Question about Indesit IS70C Electric Dryer
There is no heat coming though - Indesit IS70C Electric Dryer
  • Indesit Master
  • 7,482 Answers
ALWAYS UNPLUG YOUR DRYER BEFORE ATTEMPTING TO DO ANY WORK ON IT.
Check to make sure you are getting full 220 Volt power to the dryer, if you are then:
Check your Wiring
Often the main wiring connection from the house, at the dryer, burns and the connection breaks. If this has happened to your dryer, you need to replace the power cord and the terminal block inside the dryer to which the wire is attached.
Check the Door Switch
If the door switch or the door-switch actuator is defective, the dryer won't work and you need to replace the failed component. The switch is inside the dryer main housing near the door frame. Sometimes you need to raise or open the top or front of the dryer to reach the switch. Check for continuity you should have none with door open, and should have a reading when closed. If not replace the door switch.
Check to make sure you heating problem is not a lint build up in the discharge hose or the dryer,as this condition can cause heater/thermistor problems such as overheating of the heating coil leading to failure of the coil and burnout of the thermostat/thermistor due to overheat.
Remove the back/or front just under the door of the machine and try to locate the air duct going from the blower to the drum. Normally inside/outside the air duct you will find the heating coil and the thermostats/thermistors. Once you have located the heating coil, remove the two wires from it and check the coil with an ohm meter across the two terminals of the coil.
You should read continuity across the terminals, if not you will need to replace the coil as it is faulty.
If the heating coil is ok, then:
You can check the thermostat/thermistor one at a time by removing the two wires and taping them together with electrical tape or with an ohm meter to test the thermostat/thermistor. (Should have/show continuity)
If the coil heats up then replace the thermostat/thermistor.
(Thermal fuse.If it overheats the dryer will not operate. It's located on the blower housing. It cannot be reset. A vent clogged with lint can cause it to overheat. You can test it with an Ohm meter or continuity checker, if no continuity, replace it)
DO NOT LEAVE THE WIRES TAPED TOGETHER AFTER THE TEST.
This could cause a FIRE, as you have removed the safety of overheat from the machine.
Right after replacing a dryer element, always run the dryer on 'air fluff' / 'no heat', and go outside to verify there's plenty of air coming out your vent system.
If the vent's clogged, that new element can burn out very quickly.
For video and pictures on how to replace the element go to the following website:
davesrepair.com/DIYhelp/DIYreplacingWPLdryels.htm
This is a FREE answer, Please rate me
Posted on Dec 31, 2010
Amana Furnace
The furnace may have a cracked heat exchanger.
Dec 19, 2013 | Heating & Cooling
No heat though out the vents
ifs theres air coming out of the vents could be a thermostat if theres no air could be blowermotor
Jan 04, 2012 | Cars & Trucks
Does not heat,gas won't ignite.the glow rod comes on ,but no gas comes out to burn
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101
Jul 12, 2011 | Dryers
Have a 2007 ranger heater works, but heat doesnt come out of vents. thank you erwin
all the controls work on the dash the way they should. but no heat comes out only cold air. even when you manually open the valve on the heater hose. Hot water will pass but no heat in the cab. It seems as though it is a vacuum problem.
Nov 10, 2010 | Ford Ranger Cars & Trucks
Gas dryer -- heat doesn't come on.
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Jul 09, 2010 | KitchenAid KAWS700L Top Load Washer
Not heating water
Is this an old or newer dishwasher many newer models will not bother trying to heat up the water if it does not come in hot enough there is a temperature sensor, if the water is cold heater will not come on because it will take it too long to heat the cold water.
Jan 11, 2009 | Dishwashers
The dryer works but does not heat
Before you buy an expensive heating element change out the thermal fuse. It's only about 15 dollars for a fuse as opposed to around 100 dollars for a heating element. Both can be purchased at a appliance repair shop. The thermal fuse is usually located near the heating element housing and has two wires coming off of it. Make sure you unplug the dryer first though. If the thermal fuse if dead then your heating element will only heat for about a second or two at a time. The way to check this is to open up the dryer so you can see the heating element. While it's running watch it and it the heating element comes on and then turns off then the thermal fuse is bad. If it doesn't come on at all then the heating element is bad. Wait a good 5 minutes though before determining if the heating element isn't coming on. Sometimes it takes a bit before it engages. I hope this helps you and if you have any more questions feel free to ask me. Good luck.
Jan 08, 2009 | Whirlpool GEW9250 Electric Dryer
Honeywell Pro 5000 wont bring Heat on
have you programed the tstat for your system? look at your installers book.
Oct 07, 2008 | Honeywell Electronic Programmable...
Indesit IS70C Electric Dryer Logo
313 people viewed this question
Top Indesit Dryers Experts
Tim Whalen
Gerard Curran
paul
paul
Are you an Indesit Dryer Expert? Answer questions, earn points and help others
