Question about American Standard 2770.018w.020 Cadet Whirlpool White
The on and off button for the Jetted tub was pushed in and it stayed. What should be done to fix it?
  • Anonymous Jan 03, 2011
    The solution from ericvzz to pull the hose from the motor did not fix the button that is still pushed down. What next?
  • 83 Answers
If you can get to where the motor is..there should be a small plastic hose the inserts into motor...or plug...if you pull the hose off it should allow button to push out again
Posted on Dec 31, 2010
My Aqualux tub is not working correctly. When I push the button for the jets to start they do but when I let go of the button the jets stop, the button will not stay in place for the jets to work
Hello Sheri Walker
Not finding a lot of answers in the USA... (sorry)...
The really good news is the air parts of these
switches are terribly easy to test.. Could just be a loose nut on the tubing...
16A On Off Push Button Switch Jetted Whirlpool Jet For Bath Tub Spa...
For "spares" CONTACT
Fetim Group United Kingdom
PO Box 16847,
Solihull,
B90 9JE
United Kingdom
Email: enquiries@uk.fetimgroup.comTel: 0121 395 2000
Carnac the Magnificent
Jun 15, 2017 | Home
Get jets unplugged
Cleaning your Tub
There are several options for cleaning the piping on a jetted bathtub.
The reason you have a residue on the bathtub surface when you are done bathing is because there is bacteria built up in the plumbing of the jetted tub. In order to remove that and reduce the amount of "yucky stuff" coming into the tub when using it, we recommend a regular usage of a jet cleaning product about once every couple of months
Here is a link to the cleaning products I can find right now. There may be other out there that I am not aware of but I do know these products work well in all jetted bathtubs.
US Parts Center
Jan 19, 2014 | Whirlpool Home
I need to know how to clean the jets in our eljer spa tub
Cleaning your Tub
US Parts Center
Oct 04, 2013 | Eljer Home
American standard jet bath tub black particles coming out of jets
The problem you are experiencing is common to many jetted bathtubs.It is a result of dried bathing water in the tub. There are a couple of solutions to resolve this ongoing problem.
  1. Use your tub more frequently as the water will not have time to fester in the pipes.
  2. Use a cleaning solution made for cleaning the pipes on jetted bathtubs once every three months.
You find Cleaning and Maintenance Products for jetted tubs at the following website. US Parts Center
Rod
US Parts Center
888-521-6183
Feb 25, 2013 | American Standard Evolution Oval Comfort...
Regarding a 30x60 indoor jetted tub (Jacuzzi). When I push the on/off button, the pump slows down but then a few minutes later starts again on its own when there is no water. Any idea what is going
IF that is the one I recall, the switch is not connected to the tub. When you press the button, it sends air pressure to the switch under the tub to activate it;. You need to check the tubing and the switch
Feb 22, 2013 | Jacuzzi Home
Jetted bathtub jet replacement
there will be pool and spar shops in the district that will have various spares or can get what you want
They will also advise you on how to fix /replace the faulty jets
jet tub manufacturers seldom use specific parts but opt for off the shelf generic parts to keep production costs down
Jul 31, 2017 | Home
Purchased new home with a swirl-way avalon jetted tub dont know how to start it please help
is there an air button on the top of the tub? if so that is what you would turn the pump on/off with. give it a push and see. if you do have a button to push like that then make sure the air tubing is hooked up to the bottom of the air button and the other end is hooked to the air switch in the back of the motor.
if there is NO air button to push and just the logo on the top of the tub then you will need to fill the tub with water, get into the tub and then touch the logo. that would turn an older Swirlway tub on/off.
Feb 06, 2011 | Home
I pushed in the air button on our pac-fab jetted tub and it stayed in. How do I get it out?
outside ring on button turns, just turn and let air in and it shud pop out...
Nov 19, 2010 | Home
I have a jetted tub that has not been used in years, but still worked until recently. When I went to use it you could push the button all the way in with no response from the motor. So just wondering if...
the button is an air switch, check the simple things first. your tub is connected to a gfi plug or breaker, try reseting the breaker first.next is the air hose from the button to the pump connected,is it split or have a hole in it. with the access door removed pump the button and listen for an air leak, if so remove hose just by pulling on it, most hardware stores carry the same hose and sell it by the foot.
Oct 24, 2010 | Home
American Standard 2770.018w.020 Cadet Whirlpool White Logo
316 people viewed this question
Top American Standard Home Experts
Donni Steen
Mike
john h
Are you an American Standard Home Expert? Answer questions, earn points and help others
