Got a Yamaha RX-V767 today. I tried to connect it to an -also new bought- Harman Kardon HKTS 30BQ. Everything works, except the subwoofer.... Tried everything (even a different cable) and was carefully reading the manual but found nothing...... A second problem is that the digital cable-HDTV-decoder doesn't work connected to the HDMI1-input. The other devices (DVD, PS3) work properly.
  • 192 Answers
SOURCE: Component Video inputs do not work
I started back in the day of tubes. A family would have one set and it would be a 19" black and white. There are different resolutions now. The components probably do work, but, they don't pass the 480i signal. The satelite converter's analog signal needs to be set to 480p and the DVD needs to be set to progressive if it does have that setting. If the DVD is not a progressive scan DVD, then, the only inputs that it will show on is the analog signal. Some of the dish converters have a switch on the face for changing the resolution. If yours doesn't then put it in an analog source and go to the menu and change it there. Then move it to the component input. Hope this helps.
Posted on Jun 24, 2007
cheebster
  • 39 Answers
SOURCE: harman kardon avr-147
Hi Javis. This is perfectly normal ! This mode change is done because the receiver auto detects the digital audio signal and sets the receiver's DSP to decode the signal correctly. You can go into the OSD menu to bypass the auto detection of it, but it's not recommended at all ! You're getting the best audio quality by doing so. Thanks ! cheebster.
Posted on Jul 10, 2007
Heiny
  • 10 Answers
SOURCE: PS3 no longer communicating with TV
All: Try this -
P
erform the following steps to reset the Video Output Settings.
  1. Make sure the HDMI cable is connected to the [HDMI OUT] port on the back of the PLAYSTATION 3 system. Connect the other end of the HDMI cable into the [HDMI Input] port of the TV or display monitor.
  2. While the PLAYSTATION 3 system is in standby mode (red light on the front of the system), hold down the touch-sensitive On/Off button on the front of the system until the system goes into standby mode again . (So the light cycle would go from: red light to --> green light --> then back to red light) This will ensure that you have held down the On/Off button long enough to reset the Video Output Settings.
  3. Turn ON the PLAYSTATION 3 and once the system finishes powering up, the Video Output Settings will automatically reset to the standard resolution (or detect the current display output settings of your TV/monitor). [If resetting does not auto-detect your HDTV, see next step below.]
NOTE: As of system software update version 1.60, the PLAYSTATION 3can automatically detect an HDMI connection to a TV. If the PLAYSTATION 3 is turned on with an HDMI cable connected, the screen for switching video output settings will be displayed automatically. (Does not function unless the TV that is connected by the HDMI cable is turned on.)
As of version 1.80 of the system update for the PLAYSTATION 3, the PLAYSTATION 3 can upscale the video content of PlayStation® format software, PlayStation®2 format software, and DVDs to HD resolution.
If Resetting the Video Output Setting Did NOT Detect Your HDTV Automatically (Certain TV's Only)
With certain televisions, the PLAYSTATION 3 may not automatically detect the HDMI source (TV) which it is plugged into, even after resetting the Video Output Setting (as described above).
If resetting the Video Output Setting did not work, you may need to follow these steps to manually locate the HDMI source:
1. Connect both the AV Cable and the HDMI cable from the PLAYSTATION 3 to the corresponding (AV and HDMI) ports on your TV. 2. Proceed with resetting the Video Output Setting on the PLAYSTATION 3 again. (Follow these steps, then continue to step 3 below.)
3. Turn the TV channel to the corresponding "Input" or "Video" channel for the AV Cable connection.
4. Manually change the Video Output Settings to HDMI. (Follow these steps, then continue to step 5 below.)
5. Now switch the "Input" or "Video" channel on the TV for the HDMI port the PLAYSTATION 3 is currently plugged into.
6. Accept the display settings for HDMI before the timer runs out (30 seconds). Highlight "Yes" and press the X button.
7. You can now disconnect AV Cable from the PLAYSTATION 3 and the TV, as it is no longer needed.
Posted on Dec 17, 2007
Open SKy
  • 620 Answers
Orastie
Wow, general problem here, but the most near your problem could be, power failure, or the Power adapter is bad, or a energy failure at home, time to buy a new adapter.
Carl
Posted on Dec 30, 2007
  • 236 Answers
SOURCE: Yamaha RX-V1200 subwoofer connection to Mirage BPS-150i subwoofer
just connect your subwoofer mono RCA to your amp sub single out rca connector. you do not need to megre all those 4terminals into one. in fact internal circuit of those 4rca are merging inside to one since the sub uses only a single amp. 4inputs was meant for sources with multiple sub out
Posted on May 03, 2008
WHY is my harman kardon HKTS 15 subwoofwer is making a booming sound
Disconnect the cable and check the impedance/ohms with a meter.If rated at 4 ohms then it should read near that value.For 8 ohms also the reading should be near that value.You can buy a cheap Volt ohm meter for under ten dollars.After taking the ohm reading,it will be easier to diagnose................
Aug 19, 2014 | Harman Kardon HKTS 14 System
HKTS 15 speaker stopper working
more info ? unit powers up ? or no power up ?
Sep 08, 2013 | Harman Kardon HKTS 15 Theater System
Harman kardon hkts7 subwoofer problems
luis::
you have to open 16 screws to open the ts 7 logic board.
Mar 24, 2013 | Harman Kardon HKTS 7 System
check the audio stage and replace the audio stage ics
u 201,202,301. with TL074 ic
IPad connected to V-AUX of Yamaha RX-V767 - audio only on one side
Try switching the input cables between red and white, and see if the audio switches sides. Your cable may be bad.
Jan 29, 2013 | Yamaha Audio Players & Recorders
No sound from my LG HD TV to my Harman Kardon receiver
Hi!.
i want to connect my akg t 912 headphone with Sony LCD. The audio output from setup box is attached with the Home theater and not directly to LCD TV. Suggest me the way to get the setup box audio output to AKG wireless headphone.
Jan 02, 2013 | Harman Kardon Audio Players & Recorders
Can I connect a Harmon Kardon TS200 speaker system I bought an auction to my iMac or do I need some kind of amp/receiver?
Does the speaker system have its own Built in amp to the sub, If it has a built in amp, Then you can hook it up to thje computer with the proper patch cord,
Dec 02, 2012 | Harmon Kardon Harman/kardon Hkts 200 Bq...
I am getting no sound from sub. The turns on, but so sound. I have connected to two different receivers to verify it isn't the receiver sub output.
Bear with me on this.
Just because two systems don't light this sub up doesn't prove the amps are faultless unless they work with other subs. Can you assert that?
See page 14:
http://www.retrevo.com/support/Harman-Kardon-HKTS-14-Speaker-Systems-manual/id/386ci056/t/2/
How are you driving the sub - Speaker or Line Level?
Jan 30, 2011 | Harman Kardon HKTS 14 System
Harman/kardon avr 247 no audio or LED display on the reciever
I've had the exact problem. HK in the states is no help, you need to deal with a company in Montreal (Jan Industries). Regular techs are unable to fix it without schematics that only authorized dealers have and the manufacturer. This problem happened to me just after 2 years and outside warranty. I've bought a Yamaha today.
Apr 01, 2009 | Harman Multimedia AVR 247 7.1 Channels...
Televison & Video Logo
139 people viewed this question
Top Televison & Video Experts
