Question about Bissell Vacuums
The brush bar will not spin. The belts melt when I turn it on and the belt drive is hot to touch with smoke coming out.
    President:
  • 1,486 Answers
The belt is rubbing the foot plate.Check to see if the foot plate is damaged.Allso check the bearings in the brush bar are free and spin without the belt on.If you cant spin the brush bar by hand with the belt not attached then your bearings are seized.Get a new brush bar
Posted on Dec 30, 2010
Dyson DC25 brush won't spin when touching the floor. If I lift it off the floor it spins, once it touches the floor it stops. Any idea what the problem is?
I can think of three things that could be wrong.
The easiest one is that the brush has hair and fluff wrapped around its bearing. This happened to me and was causing a burning rubber smell. Turn it over and remove the base plate. Lift the belt by putting a piece of cord under it and slide the brush out. Remove one end of the brush and slide the spindle out. Clean all the hair out and reassemble.
The internal drive belt is worn, or the nylon bush that it runs on.
The clutch is worn out.
The last two are not as easy to fix as the main drive belt is enclosed in the centre of the clutch. There are videos though that show you the process. Have a read and a watch, but try my first tip first.
  • Dyson DC25, DC29 - Resetting the brush bar (Official Dyson ... www.youtube.com/watch?v=q--faamcC7g
    • BY ASKDYSON
    • 1 MIN
    • 127K VIEWS
    2011-09-29 · Want to watch this again later? Sign in to add this video to a playlist. How to clear and reset the brush bar of your Dyson DC25 or DC29 upright ...
  • Dyson DC25 Upright Vacuum Cleaner - Support ' Dyson.com www.dyson.com/Support/dc25/DC25-ANIMAL Dyson DC25 Upright Vacuum Cleaner Support. Skip to main content X. Shop. Shop vacuums; Shop air treatment ... The Dyson Helpline is available during the following ...
  • My dyson vacuum cleaner brush will not spin. It is not the ... howtomendit.com > ... > Household Appliances, Vacuum Cleaners My dyson vacuum cleaner brush will not spin. It is not the belt. ... How can I fix my dyson dc25? The turbo button is not working... Click here for the answer:
  • Brush bar not rotating - Dyson www.dyson.co.uk/.../brush-bar-not-rotating Brush bar not rotating. ... to ensure vacuums containing Dyson Cinetic™ science maintain constant suction. ... tested at the cleaner head.
  • The Brush Won't Spin on My Dyson Vacuum Cleaner ' eHow www.ehow.com > Home > Home Appliances > Other Home Appliances 2015-06-29 · eHow; Home; Home Appliances; Other Home Appliances; ... My Dyson Vacuum Cleaner's Beater Brush Won't Spin; Dyson Vacuum Brush Roll Not... My Dyson ...
  • Dyson DC25 brush won't spin when touching the floor. If I ... www.fixya.com > Forum > Vacuums > Dyson 2016-03-18 · Dyson DC25 brush won't spin when touching the floor. If I lift it off the floor it spins, once it touches the floor it stops. Any idea what the problem is?
  • Dc25 animal. front brush not working - Fixya www.fixya.com > ... > Dyson > DC25 Animal Bagless Upright Vacuum 2012-03-29 · ... Dyson DC25 Animal Bagless ... dc25 animal. front brush not ... I have a Dyson DC-25 animal. My brush bar did not spin and has been replaced with a ...
  • Dyson DC24 Brush Bar Motor - Dyson Medic - Dyson Medic dysonmedic.co.uk/dyson-dc24-brush-bar-motor It will not spin when the ... Dyson DC24 Brush Bar ... Unit Motor Dyson DC25 Dyson DC25 beater bar Dyson DC25 brush bar Dyson DC41 Dyson DC50 Dyson Motor Dyson ...
  • DC25 brush bar not working - Dyson Spare Parts with Free ... manchestervacs.co.uk/DysonForum/index.php?topic=738.0 DC25 brush bar not working ... My brush bar stopped working on my DC25 ball the other day. ... Manchester Vacs Dyson Engineer
  • Dyson DC24 - Resetting the brush bar (Official Dyson video ... www.youtube.com/watch?v=akGLQ7UbctY
    • BY ASKDYSON
    • 2 MIN
    • 275K VIEWS
    2011-09-29 · How to clear and reset the brush bar of your Dyson DC24 upright vacuum cleaner. DC24's brush bar is engineered to shut off for protection if ...
  • Mar 18, 2016 | Dyson Vacuums
    Tip
    Vacuum Brush Bar Not Spinning
    " My vacuum brush is not spinning". OR
    " My vacuum brush is spinning but not picking up".
    " My dirt sensor doesn't work, continually blinks".
    These three things are very common in vacuum cleaners and they are nothing serious. There is a rubber belt that drives the Brush Bar.You simply need to replace the belt.
    * If the Brush Bar is not spinning, then you know that the belt is broken.
    * If the Brush Bar is spinning but not picking up anything, then the belt is stretched to the point where it is now spinning on the Brush Bar. When this is the case, you may smell the belt burning and you may even see a little smoke.
    * And, if the you have a dirt sensor on you vacuum and it continually blinks, this is due to a bad belt as well.
    Whatever the case, the belt must be replaced. Belts are very easy to replace. In most vacuums, you turn the vacuum over and pop off the bottom to access the belt. In some other vacuums, there will be a little door/cover that pops off on the top side of the vacuum; allowing access that way.
    You can pick a belt up at your large department stores or Do-It-Yourself Centers. These stores usually only carry specific brands, depending on each store you search. You may want to call around first. The belts are very reasonably priced for the most part.
    Or, if you would rather shop on line, here is a link to belts. Just look up the Make and Model # of your vacuum and order.
    govacuum.com/Categories/173-Belts.aspx
    Good Luck!
    If you should have any questions about "Drywall Finishing/Patching", or know someone who does, put your questions to Category:"Tools- Building & Power- HAND TOOLS" at FixYa.com
    I will do my best to answer your questions about drywall finishing. However, it would be best if we could speak on the PHONE or do a live CHAT. I can answer any question you have if it involves getting a wall ready for paint!
    Thanks for looking,
    Jim
    Key Words: Vacuum, Hose, Canister, Belt, Brush, Beater Bar, Smoke, No Suction, Not Picking Up & Spinning
    on Oct 07, 2010 | Vacuums
    I have a bissell powerforce bagless.that is melting belts. i've cleaned the brush bar and put a new belt on only to have the new one melted again. i don't know what could possibly be wrong with it.
    Make sure all the pulleys the belt attaches to are spinning properly, if one is stuck or not spinning fast enough that will easily generate enough friction to melt the belt each time you replace it. Might need to replace other parts, or clean out more than just the brushes.
    Jun 15, 2011 | Vacuums
    The little belt inside the head of the vaccum with the beater bar is not always spinning therefor is melting. Is it normal for the metal pin that it is going around on to get really hot?
    The Belt should be changed at this point. This will allow for the proper tension to be on the brush between the motor assembly (metal pin) and the brush so that it spins at the proper speed.
    Is it "normal" for the metal pin (motor shaft) to get hot.... not normal, however in the problem you have described, yes it is normal for this situation.
    Change the belt and your problem should go away.
    Nov 05, 2010 | Filter Queen Majestic Canister Vacuum
    How to fix a vacume that is smoking
    any electrical unit that smokes,is ,not worth repairing
    Jul 01, 2010 | Eureka 2961AVZ Bagless Upright Vacuum
    The drive belt doesn't turn.
    The drive belt may have just melted a notch into the rubber on the motor piston.
    With the cover off, are you able to move the brushes by hand? When the brush bar turns, does the drive belt move too? If so, move it for a full rotation of the belt (make a mark with a Sharpie and move it until you see your mark again)
    If there's a melted notch or "Dent" in the belt, you'll need to replace it
    Apr 19, 2010 | Dyson DC14 Animal Bagless Upright Cyclonic...
    My machine ran over some string,made a funny noise and emitted some smoke,the hand suction pipe at the rear works perfectly, the motor runs fine,but the front of the vacuum will not work.thankyou very...
    the string bound up the beater bar (brush), keeps the belt stationary, and the motor spindle is just rubbing against the belt and melting it. remove the belt guard, remove the brush, and the belt. clean off the brush bearings (at the ends of the brush) of the string and make sure the ends spin freely from the brush. replace the belt with a new one, and put it all back together.
    Aug 17, 2009 | Panasonic Vacuums
    Vacuum belts smokes and needs to be replaced 3x's in 6 months is tis normal or did I get a lemon
    brush roller berings may be faulty making the brush stick and motor shaft spins against belt causing melting. remove brush roller, clean out end berings and see if ends spin freely or if they stick. if they stick, you might need to replace brush roller.
    Jul 30, 2009 | Eureka Altima Upright Vacuum Model 2996AVS...
    M1300 i dirt devil brushes wont roll
    Ok I would say the belt burnt into if you can turn it on and the motor runs it is the belt . I would pull it apart and replace the belt.
    Feb 25, 2009 | Dirt Devil M130000 ''i'' Dual Cyclonic...
    Vacuums Logo
    212 people viewed this question
    Top Bissell Vacuums Experts
    Jim Thurston
    Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
