Question about York Yankees Bedding MLB Comforter
The water seems to circulate around the refrigeration system but the tank is at 38 degrees and the inlet water temp reads 0 degrees. the system says the suction pressure is low and shuts the both compressors down, no refrigeration can take place
  • 43,501 Answers
Without actually being able to get gauges on there to check it out.... I would say that you have a leak and that you have a system that is low on charge....
I would get a tech to get gauges on there and see exactly what is happening...
heatman101
Posted on Jan 02, 2011
My double door galaxy (5 year old or so) seems to be at the right temperatures but the control reads 56 degrees for the freezer and fridge
Get a thermometer for both fridge and freezer to ensure temps are correct. Freezer should be around 0F and fridge around 37-38. If temps are correct but display is reading that much differently, control is most likely bad.
Sep 08, 2017 | Galaxy Refrigerators
I have Kitchen Aid french door fridge with large temp fluctuation. Please help
Clean your coils first, if they are dirty from dog hair or lint in general it will overheat compressor and cause temps to fluctuate
Oct 17, 2016 | Refrigerators
What is the correct fridge temperature this fridge should be on?
If your refrigerator has 2 controls, the start setting is usually at mid point on both dials. That should give you a freezer temp close to 0 and a fresh food temp of 38 to 42 degrees. If only one control---same middle setting should produce about the same inside temps. Fresh food temp is best measures if you can put thermometer in a glass of water to stabilize the temp.
Apr 15, 2015 | Refrigerators
Freezer goes -9 and fridge goes to 40 I have set it to 0 for freezer and 34 for fridge it changes on its own
Depends on type of refrigerator freezer you have, but you need to realize that the evaporator (cooling coils) are in the freezer, and the cold air produced in the freezer is then circulated via an evaporator fan into the refrigerator section. The thermostat the cycles the compressor motor is located in the refrigerator, and the compressor will run until the temperature reaches the desired level in the refrigerator. On most units, the freezer temperature setting simply regulates how much cold air is circulated into the refrigerator.
What you are describing is that the freezer is working fine (almost too good), but the air is not properly getting to the refrigerator area. Several things can be causing restricted airflow, including a faulty evaporator fan, icing of the evaporator coils because of a malfunction in the automatic defrost system. Check to see if there is frost or ice build up in the back or bottom of the freezer. The proper temperatures should be around 0 F for the freezer and 38-40 degrees F for the refrigerator.
Feb 25, 2015 | Refrigerators
Recommend temp settings for Gallery
Hey friend, thanks for your post!
The recommend setting for your refrigerator is 0 degrees for your freezer and 37 degrees for your refrigerator. If your refrigerator has a water tank that holds the water prior to dispensing it then you would turn down your settings. I hope this is helpful. -Matt
Sep 22, 2014 | Frigidaire Refrigerators
Freezer is cold but food isn't frozen
Deforst freezer and ref. wipe dry. Reset controls to starting point.
Check temp. 0 in fez. 38-40 in ref. keep advancing settings until you reach temp. Also, vaccum behind unit
May 02, 2014 | Amana 22.6 cu. ft. Side-By-Side...
Fridge not cold enough
The higher the number the colder the temp is supposed to be.
In order to prevent the formation of bacteria and other such organisms to affect food the way it does, the ideal temperature range of refrigerators has been mentioned here. Before we look at these settings, it is important to know the format in which temperatures are represented within a refrigerator. Commonly, you will notice a dial representing the figures 1-5 or 1-9 in the refrigerator, and a dial representing the letters A-E in the freezer. The ideal setting is usually in the middle of such figures.
If the dial is in such a format in your refrigerator, try a setting at 3 if the range is 1-5, and at 4 if the range is 1-9. For the freezer, a setting at C is suitable.
The ideal temperature in the refrigerator ranges between 34 degrees F - 38 degrees F or 1 degrees C - 3 degrees C. So that foods such as vegetables and fruits remain fresh and crisp, the temperature may be set around 38 degrees F or 3 degrees C.
The ideal temperature in the freezer ranges around 0 degrees F (-18 degrees C) or lower.
Read more at Buzzle: http://www.buzzle.com/articles/refrigerator-temperature-settings.html
Mar 05, 2014 | Belling Refrigerators
What temp should frig be set for and what temp for freezer?
Nominal tempretures for freezer are 0 degrees and for a refrigerator are around 37-38. If you have any further questions message me back. Thanks Rick
Sep 10, 2011 | Bosch Refrigerators
Kenmore fridge and freezer not cooling
Check to see if there is any ice built up on the back wall of the freezer. If so thaw the ice and take the back wall out of the freezer. next check to see if the fan is running in the freezer (evaporator fan) This fan is what circulates the air from the freezer to the fridge. If it does run then you have a defrost problem (if ice is on the coils and back wall). Then replace defrost timer, heater, and thermostat.
Nov 19, 2008 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
York Yankees Bedding MLB Comforter Logo
27 people viewed this question
Top York Sport & Outdoor - Others Experts
Paul Carew
Shehu Pro
Shehu Pro
ray gallant
Are you a York Sport and Outdoor - Other Expert? Answer questions, earn points and help others
