Question about Dryers
Heat works but clothes don't dry - Dryers
Check to make sure the dryer vent is clear so the damp air from the drying clothes can escape the dryer.
Posted on Dec 30, 2010
Not drying efficiently. Air moving ok, heat appears to be ok. Would like to open it up to visually inspect it. With event off slight burning smell. Would like to verify clean of lint.
If it tumbles and it heats up but your clothes don' t dry disconnect the vent tube from the the wall and run a load of wet clothes if they dry then your homes venting is clogged and if it still does not dry then it could be your thermal fuse.
Mar 30, 2014 | GE Dryers
Whirlpool duet dryer
Run the dryer for 2-5 minutes. Check to see if it has heat inside. If not, you have an internal problem.
If heat is generated, check your dryer lint trap. It must be clean before every dry cycle to dry properly and efficently. If the trap is clean and heat is generated, check the tubes behind the dryer for disposing of the lint.
Oct 15, 2013 | Dryers
Clothes don't dry or get warm
Ether a bad heating element,or an obstructed discharge vent. The bad element will prevent heat production, a blocked discharge will not allow humidity to escape, resulting in wet clothes. Hope this helps.
Sep 11, 2013 | Dryers
Frigidaire Galaxy Dryer tumbles but heats to dry seldomly
What is the model number of the unit?
Nov 13, 2012 | Dryers
My whirlpool duet dryer works but it appears that the air is not evacuating from the baril. The heat and humidity built up and the clothes don't dry. Do I need to replace the fan and if so, how
YOU NEED TO CLEAN THE VENT ON YOUR HOUSE IF THE BLOWER WHEEL IS BAD ON THE DRYER YOU WOULD HERE THE NOISE AFTER THE DRY STOPS THE BLOWER WHEEL WILL STILL TURN AND MAKE A NOISE
Oct 29, 2012 | Whirlpool Duet Steam WFW9700V Front Load...
My dryer won't dry my clothes
clean out lint filter check the vent hose make sure you are getting a air flow out your vent hose if not its blocked inside no air no dry it need air to dry cloths heat only will not dry plenty of air heat quicker drying
Nov 27, 2011 | Whirlpool Dryers
Kenmore Elite Model 11087731700, the timer decreases during cycle and stops before items are dry.
check the venting for your machine, the normal problem for clothes that don't completely dry is clogged vents , if your vent is clear and free from any buildup , you could have a bad thermostat which shuts the heat down too early as the drying cycle progresses
Jun 21, 2011 | Kenmore Dryers
FRIDGIDAIRE GAS DRYER MODEL # GLGR642AS2 IS NOT DRYING CLOTHES BUT GAS IS IGNITING. THANK YOU. DON
Hi Don,
So let me get this straight, you are getting heat from the gas burner and the drum rotates but your clothes remain wet? You can check a few basic things to identify where the problem lies.. First off, have you checked the lint trap and cleaned it? Secondly, have you checked your vent system ( meaning : are you sure it is not clogged anywhere in the duct or at the end where it exits outside? If that's OK.. when your system is drying clothes.. do you get hot air flow at the end of that duct? If not, your blower may not be working ..You need to move that hot air out of the tub for the system to dry. Heat, Motion to move clothes, air flow from the blower and an unimpeded path via the vent duct to outside.. Hope one of these things to check gets you going. Regards...
Sep 03, 2008 | Dryers
My indesit widl126s
my washer works fine but the dryer wont heat up or dry the clothes it goes onto dry but all the clothes are still coming out wet and the drum is cold
Apr 01, 2008 | Washing Machines
Dryers Logo
26 people viewed this question
Top Dryers Experts
