Home | Grills and Smokers | The regulator fre...
Grills and Smokers
Problem for Grills and Smokers
Generic problem for all Grills and Smokers
The regulator freezes on my three bur...
By lminks527 on Jul 08, 2008
I replaced the tank with a full tank and the regulator froze with a white coat of frost and the burners made singing noises. I replaced the regulator with a new one and the same thing happened. I put the old almost empty tank back on and again the same thing happened.
Same Problem
Oct 07, 2008
-   same thing . It freezes up
-   Guest
Solution #1
posted on Jul 08, 2008
Somewhat Helpful)
burzerko
Rank: Guru
Rating: 89%, 187 votes
Are you sure that you replaced it with the correct size regulator, Another thing might be the orifaces are restricted in the burner valves. The only way to check this would be with a manometer that reads in water coloumn. You also may have a burner problem if its a single burner. One thing you might do is take apart the burner(s) and blow them out with compressed air including the burner valves. But not the regulator this may damage the diaphgram.
Was this helpful?
Yes
No
Solution #2
posted on Aug 01, 2009
Very Helpful)
flydude
Rank: Master
Rating: 93%, 20 votes
This can happen when an excessive amount of propane gas is used or when if the tank you are using is not sitting upright, therefore allowing liquid propane to exit the tank through the regulator.
Was this helpful?
Yes
No
1 person thought this was helpful
Popular Solutions for Grills and Smokers
Questions and Unsolved Problems for Grills and Smokers
Answer
How does one roast with this product? Ours didn't come with a manual
Answer
We have a new Ducane 2 stage furnace High Eff. and we are wondering what would be the best furnace... (More)
Answer
can i get info on a used flat top that has a CG58 mod #? it is wired for 197-219 ac now help . i... (More)
Answer
cheapest place to purchase a neil perry t grill on the gold coast qld
Describe your problem:
Select a Category:
Sponsored Links
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Grills and Smokers:
Top Grill and Smoker Experts
Rank: Guru Guru
Solutions: 1303
Experience: 15 years field experience and 5 years navy training
Ask Me
Find more Grill and Smoker Experts
Top Range & Oven Repair
(423) 303-3784
Oven and Range parts delivered overnight...
 Appliance Parts Pros.com
(800) 555-9987
All the services you need in order to get your...
Home Blue
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
