE MODE When you want to receive voice messages on your answering machine and receive faxes automatically. FAX/TEL auto switch
FAX :
The machine does not ring but will receive the fax automatically. Voice call :
The phone attached to the machine will ring. Pick up the handset to answer the call. Note:
  • Ring start timing and Telephone ring length can be specified in FAX/TEL auto switch in the Receive mode settings.
  • If you want the telephone to ring when it receives a fax, connect a telephone to your machine and enable the Incoming ring settings in RX settings.
  • The phone attached to the machine may not ring depending on the telephone type you are using.
FAX only
FAX * :
The telephone does not ring. The machine will receive the fax automatically. Voice call :
You will not be able to answer the call. * If you want the telephone to ring, connect the telephone to your machine and enable the Incoming ring settings in RX settings menu.
DRPD
FAX :
Your telephone line will ring according to the ring pattern you have chosen and receive the fax automatically. Voice call :
Your telephone line will ring according to the ring pattern you have chosen. Pick up the handset to answer the call. Note: Specify the FAX pattern in the DRPD: Set FAX ring pat. in RX settings menu.
Manual RX
FAX :
The telephone attached to the machine will ring. Pick up the handset and if you hear a beep tone, press the <Color> or <Black> button on the machine to receive the fax. Voice call :
The telephone attached to the machine will ring. Pick up the handset to answer the call. Note: If you are far from your machine, you can use the remote receiving function to receive faxes. Pick up the handset of the telephone connected to the machine and press 25 (the remote receiving ID).
Ans. machine connect
FAX :
First the answering machine connected to your machine will respond to an incoming call, and then the machine will receive faxes automatically. Voice call :
The answering machine connected to your machine will respond to an incoming call. Note:
  • Set the answering machine to answer on the first or second ring.
  • The entire message should be no longer than 15
Nov 24, 2008 | Canon PIXMA MP530 All-In-One InkJet...
Can't always hear other person when using ear bud wint VX-8300
Make sure the ear bud isn't going bad, they are generally thin wired and poorly manufactured. Try a different set that is compatible.
If that doesn't fix it, take the battery out of the phone, get some rubbing alcohol and an old toothbrush and clean the headphone port.
And if that doesn't fix it, just get a bluetooth headset. Your pone is compatible and they can be found online for usually around $20. $40 for a descent set.
Hope this helps,
Simon.
Nov 13, 2008 | LG VX8300 Cellular Phone
Music troubleshooting
music on hold products are licensed and interface with office systems, so you may first want to check your music on hold interface....here is a link which may help
http://www.tmilimited.co.uk/music_on_hold.htm
Jan 07, 2008 | Panasonic KX-T7730 Corded Phone
MP3 enabling
Step by step to enable mp3: Two part process. To enable outside phone buttons to play mp3: From main screen press OK and then the number 0 seven times (you?ll see a series of question marks disappear). Then scroll all the way down and press #11 (Music Setting). Finally, choose My mp3. To get MP3s to play, including ringtones ? Press OK (Menu) and go to Settings and Tools, press 5 (phone settings), press 2 (shortcut key), press 5 (play key), and choose my mp3s.
Jun 21, 2007 | LG VX8300 Cellular Phone
Cell Phones Logo
51 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
