Question about Toshiba 26 26AV502R 26 in. LCD HDTV
Toshiba 26av502R picture has a white haze with vertical lines that fade in and out covering the picture. The TV is a over one year old. Is this covered under warrenty? If not what should I do?
  • 179 Answers
SOURCE: Toshiba 50HP95 50 in. Plasma TV Has A Black Vertical Line!
either the address buffer or the panel has gone bad..a technician would be needed to determine which one..
Posted on Nov 28, 2007
SOURCE: Faint black lines running vertically
did you try unplugging everything and resetting your cable box. then plugging it back in,
i got some faint boxes yesterday and that did the trick
Posted on Jan 02, 2009
  • 1779 Answers
SOURCE: Sharp aquos has green and white vertical lines
You must contact a svc co. This is a upper or lower buffer board problem and possibly a control board. Nothing you have done wrong, it just happened.
Posted on Feb 28, 2009
  • 92 Answers
SOURCE: black haze covering picture after "pop" noise
That's a very old model to be only 1 year old?
It needs a Z-Sustain PCB anyway.
Thanks.
Posted on Sep 08, 2009
barbu51
  • 566 Answers
SOURCE: samsung plasma tv white spots
Hi tim
To answer your question;
The only thing that an extended warranty doesn`t usually cover is physical damage or abuse.
You problem is technical and therefore should be cover.
Hope this help Good luck
Posted on Jan 18, 2010
Vertical lines
Was this problem why you changed the panel in the first place?
check your connectors and perhaps you have a bad Tcon.
Nov 30, 2013 | Samsung LN32C450 32 in TV
White vertical lines like jail bars
If you wish to get some details; visit the site linked here. Pull up older posts.
Line faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.
Jun 26, 2017 | Samsung HLN5065W 50" Rear Projection...
My Toshiba 46XV540U LCD TV. Has ghost image plus many white vertical and horizontal line when it is turned on. These lines and the ghost image stay for 20 to 30 minutes and than the picture becomes clear....
Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish board that call T-CON board to do a replacement.This T-CON board sit in the middle at the bottom of the tv LCD screen panel.This T-CON board control all the picture pixels going throught to the tv LCD screen panel.
Jun 11, 2011 | Toshiba 46XV540U 46 in. LCD HDTV
I have a 6 year old 32" Toshiba tube .tv. I have
thir is somecondensers on the tv needs to be changed especialy on pwer supply and vertical circuit it is easy fault but needs technication,,,but first be sure thir is no floresent lamp common with the same supply of the set
Dec 23, 2010 | Toshiba 32A14 TV
Black haze covering picture after "pop" noise
Thanks.
Sep 08, 2009 | LG DU-50PZ60 50 in. Plasma Television
9 year old Toshiba TV. The picture is totally
Symptom shows TV got problem in vertical out deflection section, please check and replace vertical output IC and nearby electrolytic capacitors.
Jun 25, 2009 | Toshiba Televison & Video
Horinzontal white line with sound
vertical collapse. usually not to expensive to fix.
Jun 02, 2009 | Toshiba 32A33 32" TV
Toshiba 32D46 - White Lines at Top Of Display and TV Not Turning
as i've read you statement your tv need to check parts by parts, the one you mention upside trace vertical line, that part control on vertical ckt faulty parts nearly to faded filter capacitor you can directly replace all capacitor of vertical section. the one you adjust is that the playback transformer the upper portion is focus and the lower portion is screen voltage controlling screen voltage supply to crt g2 pin. if you turn this high that resulting hazing sound come from 2nd anode cup.
Mar 29, 2009 | Toshiba 32D46 32" TV
White lines accross top of screen on our 27 inch Toshiba,
lcd or plasma.
are the lines solid or blurred. do they have sharp edges.
You may have a memory problem with the display which can only be repaired by factory trained technicians, or a brave soul willing to find parts on ebay.
May 02, 2008 | Toshiba MW27FP1 27 in. TV/VCR/DVD Combo
Toshiba 26 26AV502R 26 in. LCD HDTV Logo
296 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
