Hi experts, How do you put together a bell antenna that has two lnbf's? The two lnbf's also have 82 degrees and 91 respectively, in what position would their placements be? Thank-you for your help regarding this matter. Regards; Patrick Riess.
  • 8 Answers
SOURCE: Technics SL-DV250 Ribbon Cable
Hi Alan,
I ordered the cable directly from Panasonic Parts Centre but had to go to a Service Centre to get them to order the connector as it is classified as an internal part. The reasoning in this is as it is an internal part and I maybe opening the system to use it they are not allowed to sell it to me as I might electrocute myself in the process and all my family would want to take Panasonic to court for compensation.
The job itself is simple but very very tedious and time consuming. It is best to do a little bit at a time as it is less stressfull this way.The ribbon cable about £4.50 and part number REX0967. The connector you will have to show them at the service centre and they will order for you and the cost is approx £7.00. If you send me your email address I will send you all the photos I took and parts address details
regards
Topgunner
Posted on Oct 01, 2008
danforddan1
  • 192 Answers
SOURCE: I want a Manual for a NEC DVD-VHS Recorder, Model No.NDT-41
Go the co.;s web site go to product support. find you model and then download a manual for free. pdif file use Adobe to read. that's it DFD
Posted on Apr 11, 2009
SOURCE: packard Bell Easynote E4 - Wireless Switch
i've been having the exact same yrouble with my Easynote E4 laptop and have just fixed it.
in the bottom left hand corner of the keyboard theres a key with Fn written in blue, hold this down and press F1it should beep and the 'wireless lan connection indicator' in your system tray the red cross will disipear then you will pick up wireless!
Posted on Apr 26, 2009
  • 120 Answers
SOURCE: hello, do you have a manual for Chicco Smart
http://www.chiccousa.com/Files/pdf/product-manuals/SmartSupportInstructions0_00.pdf
Posted on Oct 15, 2009
  • 245 Answers
SOURCE: hi where is the jumper to
Hi
There are no jumpers to set on a SATA drive since they all use individual interfaces with the motherboard.
All you can do is connect the drive you want as master to the first SATA header,slave to the second,and then set the boot priority in BIOS.
They don't have jumper pins like the old days.
Post again if you have questions,and if this helps would you rate my post?
Bob
Posted on Aug 22, 2010
What is the missing number to get a mean of 79.5? 82,71,83,91,78?
If the sixth number is 72 then the mean of the six numbers will be 79.5
Feb 18, 2015 | The Learning Company Achieve! Math &...
Tv programs freeze up numerous times during day. have to unplug, retart each time. what can be done? I HAVE VIP 222K MODEL.
There is an installation problem, and you need a technician. When the receiver reboots, it sends a boost of power to the LNBF until it gets a signal in return, or gets a response of no signal. If you have damaged lines, a damaged receiver, damaged LNBF, or low signal reception on your antenna, a rebooted receiver will, for a very short time, boost the signal enough to get reception. Then, the receiver will drop the power back to the correct levels, thereby eliminating the short term reception boost. A technician can repair your installation to improve the reception, as long as there is Line Of Sight to the correct satellites.
Oct 16, 2014 | DISH Network Televison & Video
My 82 750 Nighthawk and the headlight does not work before and after it starts
First, test for voltage at the plug that attaches to the headlight, if you have voltage at each terminal when set to it's respective hi or low position it could only be your headlight. If you don't have voltage then you need to work back from the wire to the switch and etc etc
Apr 19, 2014 | 1993 Honda CB 750 Nighthawk
Put together
You may be able to get Unique Imports to supply assembly information although that should have been provided with the antenna.
Nov 22, 2013 | Unique Imports Amplified Outdoor Remote...
Power supply repair
you must two optios: 1) repair the power supply box, you must be expert in electronic and have the respective diagram 2) replace the complete board, can be cost aprox us$20? aprox in USA.
in my country is us$30,00
God bless you
Jul 28, 2013 | Packard Bell Computers & Internet
1998 gmc surburban. front blows 82 degrees, rear blows 48 degrees. ambient is 91 degrees. this is with max-recirc-full tilt.the valve for the heater core does not change position no matter where i put the...
Hi John,
Your right with your diagnostics, you have a blend door problem. If your switching to cool air and it is still hot then you also have a heat exchange unit fault, this is the component that changes the water flow from hot to cool by shutting off. If it is not operating correctly this will give you constant hot air no matter where you temperature switch is positioned.
As for the warm air while the engine is cold, sounds like the blend door is still open to atmosphere tempreture and if it is hot outside will pull that hot air into the inside of the vehicle.
Have the heat exchange valve checked, and the only way the check blend door operation is to remove the wiring from the blend doors and have the circuit tested. If the circuit is ok then the blend doors will need to be replaced.
Hope this helps
Jul 24, 2011 | 1998 GMC Suburban
How many thermoststs does the nissan nomad have
1 this being the specifications on it
Features & Benefits Quality Controlled Factory Calibration Assures Accuracy Of Opening & Closing, Regardless Of Pressure Changes. Positive Piston Heat Motor Provides Accurate Temperature Control. Sturdy Metal Construction Throughout. Attributes Depth from Flange : .82"
Design : Offset
Flange Diameter : 2.125"
Height from Flange : .91"
Jiggle Pin : Yes
Temperature Range : 195 Deg
Warranty Limited Lifetime-See Manufacturers Written Policy
Warranty PDF
Material Safety Data Sheet (MSDS) There is no MSDS for this item Application Information: 1990 Nissan Van Engines : 2.4 L 2389 CC L4 SOHC
Comments: 195 Degrees;Alternate Temperature
Per Car Qty: 1
Design : Offset
Jiggle Pin : Yes
Warranty PDF
Per Car Qty: 1
Design : Offset
Jiggle Pin : Yes
Warranty PDF
Per Car Qty: 1
Design : Offset
Jiggle Pin : Yes
Design : Offset
Jiggle Pin : Yes
Design : Offset
Jiggle Pin : Yes
Feb 27, 2011 | 1990 Nissan Minivan
With the bell dish we have the oblong dish can get 100% signal for satelite 91 and 100% on satelite 82 but not both at the same time?
Guest 10
With multiple satellite dishes, you will get a lower signal strength on mulitple satellites as opposed to individual satellites. The reason being when pointed at one satellite, you are pointed directly at that satellite. With multiple satellites, you are pointed in the general direction of the multiple satellites so the signal will not be as strong compared to pointing directly at the individual satellite. Normally, a signal strength 50 or above is sufficient. I hope this helps.
Ray Calo
DISH Network
May 20, 2010 | DISH Network IR Remote Control
Where do i find the satalite coordinates for bell expressvu in california
For Nimiq 91W- ExpressVu Standard based on Los Angeles coordinates are Longitude 91... 34 N Lat, 118.25 W Lon
For Nimq 82W-ExpressVu HDTV and international based on Los Angeles, Longitude is 82... 34 N Lat, 118.25 W Lon
http://www.kusat.com/install/calculator.php
Dec 08, 2009 | Toshiba Satellite R10-S802TD Tablet PC
Pool Not Heating Display Wrong
where the thermostat is located, the pump is not circulating the water
Sep 04, 2009 | Raypak Free Hydraulic Lift Gate Delivery -...
Televison & Video Logo
42 people viewed this question
Top Televison & Video Experts
