Question about Hotpoint HSS25GFP Side by Side Refrigerator
The pipe from the compressor is freezing up and accumulates ice causing fridge to get hot.
I ve got a Samsung fridge freezer model (RL34SCSW1). My freezer is working fine but my fridge is not cooling?
Good day, please check at the back, at the bottom where the compressor is located for the pencil dryer(as in photo). Get a nice firm grip on it just be careful and feel the temp if it's cold or one side is hot and the other side cold the dryer is block. Otherwise feel the thickest pipe running into the compressor it should be cold if the fridge has been running for a while and the thin copper pipe existing the compressor should be hot. If the thin pipe is freezing up with a thick layer of ice and the dryer as some med-temp then there's a gas leak. If the thin copper pipe is very hot and the dryer has no temp then there's a blockage but if the thin copper pipe feels med-temp and the thick copper pipe more or less the same but a bit cooler the compressor is not pumping also feel if the compressor is running. If dryer as a warmth temp and the thin copper pipe is hot and the thick one very cold(when tipping your finger on your tongue and pressing it against the pipe your finger should stick a bit) if all checks out then it's the thermostat switching the compressor off at the rong temp.
Personal opinion I believe it's a blocked dryer or gas leakage.
Regards
Jun 09, 2016 | Samsung Refrigerators
Hotpoint ice diamond RFA52 P freezer ok fridge not cold enough, this is not a frost free and there are no vents in fridge or feezer?
Regards
Jun 09, 2016 | Hotpoint Refrigerators
For the last 4 months water has collected in and under produce bins where is freezes if not mopped up. I've tried pulling items away from shelf vents. Could a drain be clogged?
Freezer /fridge water/ice in fridge and or freezer
Usually due to CONDENSATION due to bad door seals or a plugged evaporator drain line? Can use a soft flexable tubing and very hot water to clean it out. Bad door seals usually need replacement, but u can use a blow dryer and something to pry it closer to the door wall while blowing hot air on to it. To create a seal, to test for bad door seals place a dollar bill in between the door and wall of fridge where it closes. Then slide out the dollar bill with door closed. It should offer some resistance and not be easy to pull out.
Most all fridges have a drain. Look inside your fridge for a "V" shaped channel with a small hole. This hole leads to a tube and a small pan which sits on top of your refrigerator's compressor. The defrost cycle causes water to run into the channel, down the tube, and then it generally evaporates with the heat of the hot condenser/compressor.
However, if that tube is clogged with food crumbs, particles , debris etc, you will have to clear it to get back to a normal mode of operation. A toothpick, pipecleaner, straw or a cotton bud can often do the trick.
Even a frost free freezer will still ice up at times in the areas away from the heated defrost area and the drain line can freeze. This icing causes the pipe work to the compressor to ice over or sweat and cause a puddle. Or if the drainage has frozen over, it will need to be de-iced. ( usually the line is under the freezer bottom plate covering. Towards the back of the unit) And there is another inside the fridge area also.
Give the freezer a good overnight defrost until it's totally clear of ice in addition to making sure the drain is clear to the pan at the back and then restart the freezer.
Apr 21, 2015 | Samsung RF217ACRS Bottom Freezer French...
I have a hotpoint ice diamond rfa51p and alot of water fills the fridge what causes this?
Apr 20, 2015 | Hotpoint Refrigerators
Water freezing on floor of lower draw under ice maker
Dec 05, 2014 | Refrigerators
I have a samsung refrigirator side by side with a bottom freezer door. It is leaking from the bottom of the right side of the freezer right of the free
Jul 15, 2014 | Samsung Refrigerators
Samsung RS275. Water pooling under bottom drawer and freezing. What doesn't freeze, leaks through the door to the kitchen floor. What is happening?
Jun 26, 2014 | Samsung RS275AC Refrigerator
Freezing around door of freezer
Jun 01, 2014 | Samsung Refrigerators
Water dripping from freezer
May 07, 2014 | Samsung RF4287HARS Stainless Steel French...
Fridge freezing
Low freon charge will cause the compressor to run continuously, as it never reaches the set temperature. This will also cause excessive ice buildup as well. I am assuming this little fridge doesn't have an automatic defrost. If it does look at that next. You didn't say, but does it reach proper temperature? Go to the back where the compressor is. Feel the lines coming out of the compressor. the low pressure, or larger one, it may have insulation around it, should be cold. If you cant tell (sometimes these small compressors they look the same size) its the line leading inside the freezer. Feel about 1 foot away from the compressor, if possible. Next feel the high or small pipe, this one is going to the outside coil. This should be very warm, but not cool and not real hot. This goes for the compressor too. A 134A system sometimes is very hot when low on freon.
Jan 09, 2008 | Stainless Cruise 49 Marine Refridgerator -...
Hotpoint HSS25GFP Side by Side Refrigerator Logo
362 people viewed this question
Top Hotpoint Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Sal DeAngelo
Are you a Hotpoint Refrigerator Expert? Answer questions, earn points and help others
