Does this computer have bluetooth? - Computers & Internet
  • Paul Bade Dec 30, 2010
    If you are running Windows, go to the System control panel and click on the Device Manager tab. Look for a Bluetooth device in the list.
    If you are running Mac OS X, go to "About This Mac" in the blue apple menu and click on "More Info..." to see if a Bluetooth transceiver is listed in the Hardware.
    There is a similar function somewhere in Linux, but the way to find it depends on what distribution you are running.
    If you want us to answer the question, you'd have to give us the brand and model number of your computer.
    Sergeant:
    Champion:
  • 217 Answers
Go to 'Computer' icon
Right click and click Properties.
Device manager.
Look down the list to see if 'Bluetooth' is listed under 'Network adaptors'
Posted on Dec 30, 2010
How do I make my hp officejet 100 discoverable
Extracted From the USER GUIDE (download here) http://h10032.www1.hp.com/ctg/Manual/c02648771.pdf
Set up the printer for Bluetooth communication
The printer allows you to print documents from
Bluetooth devices without a cable connection.
Simply print from a Bluetooth device such as a PDA or camera phone. You can also use Bluetooth technology to print from a computer to the printer.
Set up a Bluetooth wireless connection
This section describes how to set up and configure the device for a Bluetooth wireless connection.
You can configure Bluetooth wireless settings during software installation, or you can configure settings later using Toolbox (Windows), HP Utility (Mac OS X), or the Toolbox software for PDAs
(Windows Mobile). For more information, see Printer management tools.
To connect the printer using Bluetooth communication (Windows)
NOTE:
If you are using an external Bluetooth adapter for your computer, specific instructions for adding the printer might be different. For more information, see the documentation or utility provided with the Bluetooth adapter.
1.
If you are using an external Bluetooth adapter for your computer, make sure your computer is started and then attach the Bluetooth adapter to a USB port on the computer.
If your computer has Bluetooth built in, just make sure the computer is started and that Bluetooth is turned on.
2.
On the Windows taskbar,
click Start
, click Control Panel
, click Hardware and Sound
, and then click Add a printer
- Or -
Click Start
, click Printer
or
Printers and Faxes, and then double-click the Add Printer icon
or click Add a printer
3.
Follow the onscreen instructions to finish the installation.
To connect the printer using Bluetooth communication (Mac OS X)
1.
2.
Click
System Preferences in the Dock, and then click Print & Fax
3.
Click + (Add).
4.
Select the entry for the printer in the list with Bluetooth beside its name, and then click Add
5.
Set Bluetooth security for the printer
You can enable the following printer security settings:
• Require passkey authentication prior to someone printing to the printer from a Bluetooth device.
• Make the printer visible or invisible to Bluetooth printers that are within range.
• To enable these settings, you can use Toolbox (Windows), HP Utility (Mac OS X), or the Toolbox software for PDAs (Windows Mobile). For more information, see Printer management tools.
Set up the printer for Bluetooth communication 93
Use a passkey to authenticate Bluetooth devices
You can set the security level of the printer to either
High or Low
• Low : The printer does not require a passkey. Any Bluetooth device within range can print to it.
NOTE:
The default security setting is Low
. Low level security does not require authentication.
• High: The printer requires a passkey from the Bluetooth device before allowing the printer to send a print job to it.
NOTE:
The printer ships with a predefined passkey that is set to six zeroes "000000".
Set the printer to be visible or not visible to Bluetooth devices
You can set the printer to be either visible to Bluetooth devices (public) or not visible to any (private).
•Visible : Any Bluetooth device within range can print to the printer.
• Not visible : Only Bluetooth devices that have stor
ed the device address of the printer can print to it.
NOTE:
The printer ships with a default accessibility level of Visible
To reset to factory default settings
NOTE:
Using the following instructions will reset only the device's Bluetooth settings.
1. Press and hold down (Power button).
2. While holding down (Power button), press (Cancel button) 4 times, then press (Resume button) 6 times.
3.Release (Power button).
Sep 11, 2014 | HP Officejet 100 Mobile Inkjet Printer,...
Tip
How do I automatically start Bluetooth?
<p>Bluetooth is a wireless connection method used for two different devices together, like a computer, cell phone, headset or sync. You are required to enter code synchronization when connecting two devices, but most likely you do not want to enter this information each time you want to sync the hardware. Instead, you can automatically start the Bluetooth devices in sync with each other. <br /> <p><br /> <p>1. Turn on the Bluetooth device (such as a headset) and the hardware you want to synchronize with the equipment (such as your computer or mobile phone). <br /> <p><br /> <p>2. Click the "Start" button when using a computer, select "Control Panel" and finally "Hardware and Sound". Select "Bluetooth Devices" and click "Add" and wait for the computer to search for Bluetooth devices. Press "Setup" when using a mobile phone, select "Bluetooth" and activate the configuration. This allows the phone to search for the Bluetooth device. <br /> <p><br /> <p>3. Select the Bluetooth device, once it is detected (both computers and mobile phones) and enter your pair of four-digit code (listed in the user manual of Bluetooth device). <br /> <p><br /> <p>4. Press "OK" on your computer or mobile phone connects to Bluetooth. Now each time the devices are enabled on the phone and the computer automatically detect and connect to Bluetooth devices. <br />
on Jun 26, 2011 | Computers & Internet
How do i connect the blu tooth of cannon pixma printer yo my computer
Install the printwr driver first to your computer. Make sure that your computer is capable and has bluetooth capability. If the computer has bluetooth functionality open the bluetooth and search for bluetooth device. After bluetooth scan from your computer it will find the device which is your printer. Note that your printer bluetooth is open. Then connect computer to your bluetooth computer. That should be it.
Oct 12, 2013 | Office Equipment & Supplies
Bluetooth is not responding
which bluetooth device ? are you referring to ?
keyboard , mouse , ahh a webcam ?
Bluetooth is a wireless technology that connects devices over a limited-range network (WPAN, or wireless personal area network). Bluetooth transfers data three to eight times faster than a parallel or serial port.
Some Lenovo PCs includes an internal Bluetooth card to allow users to connect Bluetooth devices to the computer. Inactive Bluetooth support or computer settings can prevent the Lenovo PC from detecting a Bluetooth device.
Hold down "Fn" and "F5" after booting the computer or returning from standby to enable Bluetooth features. Click "Start." Click "Control Panel." Double-click "Bluetooth Configuration." Select the "Accessibility" tab. Check "Let other Bluetooth devices discover this computer." Select "All devices" from the drop-down menu. Click "OK." Double-click "Bluetooth Devices." Select the "Options" tab. Check "Turn discovery on," "Allow Bluetooth devices to connect to this computer" and "Alert me when a new Bluetooth device wants to connect." Click "OK." Exit from "Control Panel." Align the device with the Lenovo PC. Check the documentation included with the device to confirm it is the correct distance from the computer. Right-click "Start." Click "Explore" or "Open." Navigate to "My Bluetooth Places." Click "Bluetooth Tasks." Click "View Devices in Range" to locate the device. Select the device from the list. Click "Discover services" to use the device's applications on your Lenovo PC. Right-click the device and select "Connect" or "Pair" to configure the device. Hope it helps.
Jan 25, 2013 | Lenovo G570 43349EU 15.6" Windows 7 Home...
I have my plantronics discovery 975 paired to my computer and my phone. It is supposed to automatically connect when I skype and it doesn't. When it is connected it only lasts for less than a minute...
  1. Make sure you are using the latest version of Skype.
  2. Make sure that Bluetooth works on your computer. You can refer to your computer manufacturer's documentation or website for details on how to set up Bluetooth on your computer. You want to ensure that the Bluetooth software and drivers (known as the Bluetooth stack) on your computer supports the Headset Profile (HSP). It's recommended that you download and install the latest drivers for your Bluetooth stack.
  3. Pair your Bluetooth device with your computer. How you do this will depend on both the Bluetooth stack on your computer, and the Bluetooth device you are using.
  4. Make the Bluetooth device your Skype audio device:
  • Sign in to Skype and in the Tools menu, select Options...
  • Under Audio settings, select your Bluetooth device from the Microphone, Speakers and Ringing drop-down list.
  • Remember that not all Bluetooth headset features may be available when making a call with Skype. For example, whether the buttons on your headset function correctly depends on your Bluetooth stack.
Good luck from Headsets Direct!
Jul 28, 2011 | Plantronics Discovery 975 (8164001 P)...
I can't connect my Samsung Jet with my PC via Bluetooth. What am I doing wrong?
to connect your samsung phone to a pc via bluetooth you need to follow the steps.
1. install your samsung pc suite NPS,
2. open your phone bluetooth.
>> go to menu, select bluetooth, select settings under bluetooth, make your phone bluetooth's visible,
3. go to your computer, open your bluetooth, right click the bluetooth icon on the system tray, they are grouped and can be located near the clock.
4. select settings for your computer's bluetooth, make it discoverable, check the discover services.
5. under the computer's bluetooth panel, you can see there add device, click add device.
6. once the computer search for your phone, pair them with passcode like 1234, or 0-9 digits, it's up to you to assign the passcode but make sure they will be having the same passcode. ( both computer and phone).
once paired you can see them there in your phone's bluetooth panel, your computer and your phone together.
>>to check if successful connection was achieved, select a file from your computer, right click and send to your phone.
>>do the same thing for your computer, select a file from the phone and send it to your computer, but you need to confirm that your computer will be receiving a file from a paired bluetooth, by clicking the balloon
message at downright corner of your computer where your bluetooth is located.
regards...
Mar 02, 2010 | Samsung Jet S8000 Cell Phone
Bluetooth wont connect
This phone does not have the capability of connecting to a computer via bluetooth. I thought it did too, but was sadly dissappointed as well.
Feb 22, 2009 | Samsung SGH-T429 Cellular Phone
Computers & Internet Logo
27 people viewed this question
David Payne
David Payne
