Question about Dell Computers & Internet
My Dell LCD monitor got hit with a sharp object and it broke the hard plastic screen. It shows all these stripes in both directions emanating from the fracture. Is it salvagable?
    Genius:
  • 1,288 Answers
Not economically, what you are seeing is a rupture of the LCD screen, replacing a screen assembly would cost more than the monitor is worth
Posted on Dec 30, 2010
I have a 1cm verticle stripe on my Dell Studio 1737 ?
Your lcd screen is going bad. You can verify this by plugging an external monitor to your laptop. if the external monitor shows without the vertical stripe it means the video card is good but your old screen is bad. If the external monitor shows the stripe then it means the video card is bad.
Plug in an external monitor and see if thedisplay shows up on it. It can be any kind of monitor even the old big fat crtmonitors as long as it has a vga cable to connect to your computer's vgaport. If so that proves your video card is ok. The video will showon most systems when you reboot without you having to do anything. Some systemswill require you to hit the FN (Function key) + F1 thru F12. Hold downthe FN key then hit the correct key for displaying on the monitor (F1 thruF12). The correct key will normally have CRT/LCD on it or it will havethe icon of a display.
May 02, 2012 | Dell Studio 1737 (Studio 1737-RubyR) PC...
When i change the dell monitor direction it shows green and blue colour in the both bottom corner..........
Its a blown capacitor in one of LCD screen. If its under warranty contact DELL for replacement.they don't repair those LCD screen. They just replace it.
Jan 26, 2011 | Dell M781P (Black) Monitor
Monitor powers on but screen is black. then a grey stripe appears across the screen. by pressing the leftmost button a faint picture shows the auto-reset? screen, a dell screen, and i can see the main menu...
Hi! I believe that the monitor has come to its end. 6 years is quite long for a monitor. You may have it repaired for there may be blown capacitors that needs replacement but a new monitor will be a great idea. HOpe this helps and have a good one!
May 18, 2010 | Dell E171FP 17" Flat Panel LCD Monitor
How to open dell monitor cover model E207WFPc
Remove the Stand, Remove the 4 Screws from behind the spot where the stand connects to, then take a flat ended object such as a butter knife or a sharp knife, and unclip the black face. then the screen comes right apart, this solution is also the same for the 20xx-30xx Dell WFP Models.
Apr 14, 2010 | Dell E207WFP LCD Monitor
About 2 inch yellow stripe appears on the LCD screen
This typically is a sign of either a problem with the monitor itself, the cable, or the computer.
Fault isolation is key here. If you have access to another monitor, I would suggest connecting that to the computer, or vice versa. That way you can figure out what's broken.
If it's the computer, you might be able to purchase a replacement video card. If it's the monitor - you're out of luck, and likely need to purchase a new one.
Nov 15, 2017 | E-Machines 19" Widescreen Flat Panel TFT...
Dark vertical stripe on monitor
You screen "LCD" is broken , need new lcd panel. Very expensive
Feb 01, 2009 | Samsung T220HD LCD Monitor
Pink Stripe
I must say thanx to Bogdan, his suggestion really did helped to fix my Dell :D
Only, the hard part was the opening of the case, it has no screws saide the middle behind the holder, but just hidden plastic border pins like on average cheap plastic remote control. After that, and removing few tin shells, second plastic connector ribbon from 10 of them needed a little press by nail and this is it! Thanx again :) I must point out that 2 local dell services said that lcd is unrepairable?!?! But shure, they did not bother to even open the case, or else, I would see the opening marks on plastic.
Mar 28, 2007 | Dell UltraSharp 2001FP 20.1" LCD Monitor
Computers & Internet Logo
435 people viewed this question
Alun Cox
