Hey mate thanks for your reply. that link you posted wont work for me for some reason...?? I have had a look in my computer and i have 3 drives. c local, d recovery, e hp tools. in the d drive its empty. is there a way i can just upload what i need in there instead of instaling windows on the flash drive or ex dvd? The reason being, i havn't got the product key that i guess i would need, not less its somewhere else part from back, where i looked??. also its windows 7 starter ( if that makes any difference). i have mailed the guy just waiting on reply.. Again thanks for you help ryan
I have a citizen 3550 printer how can i hook it up to my computer to print out misc. things instead of using you conventional printer?
Thank you for posting to Fixya.com and it is my pleasure to guide you.
To help you in the furture I have found the manual for reference. Click the link or copy paste it to download it. http://www.posguys.com/download/iDP3550UME_09E.pdf
From the manual for the Interface Cables, the manual has pictures.
4.2 Connecting the Interface Cable
1. Turn off the power. (Mating side included)
2. Check the top and bottom of the cable terminals, and connect to the interface connector.
3. Secure the cable terminals.
Serial interface: Tighten screws to secure.
Parallel interface : Turn clamps to secure.
4. Connect the interface cable to the computer.
4.3 Connecting the Drawer Kick-Out Connector
2. Check the top and bottom of the drawer kick-out cable connector and connect it to the drawer kick-out connector located at the lower section of the printer.
3. Screw the grounding cable of the drawer to the grounding terminal located at the lower section of the printer.
CAUTION: • Connect only the prescribed drawer (Solenoid) to the drawer kick -out connector.
Good luck and please post back that you are successful and give thumbs up if my solution has worked for you. If I can be more helpful just reply.
Jun 21, 2011 | Citizen iDP-3550 Matrix Printer
When i put my computer on it makes this repetitive beeping sound and the screen wont come on, whats wrong?
Usually this is either RAM or CPU problem. How dit this came up? Was the computer working fine before?
In case of a problem or clarification, don't hesitate to post me a reply before rejecting my answer.
If you are satisfied, rate my solution with the "thumbs" or (even better) add a testimonial.
Thanks and regards
Please kindly rate this solution
Stelios
direct FixYa link: http://www.fixya.com/users/technical114
Sep 19, 2010 | Intel Pentium 4 517, 2.93 GHz...
Hey Taran..thanks for ur reply. i don;t have that driver on my computer and therefore i also did have a look at that link. could u please assist me in telling me what driver i should download as i have...
HI,
Can you specify your problem more briefly,Please?
May i know, for which product you were searching for drivers and may i know, whether you get any Yellow Exclamation mark for any particular product in the Device manager?
Please post your question as a comment, and we may solve your issue.
Thanks
RNJ VINODKUMAR
Oct 02, 2009 | Office Equipment & Supplies
(850/95 turbo) car won't turn over, it clicks ?
If you are satisfied with the Starter and the Battery. Check the connection to the Starter Solenoid Relay and Maxi Fuse. If all is still OK. Make a new Frame/Body ground to Engine casing Ground connection, if possible reusing the same, but cleaned, connection points .
Regards,DT
Aug 26, 2009 | 1994 Volvo 850
Red drum pad wont work
Use the Guitar hero drum tuning kit, you can get it here-
http://redoctane.custhelp.com/cgi-bin/redoctane.cfg/php/enduser/fattach_get.php?p_sid=yPstycuj&p_li=&p_accessibility=0&p_redirect=&p_file_id=146535&p_tbl=9&p_id=21748&p_created=1225742058&p_olh=0
Hook it up to your computer using a usb connector and up the sensitivity.
Hope it wokrs mate :)
Mar 25, 2009 | Activision Guitar Hero
Polaroid reply
stiv0 posted a solution on this web site. Here is the link
http://www.fixya.com/support/r741402-polaroid_flm_373b_lcd_tv_black_screen
Sep 25, 2008 | Polaroid FLM-3732 Television
Computers & Internet Logo
23 people viewed this question
David Payne
David Payne
