Question about Frigidaire Microwave Ovens
Microwave will not turn on. if you hold door just right it will sometimes. door bent? bad switch?
  • 56 Answers
Bad switch alignment. Some models can have an adjustment. Look carefully at the latch for any sign of damage. There are three switdhes that must simultaneously be activated, or the oven won't work. If, during the operation of the oven, the door is opened and the switches DONT simultaneously trigger, the monitor switch will detect this condition and short the incoming power directly to ground, which will blow the internal fuse, and possibly also trip the circuit breaker.
Posted on Dec 30, 2010
Rival rgst902 microwave. Door won't open.
verify that door is perfectly aligned with frame edge , sometimes in busy kitchens the door gets bumped and it no longer aligns with frame , if one forces it shut the mild spring that pops it open cant overcome the friction of frame hitting and it wont open requiring one to "HELP" it to open while holding down open button , look at latch carefully when open to see if any parts look bent or "not quite right "
Sep 17, 2015 | Rival Microwave Ovens
My panasonic genius prestige inverter microwave has started to click off after I enter the power & time. Sometimes it will work fine. Sometimes it takes 2 or 3 times of entering then cleaing the i
Check the door latch switch inside the oven. The 4 switches where the door hooks latch on to when the door is closed has to engage with the door hooks to tell the oven that the door is closed. loosen the 2 phillip screws that holds the switch assembly and slide it to adj. and ensure that the switches close when the door is closed.
Sometimes the switches go bad and cannot make contact and must be replaced. If you see that the connectors on the switch is discolored or overheated replace the switch, it is bad.
Jan 15, 2015 | Panasonic Genius Prestige Inverter...
Why does Panasonic nn-sn651 usually work; but sometimes, turntable won't start ?
This is an inverter model so there is no diode or hv capacitor.
You must adt. the door latch switch assembly to make sure that the door hooks make contact with the switches. Common problem is that the assembly is bent and must be perpendicular to the door.If it is bent the switch will not make contact with the door hooks.
Place a dab of lithium grease on the tip of the door hooks to ease closing the door. This is the cause of the bent switch assembly!
Aug 31, 2014 | Panasonic 1.2 Cu. Ft. Mid-Size Microwave -...
My GE XL1400 over-the-range Microwave does not power on to cook. The inside light will not turn off when the door is open or closed. Unplugged and re-powered with no change....where to start?
Easy....the reason the light does not go out when the door is closed and the microwave gun is not activating...is due to your door switch not "sensing" it being closed. Sometimes there two electrical switches on the door...yours probably have one and the actuating arm...metal tab on the switch is probably bent and need to be re-bent to sense door closure. Take apart the microwave and re-bent this switch tab...it's relatively easy to find and correct. The door switch might be bad too...won't cost much. 9 times out of 10 it's a bent switch bar.
Oct 31, 2013 | GE Profile Spacemaker Over-the-Range...
Microwave does not come on.....but when i hold up oven door a little it comes on.
Frigidaire microwave FMV156DSB. Turntable don't turn and no heat. Clock, keypad, light and fan works. The guys above looks like they right about either the door or the switches for the latch. This model does have two switches and a fusible switch. Pushing up a bit on the oven door from the bottom right corner when its closed make mine turn on if you set it to cook. Switches numbered 8(x2) on the schematic has part number 5304440026 $18.05. Fusible switch has part number 5303319559 $30.36. Have'nt changed them because it may be the door hinge is bent since the door latch is made out of plastic. Also looks like a real pain to take apart just to get to the switches. I will try to bend the door hinge to see if it fixes it. "And..now." -- Kirk, "Huh?" -- Scotty, "The doors, Mr. Scott." --Kirk, "Aye. I'm workin' on 'em."
Mar 11, 2011 | Frigidaire FMV156D Microwave Oven
My microwave turns on but doesnt produce heat
This happens because of a bad door switch . The plastic mounts inside the microwave which hold the door switches and onto which the door latches lock when you close the door .
Check also the turntable . It could be out of it's right place .
WARNING :
1:Don't slam your microwave door because this may cause the fuse to blow and this is the reason of bad door switch problem .
2: A microwave is capable of giving you a serious electrical shock even when it's unplugged , so I recommend you to call a repair technician for help .
please don't forget to rate .
good luck .
Apr 13, 2010 | Microwave Ovens
My microwave runs, but does not heat. Model 530ck
Hello :
WARNING :
PLEASE DON'T FORGET TO RATE !
good luck .
Apr 08, 2010 | Sharp R-1480 Microwave Oven
GE Spacemaker Microwave jvm1640cj
This is usually caused by either a bad door switch, a loose door switch mount, a misaligned door hinge, or occasionally a problem on the control panel.
Even though a door switch clicks, it may still be bad inside. Its continuity must be checked.
Door switch or mount trouble can be caused by slamming the door or by opening the door while it's cooking without hitting the Stop pad first.
There are plastic mounts inside the microwave which hold the door switches and onto which the door latches lock when you close the door.
The screws on these mounts may be loose. If they get too loose, the switches will not be activated properly.
Sometimes it's a broken tab on the switch holder, allowing the switch to rotate just out of position. This tab can be hard to see, since it is under the bottom edge of the switch.
One test that sometimes helps is to gently lift up (and/or push down) on the door or handle as you try to start it. If it works or tries to work, then it's a door switch mount or door alignment issue.
If you or someone you know decide to look into it, we have critical information on safety, disassembly and door switches at our site, and our link is at our listing here on FixYa:.
You can find helpful exploded view diagrams and order parts by entering your full model number here.
There may also be a "mini-manual" hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting & testing.
If you only need a switch, you can order one from us for $5 postpaid.
If you think the problem is on the control panel, we repair these nationwide by mail for $39.95 postpaid in most cases.
Sep 11, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
Viking microwave VMOS200 timer works but no microwave or turn table
This is usually caused by either a bad door switch, a loose door switch mount, or occasionally a problem on the control panel.
The square piece you mention is the waveguide cover and it will need to be replaced. It provides important protection for the magnetron.
To buy one, you can contact Viking here or call 1-888-845-4641.
Aug 21, 2008 | Microwave Ovens
Microwave oven comes on when the door is open, we then put what ever we are heating up and turn the oven on. After it times out and goes off the microwave oven turns on again when we open the door to...
It sounds like either a bad door switch or door switch mount, or a sticking relay on the control panel.
You can order Panasonic parts here.
Otherwise, I would recommend that you contact your nearest Panasonic-authorized servicer.
Aug 19, 2008 | Panasonic Microwave Ovens
Microwave Ovens Logo
53 people viewed this question
Top Frigidaire Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Frigidaire Microwave Oven Expert? Answer questions, earn points and help others
