Question about Kenmore Washing Machines
I just need someone to explain to me if I should add clorox bleach. and clorox ll in the same area, but not at the same time. I don't understand if you should add them into the same area it seems as though your color clothes will have bleach on them Please help me before I distroy all of my colored clothes. Thanks
  • bobby818 Dec 30, 2010
    ok, I know the difference between the two. I just need to know if I put both in same dispenser.
    Should I put the safe color bleach in with the laundry detergent?
  • 56 Answers
When you add bleach to the beach dispenser, it goes directly into the water in the outer tub, where it dilutes, before coming into contact with your clothing. I'm no chemist, but I think the difference between the regular bleach and the "color safe" bleach is either a chemical additive, or just a special dilution.
If it's the latter, mixing the two will add too much chlorine, and "bleach stain" your colors. Follw the directions on the bottles, and also the user guide that came with your machine, if you still have it.
Posted on Dec 30, 2010
  • Stanley Runyon Dec 31, 2010
    It's OK to add bleach at the same time you add detergent. Just make sure the bleach is diluted in the water before adding the clothes.
IS MY DELL LAP TOP BE FIXED IF SOMEONE POORED 1/2 GAL CLOROX BLUCH ON THE KEY BOARD?
I am sure half of gallon of bleach is alot of fluid.
You will have to open up the laptop and inspect it. I advised to take it to a trained technician.
Jun 07, 2014 | Dell Inspiron Computers & Internet
Dirty filtered water
the filter in your jug probably uses charcoal as a filter medium. IT removes taste- heavy metals - chlorine -fluoride .the first application is the loose charcoal being flushed from the filter and you have no need to worry as charcoal is necessary in the body (carbon) and it will not harm you. Just empty the jug and refill until you get clean water.
Jun 02, 2013 | Sunbeam Cars & Trucks
My soap tray is moldy, how do I clean it up?
pour some clorox or liquid bleach into it. Also run a wash of rags with clorox and vinegar a time or two and odors should clear up.
Oct 08, 2010 | Maytag Neptune MAH5500B Front Load Washer
RUBBER LINER COLLECTING MOLD
I have been struggling with the same issue for a long time. Regular bleach and mold-killing products did not work. But I just tried Clorox "Washing Machine Cleaner" and was amazed. I scraped off the loose mold from the rubber gasket and then painted on the product, which is thicker than bleach. After about 20 min. I scrubbed it down with water and painted a second coat on the tough areas. No more mold. I also ran some through the machine per the instructions for good measure and ran another rinse cycle. I am in no way connected to Clorox, but I am so happy to be rid of this problem. Good luck. <!-- from fixya rte -->
Jul 26, 2010 | Maytag Neptune MAH5500B Front Load Washer
Gunky slim in rubber gasket on front door. terrible odor also
that is mold bleach water hand wash rinse with water . afresh cleaner several times then monthly
Feb 03, 2010 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
Musty smell in drum of washer
Run a short cycle with nothing except Clorox and water. This will kill the mold growing in the machine. When not in use, keep the lid open.
May 03, 2009 | GE WSXH208A Front Load Washer
Dont' know where to add bleach alternative
yes clorox 2 or "dry type" bleach should be put in with the detergent. only liquid bleach will go into the bleach dispenser.
also be sure to use soap that is "HE" type or you will get too many suds and a washer that will smell from not rinsing out.
Mar 29, 2009 | Whirlpool Cabrio WTW6600SBT Top Load...
Have a ge ac in window unit asto5 model leaks inside just recently . connot find any plug to pull for draining outside excess water inside ac cabnit . does it have one? been running this ac all summer and...
No drain plug but this model should have a SLINGER RING AROUND the end of the fan blades which picks up the water & sling it on the back coil which it is so hot & evaporates to help get rid of excess water .. So as for the water running inside, the drain channel are plugging up, from the front coil to the back, & only need to add clorox bleach to the front coil area for now , to kill the slime or mold slowly blocking the channels..But first, TURN_OFF UNIT! (certain times of the year, mold & slime grows rapidily and thats what the bleach for..!
Sep 05, 2008 | GE Heating & Cooling
Disgusting odor
I had the same problem, except it wasn't just towels. It was everything. I did some research and found that this is a common problem and nothing a tech can fix. I was about to go out this weekend and spend $1000 on a new washer because I couldn't use this washer on my clothes anymore. I did one more search for a solution and THANK GOODNESS found a solution on another site. A woman had the same problem and, after much trouble, someone at Best Buy finally told her to never use liquid detergent in the machine, not even HE. So I cleaned the inside of my machine, around the door, the rubber seal, etc. I ran the tub clean cycle with bleach and vinegar. The smell was gone and I have been using powder Tide ever since, and the smell hasn't come back!!!!!
Mar 12, 2008 | LG WM2688H Front Load Washer
Washing Machines Logo
196 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
