Question about HP PhotoSmart C4480 All-in-One Printer InkJet
How to check ink cartridge level in HP C440 - HP PhotoSmart C4480 All-in-One Printer InkJet
ctau
  • 372 Answers
SOURCE: how to check ink level on hp officejet 6210 all-in-one printer
  • Open the Printer Toolbox . There are two ways to do this:
    • Click Start and select HP Solution Center . Select the Settings menu, then the Print Settings submenu, and finally the Printer Toolbox .
    • In your printing application, click File , click Print , and click Properties . Click the Services tab, then the Service This Device icon.
  • The Printer Toolbox opens. Click the Estimated Ink Level tab. A cartridge may be running out of ink even if the graphic shows ink remaining (see the note at the start of this section). Lines or streaks always appear in printouts when the cartridges begin to run out of ink. Replace print cartridges that are out of ink or low on ink.
  • Posted on Mar 22, 2009
    aicaxz
    • 511 Answers
    SOURCE: I used to refill the ink cartridge of HP Deskjet D1460 by injecting ink. The problem is the level of ink is not resetted to full level, its still very low level. However, the printer prints normally
    Close the top left pin at head contactor (1 pin only), with tape. Plug it in head carriage. Unplug it. Close to top rigtht with tape too. Plug the head. Unplug head. Remove all the tape cleanly. Plug again. See ink monitor.
    Posted on May 31, 2009
    • 6 Answers
    SOURCE: reset ink level on hp 6310 #98 cartridge
    if you are using a refilled catridge you would not get ink levels right.
    if you want right ink level use genuine ink catridges.
    you can try taking out the catridges turning off the printer and turning it back on and then reinstalling the catridges.it might not help so if possible buy hp ink catridges.
    Posted on Aug 28, 2009
    • 7993 Answers
    SOURCE: How to check ink level on brother MFC-9440CN?
    Run the Brother Control Center. Click Device settings. Click where it says Inklevel.
    A simpler way is Start-->All Programs-->Brother--> ...-->Status Monitor.
    An icon will lodge itself on the tray (a printer). When icon is clicked on, the inklevels will show.
    Hope it helps.
    Posted on Sep 03, 2009
    SOURCE: How to reset the ink level for a HP 60 ink cartridge
    I tried blowing through the holes whenever printing quality is not good and it sure did the trick. I do printing a lot. about 40 reams a week and consume just about 300ml of ink..
    redilyn agub
    Posted on Jan 27, 2010
    Hp officejet 4620 does not print with starter cartridge
    If printer is in warranty, demand for replacement.
    1. Check ink levels in printer..if levels are showing, take out all ink cartridges refill them.
    If levels are zero, go for new cartridges.
    2. If ink level are showing in printer & physically cartridges having ink, then problem with print head, try to clean the clogged nozzles.
    Nov 16, 2014 | HP Officejet 4620 e-All-in-One Printer,...
    I want to check ink levels. It is blurring the color when printing
    Checking the ink levels A message will appear on the front panel display when the ink level for the print cartridge is low. The ink levels can also be checked through the HP Director on the computer.Checking the ink levels on a Windows computer
    1. From the HP Director , click Settings , Print Settings , and then click Printer Toolbox .
    2. Click the Estimated Ink Levels tab. The estimated ink levels appear for the print cartridges.
    Checking the ink levels on a Macintosh computer
    1. From the HP Director , click Settings , then click Maintain Printer .
    2. If the Select Printer dialog box opens, select the HP PSC, and then click Utilities .
    3. From the list, select Ink Level . The estimated ink levels appear for the print cartridges.
    Jun 21, 2011 | HP LaserJet CP1518 Printer
    How do I check my ink levels
    Method one: Check the ink levels from the idle screen on the color graphics display Look for four icons at the bottom of the color graphics display. The icons represent the ink level remaining in each of the four color ink cartridges: black, yellow, light cyan (blue), and light magenta (pink). A larger and more accurate view of the ink levels can be displayed from the Setup menu. If an ink cartridge containing non-HP ink is being used, a question mark displays instead of the ink drop in the icon for that cartridge. The HP All-in-One cannot detect the amount of ink remaining in ink cartridges that contain non-HP ink. Figure 1: Non-HP ink iconc00841629.jpg NOTE: HP cannot guarantee the quality or reliability of non-HP ink. Printer service or repairs required as a result of printer failure or damage attributable to the use of non-HP ink will not be covered under warranty. If a hollow ink drop icon displays, the ink cartridge represented by that color icon has very little ink remaining and will need to be changed soon. You might be able to continue printing for a short period of time with ink remaining in the print head assembly. Replace the ink cartridge when the Replace Soon warning message displays on the color graphics display. Figure 2: Low ink level iconc00841630.jpg When the Empty Ink message appears on the color graphics display, the indicated ink cartridge is out of ink. Replace the indicated ink cartridge. Method two: Check ink levels from the Windows computer The estimated amount of ink remaining in the ink cartridges can be checked from the computer. See the on-screen HP Director Help for information on checking the ink levels from the Printer
    1. Open the printer Toolbox. To do so, do one of the following:
      • Open HP Solution Center, click the Settings menu, then point to Print Settings , then click Printer Toolbox .
      • Right-click the HP Digital Imaging Monitor in the tray, then point to your printer model name, and click Display Printer Toolbox .
      The Toolbox opens.
    2. Click the Estimated Ink Level tab. The estimated ink level gauges display.
    Method three: Check ink levels from the Setup menu
    1. Press Setup on the printer control panel.
    2. Scroll down and select Display Ink Gauge . The Ink Gauge status from the Tools menu will only display on the color graphics display.
    Let me know if you have any other questions. Please rate this solution. Thanks.
    Mar 15, 2011 | HP Officejet Pro 8500 Wireless All-In-One...
    I am unable to print on my HP Officejet Pro 8500. i have recently replaced the 940 black cartridge and since then have been unable to print. i notice there are print cartridges in the main body as well...
    you can check the ink level from following steps Method one: Check the ink levels from the idle screen on the color graphics display Look for four icons at the bottom of the color graphics display. The icons represent the ink level remaining in each of the four color ink cartridges: black, yellow, light cyan (blue), and light magenta (pink). A larger and more accurate view of the ink levels can be displayed from the Setup menu. If an ink cartridge containing non-HP ink is being used, a question mark displays instead of the ink drop in the icon for that cartridge. The HP All-in-One cannot detect the amount of ink remaining in ink cartridges that contain non-HP ink. Figure 1: Non-HP ink iconc00841629.jpg NOTE: HP cannot guarantee the quality or reliability of non-HP ink. Printer service or repairs required as a result of printer failure or damage attributable to the use of non-HP ink will not be covered under warranty. If a hollow ink drop icon displays, the ink cartridge represented by that color icon has very little ink remaining and will need to be changed soon. You might be able to continue printing for a short period of time with ink remaining in the print head assembly. Replace the ink cartridge when the Replace Soon warning message displays on the color graphics display. Figure 2: Low ink level iconc00841630.jpg When the Empty Ink message appears on the color graphics display, the indicated ink cartridge is out of ink. Replace the indicated ink cartridge. Method two: Check ink levels from the Windows computer The estimated amount of ink remaining in the ink cartridges can be checked from the computer. See the on-screen HP Director Help for information on checking the ink levels from the Printer
      The Toolbox opens.
    If the ink level is low and the cartridge is new please contact the dealer from whom you got the cartridge and if it shows that the ink level is good enough please comment so that i can give you another step to perform
    Dec 30, 2010 | HP Officejet Pro 8500 Wireless All-In-One...
    I have a hp psc 1310 series printer and i can not find the site to check the ink levels. The book says to use the hp director on page 28.
    Checking the ink levels A message will appear on the front panel display when the ink level for the print cartridge is low. The ink levels can also be checked through the HP Director on the computer. Checking the ink levels on a Windows computer
    Oct 05, 2010 | Office Equipment & Supplies
    How to reset the ink level of my hp officejet 6500
    Checking ink levelsUse one of the following methods to check the ink levels. Method one: Check the ink levels from the HP All-in-One The ink level is displayed on the main screen of the control panel display. Locate the two icons that represent the print cartridges. The icon on the left is for the color cartridge and the icon on the right is for the black cartridge.
    • The exclamation mark (! ) symbol indicates a low ink level.
    • The question mark (? ) symbol indicates the product cannot determine the status of the print cartridge. This might be because the cartridge is refilled.
    Figure 1: Ink levels on the control panel displayc01362755.gif 1 - Exclamation mark indicates low ink in the color cartridge 2 - Ink level in the black cartridge is OK Method two: Check the ink levels from the computer using the HP ToolboxFollow these steps to check the estimated ink levels using HP Toolbox.
    1. Make sure the product is on and connected to the computer.
    2. Open HP Solution Center .
      • Windows XP: On the Windows taskbar, click Start , click All Programs , point to HP , and then click HP Solution Center .
      • Windows Vista: On the Windows taskbar, click the Windows icon (c01364735.gif ), click All Programs , click HP , and then click HP Solution Center .
      • Windows 2000: On the Windows taskbar, click Start , click Programs , point to HP , and then click HP Solution Center .
    3. Click Settings .
    4. Point to Print Settings , and then click Printer Toolbox . Printer Toolbox opens.
    5. Check the ink levels displayed on the Estimated Ink Levels tab.
    Figure 2: Estimated ink levelsc00670267.gif
    Jun 02, 2010 | HP Officejet 6500 Wireless All-in-One...
    How do you check the ink levels of the cartridges on a hp deskjet 940c
    If the ink level is low in a print cartridge, the Print Cartridge Status light stops flashing when the printer’s top cover is opened. When you open the panel the ink cartridges slide to the center , as far as checking the ink level find and right click on the printer icon, click properties, and find ink cartridges and ink levels.
    Thanks
    Shereena.
    Apr 22, 2010 | HP DeskJet 940c InkJet Printer
    How do I check ink levels on my HP deskjet D4160 printer?
    Here is what I found on the Web. You can click on the link below, to see Full Instructions. If you find this helpful, pls rate me.
    http://h10032.www1.hp.com/ctg/Manual/c00687555.pdf
    View estimated ink levels
    Follow these instructions to view the estimated ink levels of the print cartridges that are installed in the printer:
    Note If the print cartridges were used before being installed in the printer, the
    estimated ink levels will not appear on the Estimated Ink Level tab.
    The Estimated Ink Level tab also contains print cartridge ordering information. To view
    this information, click the Print Cartridge Information button.
    Thanks and good luck.......
    Pls rate me
    Jan 01, 2010 | HP Deskjet D4160 InkJet Photo Printer
    Ink level check
    I own several HP printers and 'all-in-ones' and not one of those has a way to check the ink level, save for actually pulling out the cartridge and shaking it - sorry. But i've got to say my HP printers are much better and faster than other brands I've used.
    Dec 31, 2008 | HP Photosmart 3180 All-In-One Printer
    Ink
    Normally when you install the print software you install HP Director or solution centre software that has a estimated ink staus monitor..from user manual
    Check the estimated ink levels You can easily check the ink supply level to determine how soon you might need to replace a print cartridge. The ink supply level shows an estimate of the amount of ink remaining in the print cartridges. Tip You can also print a self-test report to see if your print cartridges might need to be replaced. For more information, see Print a self-test report. To check the ink levels from the HP Director (Windows) 1. In the HP Director (or HP Solution Center), click Settings, point to Print Settings, and then click Printer Toolbox. Note You can also open the Printer Toolbox from the Print Properties dialog box. In the Print Properties dialog box, click the Services tab, and then click Service this device. 2. Click the Estimated Ink Level tab. The estimated ink levels for the print cartridges appear. To check the ink levels from the HP Image Zone software (Mac) 1. In the HP Director (OS 9) or HP Image Zone (OS X), choose Settings, and then choose Maintain Printer. 2. If the Select Printer dialog box appears, select your HP All-in-One, and then click Utilities. 3. From the pop-up menu, choose Ink Level. The estimated ink levels for the print cartridges appear.
    Print a self-test report If you are experiencing problems with printing, print a self-test report before you replace the print cartridges. This report provides useful information on several aspects of your device, including your print cartridges.
    Load letter, A4, or legal unused plain white paper into the paper tray.
    Press and hold the Cancel / Resume button and then press the Start Copy Color button
    The HP All-in-One prints a self-test report, which might indicate the source of the printing problem.
    Jan 12, 2008 | HP PSC 1510 All-In-One InkJet Printer
    HP PhotoSmart C4480 All-in-One Printer  InkJet Logo
    231 people viewed this question
    Seeker5211
    Seeker5211
