Question about Whirlpool Duet GHW9150P Front Load Washer
What do I do if I think tree leaves have clogged my draining cycle
  • 56 Answers
If you have a leaf cog, it is most likely confined to the tub outlet, the tub-to-pump hose, and stopped by the pump. Remove the tub-to pump hose and start your inspection there.
Posted on Dec 30, 2010
My tulip poplar trees had tiny leaves on them then it got 28 degrese 2 nights and the leaves turned brown will they come back.i dont think my trees are dead
Trees underduress will shed its fruit then leaves to survive.
you may have to wait till a cool spell for new leaves to appear.
Jun 02, 2017 | Garden
Water draining into driver side door mat during rain. where is the drain line so I can maybe clear it with a thin wire?
Water drains through slots in the cowl and is channeled down through the door posts to be discharged to the ground. If you live in area where leaves fall from the trees,they tend to work their way into the channels and clog the discharge end. A refashioned (wire) coat hanger is a useful tool for removal.
Apr 27, 2017 | Cars & Trucks
What can I do to keep my bougainvillaea leaves from clogging the drain on my porch?
The best solution is either to preen the tree daily (pick off and throw up the dying leaves) or to make a sort of cage over the drain hole. You can do this with a used hanger or some wire from home depot. You just want to make sure that it is slightly raised and that the leaves can't get through to the drain.
Aug 05, 2013 | Garden
My whirlpool duet will go through full wash cycle and when it get to rinse it does full rinse but light for spin does not go on and it doesn't spin it stays in spin cycle (no light on) but it does not...
Hi
This issue usually occurs due to kinked drain pipe, clogged drain filter or drain pump. First make sure that the drain is not clogged and remove clogs if present. If no visible lint is present then remove the lower front access panel to check the drain filter and drain pump for any clogs, you'll need to clean the drain filter and drain pump completely. Hope this helps... Please post back for any further assistance.
Daniel
Aug 28, 2011 | Whirlpool Duet GHW9150P Front Load Washer
Spin cycle leaves clothes wet
Hi
Daniel
Aug 16, 2011 | Maytag Neptune MAH5500B Front Load Washer
The dishwasher does not drain-- it leaves about 1-2" of water in the bottom after running a cycle
Hi
Dishwasher not draining issue usually occurs due to kinked drain pipe, clogged drain filter or drain pump. First make sure that the drain is not clogged and remove clogs if present. If no visible lint is present then remove the lower front access panel to check the drain filter and drain pump for any clogs, you'll need to clean the drain filter and drain pump completely. Also, check for any food pieces stuck near the pump impeller & clean the chopper assembly. Please note that dishwashers don't drain out the complete water such that heating element doesn't overheat. Hope this helps... Please post back for any further assistance.
Daniel
Aug 16, 2011 | Dishwashers
Whirlpool duet front loading machine stops before the final spin cycle, leaving loads full of water. Prior to stopping the display shows 18 to 22 minutes left in the cycle, but suddenly stops. There is no...
Hi
Daniel
Aug 04, 2011 | Whirlpool Duet GHW9150P Front Load Washer
Frigidaire front load washer. water is not draining out during spin cycle leaving the clothes clean but sopping wet.
It sounds like either your drain hose is clogged or the water pump is inop. If you have washed any rugs or material the may come off and clog the pump that could be the problem.
You can remove the lower front cover ( 2 screws I think) and follow the black rubber hose to where the pump is located on the lower right side when facing the washer. The hose has a spring clamp you can remove if necessary to clean the hose.
Remember to unplug the washer when working on it.
Aug 09, 2010 | Frigidaire ATF6000ES Front Load Washer
Water dripping under dash drivers side. Is that the heater core?
Taste it,if it is sweet it is,but if it just taste like water,it is the condensation from ac,the drain needs to be unstopped.
Jul 05, 2010 | 2000 Dodge Caravan
Fabric Softner not leaving dispenser
Run some vinger through it. Fabric Softner leaves a filmy residue that can clog it up.
Jan 11, 2009 | LG DLE5932W Electric Dryer
Whirlpool Duet GHW9150P Front Load Washer Logo
20 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
