Question about Motorola Mobility E815
This is my 5th E815 Motorola phone. I love the phone. Problem is that I've (and many other people it seems) have had the same problem, and I've have had it eventually on every E815 I've owned. All of a sudden you ca't make outgoing calls. I've tried resetting the phone, going to home network and back to "B". It seems that the only way to get it to work once in a while is to turn it off and on again, and then it'll work one time only. If you search the internet for: "Can't make or receive calls" you'll see a load of people have the same problem. Can't see where anyone ever found a solution. Can you help?
  • robs1951 Dec 31, 2010
    how do enter the code?
    President:
  • 1,932 Answers
This is a software issue.
If your phone freezes,cannot make outgoing calls, hangs up unexpectedly, vibrates continuously ,touch screen wont respond or in other similar ways doesn't perform as it should, this can often be solved by performing a software update. Software may perform incorrectly for many reasons without there being a fault in the phone. Some problems may be fixed by re-updating your current software, while others may require installing a new software version.
To keep your phone performing at its best, it's a good idea to perform a software update regularly. You might not always notice what an update has done, but it can prevent future problems.
To update or reinstall the software please go to nearest authorized service centre of your mobile make and they will update or reinstall the software as required.
Note: Reinstalling the software will delete all the content in your phone like contacts, calendar entry etc.
Thank You
Posted on Jan 01, 2011
    Genius:
  • 1,416 Answers
Here is the solution to solve the problem of the phone first of all put of the phone for some time allow the phone to relax it self if possible remove the battery of the phone after some time return the battery and then put on the phone allow it to search for next work it self set up the time and date if you have remove the battery as recommended after all these then apply the below code to cancel all form of call diversion affecting your calls ##002# then ##21#. then send.
Note :the above recommendation should be use one after the other
Good luck and thanks for using fixya.
Posted on Dec 31, 2010
I have a Motorola E815 Alltel cell phone and was wondering if I could somehow make this phone compatible with Verizon since they are my current carrier? How do I switch this Alltel E815 to Verizon?
Hi Dawn Lynn Martens,
You can take the device to Verizon to see if they can activate it with their frequency. Since they handle CDMA devices as the Motorola E815.
Best Regards,
Katya
Motorola Support
Aug 16, 2015 | Motorola Mobility e815 for Verizon /...
I have a Motorola E815 phone. The screen looks scrambled.
take out the sim card and format or restore to fabrik settings
May 16, 2010 | Motorola Mobility E815
Even numbers do not work on keypad of Motorola E815
The keypad seems to be broken then, had the same problem on my Nokia 6230, some keys didnt work. I'd suggest you to take it to repair.
Aug 09, 2009 | Motorola Mobility E815
Transfer my contacts from my Motorola e815
yes you can with the help of a usb data cable and motorola tools software, which you can download from motorola official website.
Jan 01, 2009 | Motorola Mobility E815
Motorola E815 phone number reset
J'AI UN MOTOROLA E815 ET J'AI OUBLIé MON LOCK CODE C'ETAIT PAS AVEC LES 4 DERNIERS CHIFFRE....AIDE MOI A RESET MON PORTABLE
Aug 30, 2008 | Motorola Mobility E815
Motorola E815
Leave it on charger on a while. And then turn on.
If no luck try to open and clean it inside.
If than is not enough phone have not contact with power.
That is usually for old phones just don't turning on.
Jul 24, 2008 | Motorola Mobility E815
Motorola e815
There is an article about someone who's screen went black. Click here
Apr 25, 2008 | Motorola Mobility E815
They can't hear me.
hi there
is there by any chance the mouthpiece speaker may need replacement? if you use bluetooth headset, it would be fine. but without bluetooth, they cant hear you.
i suggest you look for a replacement mouthpiece speaker for that to work.
hope this helps.
fixya!
Feb 04, 2008 | Motorola Mobility E815
Motorola E815 flashed to Cricket
you need to get that charging port repaired. www.fixphonenow.com can replace the charging port with a new on for $55.
Dec 06, 2007 | Motorola Mobility E815
Motorola E815 Display Screen Blank
Flex cable connected to the main board tend to get loose. You need cell technician to fix that problem.
Oct 22, 2007 | Motorola Mobility E815
Motorola Mobility E815 Logo
Top Motorola Mobility Cell Phones Experts
Rami Obeid
Level 1 Expert
D. E. Hev
Lawrence Oravetz
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
