Question about Panasonic Viera TH-42PZ80U Plasma TV
Where is the earphone jack? - Panasonic Viera TH-42PZ80U Plasma TV
    Sniper:
  • 62 Answers
The TH-42PZ80U does not have a earphone jack.
Posted on Dec 30, 2010
Can I use headphones on a Kindle?
Some Kindles have an earphone jack and some don't You can use earphones only if your Kindle has the earphone jack. It is the mini-jack like used in iPods and iPhones and many headphones (as opposed to ear buds) use a larger size jack.
Adapters are available. Try Radio Shack for adapters and lead cables. Keep in mind that most earphones require more power to operate than earbuds do and the Kindle may not be able to sufficiently power headphones to get any decent volume.
Apr 08, 2015 | Audio Players & Recorders
Earphone jack doesn't seem to work
tried to hooked up with other earphone jack first, if still doesn't work check the earphone jack of the tv which may have loose contact joint in the board.
Oct 14, 2012 | ViewSonic Televison & Video
No sound for earphone, there are no rca jacks, the earphone is used to attach speakers, but there is no sound from the earphone jack
if their is a sound from the internal speaker then the problem is with in only in the earphone jack or in the connection. to access the internal part of the tv you need to remove the rear cover. locate the earphone jack terminal re soldered and check the connection at the board ( PCB). you can check also the continuity, attached powered pc speaker then use an analog tester and check weather their is a connection coming from the stereo input jack going to the terminal of the earphone jack of the tv. if no connection replace with new earphone jack. good luck hope this can helped.
Aug 14, 2012 | Insignia Televison & Video
The earphone jack connection produces sound in only one ear. Partially with drawing the jack produces sound in both ears. Clearly, the jack is not making a good connection once inside its 'port'.
This is usually the result of faulty earphones. Try replacing the earphones you are using with the ipod and it should work normally.
Good Luck!
Jan 13, 2011 | Apple iPod nano
How to connect my computer audio to pioneer vsx515 reciever..
here the steps:
1. locate the earphone jack on your pc.
2. after finding the earphone jack from your pc you need a connector (baby stereo plug to 2xrca plug).
3.connect the baby stereo plug to your earphone jack and then the rca plug to your Pioneer axuliary in.
Jan 02, 2011 | Pioneer VSX-515 Receiver
Hi i have a 1st gen 16gb ipod touch. When i insert the earphones into the socket i either get no sound, very poor quality sound, or ok quality sound which disapears when i move. i think this is because of...
Some devices such as yours have a 4 conductor jack, (used for earphones and microphone) and most earphones have a 3 conductor plug. They are not compatible. This would be my first guess. Second is earphones and earbuds get tossed around, put into pockets, etc. The cords can get damaged, and not be visible from the outside as the wires inside are very delicate. I would try a set that works in a different device.
Dec 02, 2017 | Apple iPod touch 1st Generation (8 GB) MP3...
Sound from 1 side only!
your ear input female jack is stripped try another new pair of earphones if not you may have to take it in for service.
Nov 05, 2009 | SanDisk Sansa E280 MP3 Player
My itouch earphone jack creates static in earphones.
sounds like the typical ipod and ipod touch common situation. It seems to be the dreaded headphone jack on the bottom or top of the device has gone belly up. You can either take it to your local apple store or look online and search your problem and see if anyone else has the same issues you have and see what can be done.You can send it to ipodsquad.com to get repairs or check your local apple store.
Oct 12, 2009 | Apple iPod touch
My earphones won't work
Usually this is a problem with the wires in the earphones themselves actually being broken or the connection on the earplugs is too small. I suggest borrowing another pair of earphones to make sure the problem actually is in the Zen. If another pair works, you know the issue is the earphones. If the problem remains even with different earphones, take a look in the earphone jack hole to make sure nothing is stuck in it like paper or something. If everything is clean, the earphone jack or its soldered connections inside the Zen may be cracked and will require the unit to be opened and serviced.
Aug 17, 2009 | Creative Labs Zen Micro MP3 Player
Won't detect a jack being plugged in
it doesen`t do that on my computer either but i still get sound
Apr 13, 2009 | Dell A215 Computer Speakers
Panasonic Viera TH-42PZ80U Plasma TV Logo
81 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
