Fahrenheat FUH5-4 Heater Logo
Posted on Dec 30, 2010
Looking for replacement fan motor - Fahrenheat FUH5-4 Heater
I am looking for a replacement electric motor for a CZ1200 Duracraft Fan heater
duracraft model cz 1200 Questions & Answers (with Pictures) - Fixya
www.fixya.com > Forum > Tags
Jan 3, 2010 - Duracraft CZ 600 oil filled fanned portable heater and has two switch on end for different watt ... It is white portable electric,but it has oil in it, do . ... looking for replacement parts for a Duracraft model s6436 sander I am looking for a ... I need replacement moter for Duracraft Model DS1600 fan can I get a replacement motor? Where can I find parts for a Duracraft window fan ...
Aug 16, 2010
Duracraft User Manual
Sep 24, 2009
duracraft fan parts Questions & Answers (with Pictures)
Sep 4, 2009
SOLVED: Can't get at the fan to clean
Apr 14, 2008
More results from www.fixya.com
Overheating, fan motor not running while engine is running. Need help in troubleshooting the control circuit.
Disconnect the ECT (engine coolant temperature) sensor with the key on, the fan should start in default and stay running, if it doesn't run check for voltage at the fan motor connector, if voltage is present and the connector is not burned looking or discolored replace the fan motor. If the fan has no power try jumping the relay socket to power up the fan motor circuit, if that works replace the fan motor relay under the hood. You gave no make, model or year and engine type so that is about all I can help.
Need fan motor for model 2E440
Try Grainger
dayton 2e440 heater Questions & Answers - Fixya
... a Dayton Model 2YU40 electric heater Need manual for Dayton. ... looking for a replacement fan and fan motor for a Dayton model 2E454B electric wall heater.
Dayton rheostat fan motor Heaters Questions & Answers ...
www.fixya.com > Forum > Tags > rheostat fan motor > Heaters
Dayton heaters rheostat fan motor related questions and answers. ... UP BUT FAN WONT KICK ON Could be one of several problems dependant on the model you have.... The motors are noisy in 2 Dayton 2e440 heaters. I ... I'm looking for a replacement fan and fan motor for a Dayton model 2E454B electric wall heater.
DAYTON Electric Wall Heater, Recessed or Surface ...
www.grainger.com/.../DAYTON-Electric-Wall-Heater-3...
W. W. GraingerShop DAYTON Electric Wall Heater, Recessed or Surface, Voltage 208/240, Watts ...Item # 3UG56; Mfr. Model # 3UG56; UNSPSC # 40101814; Catalog Page # 4277; Shipping Weight 20.65 lbs. ... Additional features include a built-in thermal cutout andfan delay switch for added safety ... Need Help Finding Repair Parts?
Ac compressor fan running backwards.
Fan motors have rotations, clockwise and counter clockwise, lead end and opposite lead end. If you are looking at the motor from the fan blade side and the wires are on the back (opposite) side of the motor then you are looking at opposite lead end. Then you need to determine the rotation of the blade. It will scoop the air, so turning the blade that direction will give you the rotation. They also sell motors that you can change rotation by changing certain wires they have added.
When you replace a motor you need to notice the rotation and order that rotation. which end of the motor you are looking at to determine it. Then order the same rotation when buying the new one.
4helpful
2answers
Out of the blue, my Carrier 38tkb fan is not working; we hear a humming sound inside the outside unit; the unit is 7-yrs old and had no issues so far; any idea where we could find a service manual...
Hello, if the compressor is running then it is either a bad capacitor or bad fan motor, an easy way. To check is try to spin the fan blade with a thin object, if this gets the motor going the capacitor is bad if not the motor is shot.
3answers
Fan won't start. I turn my thermostat down and the compressor kicks on, but the fan won't start and immediately get's hot. Is the fan motor burnt up, or is there another problem I should look for?
Hello my name is Heath it will be my pleasure to assist you. The first thing to do is check the capacitor for the fan look at it and see if it is swollen or pitted. If the capacitor is okay then the fan motor may have gone bad.
4helpful
2answers
Where do i find a replacement motor for my patton model u-2-1887 fan? 120v/60hz/270w/2.6 amps. or where would i get the motor rebuilt?
Before you replace it, try oiling it -- look at the little oil hole on the back of the motor housing. Or try taking it apart and cleaning it, then oiling.
Did it work before, but gradually slowed down and then refused to start? See other threads on this topic for that fan model.
Fan does not run
You have a bad fan motor and it needs replacment(outdoor fan),sometimes though you can replace the capacitor(if it looks bloated or malformed).good luck--Nate
2helpful
2answers
1helpful
2answers
Condensor fan motor inop - fuse good but replaced anyway - replaced relay. put 12 volts to motor and it worked. what activates the relay to send power to the motor ????
Either radiator fan switch or AC system fan activate relay. Check fan switch or look for AC fan motor fuse. Wiring diagram would help.
Top Fahrenheat Heating & Cooling Experts
Paul Carew
Paul Katynski
Paul Katynski
Are you a Fahrenheat Heating and Cooling Expert? Answer questions, earn points and help others
