Question about Jenn-Air JGS8750 Gas Kitchen Range
Familiar F3-1 error on Jennair #JGS8850ADS. Changed Control Panel, igniter, Sensor, thought problem was solved. After 1 week F3-1 error came back after oven is on for about 20 minutes and shuts the oven off!!! HELP PLEASE!!!! Cheryl
  • Jenn-Air Master
  • 1,711 Answers
F3
or
F4
Shorted or open oven temperature sensor
(RTD) Check sensor harness and harness connection
between oven sensor and oven control. Replace oven temperature sensor (RTD) if
wiring is ok.
Posted on Feb 23, 2011
2006 grand prix no spark
IF YOU HAVE NO SPARK CHECK IGNITION COIL(S)
Jun 29, 2013 | Pontiac Cars & Trucks
My Maytag Self cleaning range is giving me a F-4 error when i turn on the oven
Maytag / MAYCOR / Magic Chef / Jennair / Admiral
Oven Fault Codes
Display Condition Remedy
F0 Function key shorted or stuck button Clean and unstick button or replace Touch Pad or Clock
F1 Defective Touch Pad or Membrane Replace Touch Pad or Membrane
F2 Oven over heat defective Relay Board or (if present) or defective Sensor
F3 Oven Sensor Open Replace Sensor
F4 Shorted wire or Sensor locate short and correct it or replace Sensor
F5 Hardware, safety circuits disagree Replace Clock
F6 Missing AC (power) signal Check for proper voltage (plug, breaker, etc.)
F7 Function key shorted or stuck button Clean and unstick button or replace Touch Pad or Clock
F8 A/D Warning Replace Clock
F9 Door Lock Warning Check door lock circuit or Replace Clock
OK F4 is a Shorted wire or Sensor locate short and correct it or replace Sensor bcd5f2e.jpgGo to the rear of the stove and take the service panel off after disconnecting power. Find the sensor and unplug it. Check for continuity between each terminal and earth/ground/frame. Look for corrosion in the plug. Frigidaire offers a nice video which shows how to check a sensor. Yours is not a Frigidaire but they all work the same. They provide the control with temp data. The oven control (ERC) sends out voltage to the sensor. As temp changes the resistance in the sensor changes. This tells the brain (ERC) temp changes. When the sensor gets shorted or is open (no continuity) then the ERC declares an error and posts it to your control panel. Here is a tip. New sensors sometimes come without the connector. 2 porcelin wire nuts are provided to splice in the new sensor. If you see corrosion on the quick connect. and you cannot clean it but you have continuity to the old sensor and it is not shorted you can bypass the quick connect and make it work in some instances. Just thought I would throw that in.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Jul 22, 2010 | Maytag Kitchen Ranges
1996 a4 disconnect battery changed temp sensor
check the pigtail on the temp sensor make sure it is clean and well connected i herd that if the pigtail is bad the car won't start also check the crank sensor and the ignition control module also check the fuse panel under the hood for there is a fuse for the ignition
Mar 09, 2010 | 1996 Audi A4
The cotrol panel blinks F7 E6 AND DOES NOT TURN ON AT ALL THE OVEN ALSO ONE BURNER IS OUT
f-7 mean stuck button on key pad or stuck relay on oven control. if the problem started while oven was in use replace oven control board. if problem started while oven was not in use replace key pad . because control board shorts when oven is running then this error comes up. but if the error is both f7 e6 then, F7 E6 shows that Function pad button stuck or Bad clock try to Un-stick Button or replace Clock also if persist then check the connections to the control panel
-------- for any other codes :--- Code Condition Check/Repair F0 and F1 Failed Thermistor Control Replace Electronic Range Control (ERC) F2 Oven temp exceeds 590 w/ unlocked door High resistance or interference in oven temperature sensor. Replace oven temperature sensor F3 Open oven temperature sensor circuit Replace oven temperature sensor F4 Shorted wire (Oven temperature sensor) Locate and correct F7 A = Function pad button stuck or
B = Bad clock Un-stick button or
Replace Electronic Range Control (ERC) F8 Component Failure Replace Electronic Range Control (ERC) F9 Program w/ door circuit Check wiring . ------ for getting required parts you can get it from ---- www.repairclinic.com or from www.partselect.com --------- if not familiar with replacing part a local repair technician familiar with your brand /model is advisable as its normal problem and gets solved after replacing the required part .and yes its worth getting repaired. ----- This will help. Thanks please keep updated.please do rate the solutionif helped.thank you for using fixya.
Oct 25, 2009 | Kitchen Ranges
What is f7 jennair sce30600
F7 stuck keypad
Stuck keypad may mean relay is turned on.
Determine if problem is with the Key Panel or Control by:
1. Pushing CLEAR/OFF pad.
2. Disconnecting Ribbon Cable from control and waiting at least 32 seconds to see if Code recurs
If code recurs, problem is in the control. Replace control.
If code does not recur, problem is with the Key Panel.
Aug 11, 2009 | Jenn-Air SCE30600 Slide-In Electric...
The remote control of my philips model #: 47PFL5403/98 is not working, I changed the batteries and still not working. I think the problem is in the sensor lens. how can I solve this problem. Thanks, Miloud
The IR Reciever is faulty if it is an 08' model, the serial number will indicate the manufacturer's date of production. The digits 5,6,7, and 8 are the keys. 5 and 6 is the week of the 78 year.
Have a technician replace the IR Board to solve the problem.
Jan 26, 2009 | Philips 47PFL5603D 47 in. LCD HDTV
I have a Jenn-air model # JGS8850ADS. An F3 - 1 came up. The temperature sensor was changed and it happened again on the same day that it was changed
hi there,
this is an overtemperature error that happens during self-clean. i would recommend ohming out the sensor and the harness and if they check out okay, replace the oven control itself.
Nov 07, 2008 | Jenn-Air Kitchen Ranges
Aman biult in oven
F2 is Oven sensor is out of range .. oven sensor is sending a reading that the control can not understand... replace oven sensor and you may have to replace the control too as it may not be reading correctly... good luck and let me know if it helps
Jan 02, 2008 | Amana AOCS3040 Electric Single Oven
Jenn-Air JGS8750 Gas Kitchen Range Logo
1,039 people viewed this question
Top Jenn-Air Kitchen Ranges Experts
Sal De
Craig Butler
Craig Butler
Paul Carew
Are you a Jenn-Air Kitchen Range Expert? Answer questions, earn points and help others
