Question about Waterway Spa Pump Executive 56 Frame 4hp Dual Speed 2" Intake 2" Discharge
How do you take this pump apart so you can replace a bearing? Model# PF-40-2N22C
    Problem Solver:
  • 9 Answers
I just did this.
Take the screws off the outer cover fo the wet end. That will expose the impeller.
At the other end of the pump is a small metal cap in the middle. Pry that off with a screwdriver. That reveals the shaft of the motor which has a slot in it. This allows you to hold the shaft still with a large screwdriver.
While someone holds the shaft with a big screwdriver, you rotate the impeller counter clockwise to unscrew it off the motor shaft.
In my case the impeller was so caked onto the shaft with rust that we could not loosen it. We broke the impeller and still could not unscrew it. The screwdriver keeps jumping out of the slot in the shaft.
So the next step was to take the shaft out of the motor. On the far end of the motor are 4 small looking bolt heads. Undo those. They go right through the motor into the 4 legs of the wet end.
Stand the motor up with the wet end up. Pull hard to pull the wet end motor cover off the motor and you will then have the wet end and armature of the motor in your hands. Heavy.
Place some wood into a large vice and then grip the big silver part of the armature in the vice. Then unscrew the impeller.
I got this far tonight and the bearing at the wet end is hard to turn and is the reason for the failure of the pump. I am not sure of the bearing can be pulled off without special equipment.
Posted on Jan 27, 2011
    Problem Solver:
  • 5 Answers
The picture is showing the pump and the motor. They should seperate with a coupler of some sort. If you find rust or not allways soak any screws or bolts or nuts with something like "blaster" or wd 40 overnight. "Be carefull not to get any into the motor". Once you have them seperate. Find out if it's pump or motor with a bearing problem and which end. You can hear where its comeing from a lot ease by taking a screwdriver and place the big end in your ear and the small end draging on the shaft or touching something close to it and then spin the shaft. This magnify the noise a bunch. Thats about all the info i can help with for now untill you get that far. But once you do. You will figure it out. jerry
Posted on Mar 25, 2013
  • jerry carmichael Mar 25, 2013
    Hey fixya, why send me an email about a question over 2 years old? What are yall a bunch of *****'s ?
How do I lubricate squeeking ball bearings
You dont, if the ball bearings are bad they need to be replaced, all pool motors ball bearings should be sealed. Taking apart the motor to get to them is a bit much for most people. First find the make and model of your motor how many ball ball bearings there are and find somebody that sells the ones you'll need. There's usually 2 and you'll have to take the front and the back of the motor apart to get to them and replace them. See attached what one looks like. Also if you do this yourself and take the motor from the pump its a good idea to replace the pump shaft seal as it usually leaks and easier to do while your putting it back, rather than after you put it back and it leaks.
Nov 21, 2015 | Pool & Spa
What is the flow rate (GPM) of an Executive 56 Waterway pump Model PF-50-2N22F?
Waterway Executive 56 Spa Pump, 5 HP, 230V
Waterway Executive 56 Frame spa pump wet end
assembled to a 56 frame, 5hp, 2-speed 230V spa motor
This Spa pump has a 2-1/2 inch intake and a 2 inch discharge for plumbing
(but measures 3-1/2 inch and 3 inch- see bottom of this page)Manufacturer Part No. 3722021-13 Other Part No. PF-50-2N22C
Features:
  • Executive spa pump wet end designed specifically for 56-frame spa motors
  • Two double shielded ball bearings with moisture resistant grease for quieter operation and longer life
  • Two speed spa motors have four sets of insulated windings for increased efficiency
  • 56 frame spa motor for added strength, cooler operating temperature and longer motor life
  • Large 2-1/2 inch intake for improved flow performance and reduced noise
  • Large 6-1/2" diameter wet end for higher head pressure
  • Split capacitor, (start and run) for less energy consumption
  • Thermally protected to extend life expectancy of hot tub motor
  • Highly versatile wet end can be rotated every 90 degrees
  • Viton seals
  • Three year manufacture's warranty on spa motor and spa pump wet end
Jun 05, 2015 | Waterway Garden
How to change a front bearing on sp 1540 c pump
you cannot they dont sell bearings get number of pump and motor you will have to replace the motor if you can get it make sure to get the seals
Aug 03, 2014 | Hayward Pool & Spa
Need to change seal on pf-40 waterway pump
can change but water leaking into motor it will start to squeal bad bearing just change whole pump
Dec 26, 2012 | Waterway 5HP Executive 56 Frame Spa Pump...
Hello, I am trying to replace the front bearing on
If you haven't got your answer yet, I can help you, but it seems very late to reply. I have a same model, I take apart it, I see 2 bearings, you probably need puller to get it out.
Jul 15, 2011 | AO Smith 1 hp 3450rpm 48Y Frame 230/460...
I have a Waterway Spa Pump Executive 56 Frame 4hp Dual Speed PF-40-2N22C in a Catalina spa that recently developed an issue. The pump will not start in low speed, just makes a humming noise, but it will...
the problem with the sound is the bearings inside the motor are going out. i have the same pump and i have to replace the motor. replacing the bearings is very hard and will cost you about the same after you carry the motor and new bearings to a shop to be pressed in. hope this helps!!
May 04, 2011 | Waterway Spa Pump Executive 56 Frame 4hp...
Haywood pump is making a high pitched noise
Inside the pump is a set of bearings that help the components of the motor run smoothly. When they become clogged with dirt and debris or wear down, your pool pump may get very noisy or stop working altogether. This high pitched squealing you are hearing is fairly consistent with bearing failure.
Replacing the bearings in your pool motor:
1. Turn off power to your pool pump by unplugging it from the power source or by turning off the circuit breaker. 2 Remove the plumbing from the pump. Take off the unions on the suction and discharge side using a wrench. Loosen the pool pump from the fitting holding it to the ground and move it to a comfortable area to work in. 3 Remove the housing from the pool pump and separate it from the motor. Look at the owner's manual for your pump to see the specifics on how to remove the pool pump housing, since each model is different. Usually you will need to loosen a bolt with a socket wrench and loosen the metal band that holds it in place. 4 Remove the four bolts that hold the pump together. These are located on the hand bell of the frame. Remove the motor end bells. 5 Pull out the motor armature to expose the ball bearings. Insert your ball bearing puller to pull out the old ball bearings. Inspect them for damage. Replace the old ball bearings with new ones after greasing them with bearing grease, and reassemble the pump.
To be honest with you, I don't even let our technicians replace the bearings in the field anymore. It is a little difficult and really, how many people have a "ball bearing puller" laying around their house.
It might be best to have the motor seperated from the pump housing and take it to your local pool outlet or motor shop. Installation of the bearings will be a breeze for them and make sure that no damage is done to the shaft of while the new bearings are being installed. Also, you should ALWAYS, ALWAYS, ALWAYS replace the shaft seal whenever you take the pool pump motor apart. This will ensure a positive seal for the motor and minimize the opportunity for leaks to occur.
Please note, this should ONLY be attempted if you are comfortable with the instructions and taking apart the pump, have the necessary parts and tools to make the repair, and are familiar with ensuring that everything is back together properly!
Please take a moment to let me know if this answered your problem or not! All of us here a Fix Ya do our best to help each person with their questions, and we know that we may not always be "perfect", but we do try!
The Ugly Pool Guy www.WeFixUglyPools.com
Dec 11, 2010 | Hayward Pool & Spa
Price pfister soap dispenser will not work
Replacement parts can be found on amazon. Click here Watkins Hand Soap Made Naturally Since 1868 and take a look. I hope this was helpful. Cheers
Dec 13, 2008 | Price Pfister Marielle Kitchen Faucet with...
Waterway Spa Pump Executive 56 Frame 4hp Dual Speed 2" Intake 2" Discharge  Logo
1,644 people viewed this question
Top Waterway Garden Experts
Ian Kime
Ian Kime
Mike Raino
Level 1 Expert
john h
Are you a Waterway Garden Expert? Answer questions, earn points and help others
