Question about Olympia Startype 3 Typewriter
How do you insert correction ribbon and print cartridge
  • Olympia Master
  • 3,594 Answers
Go to NADIST.COM, click on current molels, find the Nahajima that id the same as your T/W.
Nakajima made yours.
HAPPY NEW YEAR
DickyO
Posted on Dec 31, 2010
Install lift off tape cartridge
Remove the ribbon by pushing the blue lever to the right and front of the ribbon. The correction tape cartridge is attached to the bottom
of the Printing ribbon. Depress the center of Printing ribbon to release the correction ribbon. Snap on a new one.
Nov 04, 2013 | IBM Personal Wheelwriter 2
My zebra id card printer p120i does not print very sharp
zebra p120i TROUBLESHOOTING LINK
Printing shows blurry printed image.
Possible Cause:
•Ribbon cartridge may not be correctly positioned.
Solution:
•Check that the ribbon is properly rolled onto the ribbon cores of the cartridge, with no wrinkles.
•Replace ribbon cartridge, making sure it locks in place, and print again.
Possible Cause:
•Ribbon may not be synchronized on the correct color panel position.
Solution:
•Open lid, then close lid to synchronize ribbon.
Possible Cause:
•Cards may not meet specifications.
Solution:
•Use a different supply of cards.
Possible Cause:
•Dust or embedded contamination inside the printer and/or dirty Cleaning Roller.
Solution:
•Clean the Print Head.
•Replace Cleaning Roller
Jan 30, 2011 | Zebra P120i Thermal Card Printer
The ink cartridge will not eject. It's stuck inside the printer.
Canon Selphy CP800. I had a cartridge ribbon break when it stuck to some photo paper I was trying to reuse and the cartridge became stuck and would not release. All you have to do is try to print a dummy print, the printer will then display that the ink cartridge needs replacing, it will then allow the cartridge to pop out when the release catch is operated. Beware of broken and torn ribbon inside the printer and try to remove the obvious loose pieces before inserting the new cartridge. Any remaining bits of ribbon should stick to the next photo you try to print but a ruined photo is a small price to pay as your printer should work ok once the debris is cleared. If you are adventurous you can dismantle the cartridge by inserting a small flat screwdriver into the retaining clips at each end of the cartridge cover. remove the used ribbon from the spool as it is only stuck onto the spool spindle. Re thread the unused ribbon onto the spool ensuring it travels round the deflecting spindle which is easily prised out and replaced over the ribbon. You must ensure that the new ribbon is wound onto the spool in the correct direction (check this by comparing the rotation with good cartridge by ensuring the ribbon tightens as it should) then wind the ribbon forward until the black line appears on the clear sheet of ribbon and carry on printing.
Dec 19, 2010 | Canon Selphy CP510 Thermal Photo Printer
Datacard sp55 printer won't recognize ribbon
PR-01726 Ribbon Out
Out of print ribbon.
Possible Cause 1 : The print ribbon Cartridge is empty.
Solution 1 : Reload the print cartridge. Change the cleaning sleeve and replace the cartridge in the printer. Run a cleaning card as soon as printing is completed.
Possible Cause 2 : The printer ribbon is not loaded correctly.
Soultion 2 :Load the printer ribbon correctly and then close the cover.
Possible Cause 3 : This ribbon has been completely used.
Solution 3 : Use a new roll of ribbon.
Tips for Success
* When this message appears, replace the old ribbon with the new ribbon of the same type. The printer has already prepared the card data for this ribbon type. You can change the colors of monochrome ribbon (such as from dark blue to gold).
* If you must change the type of ribbon (such as (YMCKT to KT) when this message appears, install the new ribbon, cancel any cards waiting to print, and change the ribbon type settings. Finally, return to the card creation program to send the card data to print.
* If the ribbon was repaired, the wrong take-up spool was used. Repair the ribbon again, using the correct take-up spool.
If you cannot fix the problem contact your service provider for assistance.
FTB
Nov 23, 2009 | Datacard Group SP55 Card Printer
I can't get the ribbon cartridge in the down position to type.
It seems to me that your cartridge is not sitting correctly. If you are using an OEM ribbon, then it may well just be that you have not correctly inserted the casing. In that case, I suggest you try again.
If you are using a COMPATIBLE ribbon, then it is most likely due to wrong design of the casing. Unfortunately, some compatible ribbons in the marketplace do come with lugs, even though they look very similar to the correct cartridges. If you require further advice or would like to replace your ribbons, i suggest you contact www.inkribbonpaper.co.uk.
Sep 22, 2009 | Brother ML-100 Typewriter
Put new ribbon cartridge in ibm wheelwriter 3 not printing now
If the ribbon is lifting up you probably have a cracked print solenoid plunger cap. They are available but a little tricky to install.
DickyO
Feb 10, 2009 | IBM Wheelwriter 30 Typewriter
Hpc4100 printer error message 'Remove and check cartridge on right"' Refer to printer documentation
3 causes
1 faulty cartridge
2 dirty contacts
3 print carriage ribbon damaged
Rmove cartridge and rub the golden contacts at the back of the cartridge with a slightly damp (not wet) tissue. Re insert and turn printer off and on again
If this doen't work check the white ribbon inside the printer cartridge carriage in the printer (which touches the golden contacts on the back of the cartridge when it is inserted) for damage - it might have a pinhole in it where the metal pin holding the cartridge in place has pushed back through the white ribbon
If there is no damage and rubbing the cartridge contacts has not worked then most likely it is a faulty cartridge
Let me know how you get on
Nov 11, 2008 | HP PSC 1210 All-In-One InkJet Printer
Why doesn't my typewriter type when I'm typing
I had this problem once with another brand. One mode actually waits for you to complete an entire line of type before printing it onto the page allowing you to make error corrections without wasting alot of "correction tape". Change the mode back to typing on the fly.
Mar 14, 2008 | Brother SX-4000 Typewriter
IBM quietwriter 7 - autocorrect problem
Do you have a lift off tap snapped onto the bottom of the ribbon
Nov 07, 2007 | Lexmark Wheelwriter 1000 Typewriter
Printer error, only prints one color
Did any of the ribbon come away, or tear when it broke, i have heard of small pieces lodging in the carriage or feeder. Check this very thoroughly as blockages can be very tiny. Check you correctly inserted the ribbon too, and it is the correct type of ribbon for your unit. (sounds silly but sometimes it ccan be that simple) try reinstalling printer, is the ribbon cartridge faulty? check it.
Aug 10, 2007 | Olympus P 400 Thermal Printer
Olympia Startype 3 Typewriter Logo
26 people viewed this question
Top Olympia Office Equipment & Supplies Experts
James Cagle
James Cagle
Daniel Thibodeau
Level 1 Expert
Jim Keysor
Are you an Olympia Office Equipment and Supply Expert? Answer questions, earn points and help others
