Question about Metz Mecablitz 60CT4 TTL Flash
I need to replace my capacitor in my 60 Ct 4 but there are no specs on the unit all it says is "Frako, Kapazitatskonstant, 333 39 0010-1, 87 26" can someone tell me what the specs on that unit is? or suggest a suitable replacement? Thanks, Dave
  • lngroller Jul 09, 2008
    Thank you and I appreciate the concern, but after repairing my Speedotron 1200j units this is a walk in the park. about 1/10 the capacitor capacity. try saying that 3x's fast : )
  • 20 Answers
The flash stores 200 Joules Energy and uses 350V. You can figure the capacity from those numbers using C = 2*Energy/V^2 However, it is a custom high current photoflash capacitor of odd size, and you will not be able to get it as a spare except from vendor and it would cost much more than a whole used box unit,that you can get off of ebay.
Posted on Oct 18, 2014
    Genius:
  • 1,673 Answers
Send the flash to the manufacture or their authorized service rep for proper service. These capacitors are charged to high voltage and are discharged with very high current.
There are serious safety issues with these capacitors. The flash manufactures normaly will not give out service information or supply support for self service. There are serious liability and safety issues involved.
For personal interest, below is a very good article on basic capcitor theory and history. If you have a background in physics and math, this article can be well appreciated.
http://en.wikipedia.org/wiki/Capacitor
Jerry G.
Posted on Jul 09, 2008
Trying to determine what size capacitor my unit C1048BBD1VF uses for my AC unit. Is it larger then a 45 amp? Replace it with a 45 and you can hear it try to turn on but it won't.
capacitors are rated in microfarads or picofarads and not amps
capacitors are used to provide a boost voltage to start motors and then to keep them running
Amps is current flow so what ever you replaced was the wrong unit.
on the side of a capacitor will be voltage rating (110-115-220-240 etc and a number 45 -55 60 uf etc
it will have either 2 terminals or 4 terminals connected as pairs
from what you describe it is a capacitor problem
May 26, 2016 | Airwell Fedders Fedders C1048bbd3vf 3...
Model 10AJB48A01. What are the specs for the motor starting capacitor?
it is either a 45/3 370vac or a 60/5 370vac depending on the compressor that's in the unit. if the unit serial number starts with 6936 it is the 45/3 if it starts with 6937 it is the 60/5
Jul 24, 2015 | Weather King Heating & Cooling
RE: OnKYO CR-305TX CD RECEIVER Why do the "saved"
There shouldn't be a battery inside but a super capacitor that is supposed to keep the station memory...may be the capacitor is defective...it should be located on the tuner/radio board and may have a high value such as .47Farads at 5 volts...you may need a tech to replace if you have no working knowledge of circuits , but if you do , you should be able to obtain one at radio shack...they sometimes call these capacitors memory backup capacitors
Apr 27, 2011 | Onkyo Audio Players & Recorders
Blower fan starts fine sometimes circulating fan starts right away then after about 4 0r 5 min the small 3 amp fuse blows and shuts down whole unit. What is this fuse for and why does circulating fan...
Hi WFO9, It sounds as though the fan capacitor is under specs. It is probably losing its capacitance ability, they are usually rated plus or minus 5% of the value printed on the case. If however the capacitor is no longer within the rated specs. the fan motor will draw too much current and will then blow the fuse. either that or after the normal start delay built into the Ac, which is 3-4 minutes, the compressor tries to start and again draws to much current and blows the fuse. have all the capacitors checked and replaced if they dont meet the specs printed on the capacitor case. regards Col www.digitalcontrols.com.au
Feb 23, 2011 | Heating & Cooling
My beloved sander dosn't get up to speed and is starting to make a grinding noise; is there maintenance I should be doing? Possibly replace motor bushings? Bearings???
I just had the same problem with mine. I replaced the motor start capacitor with one from Grainger and it starts like a champ now. I found one that had the same specs as the stock one and it also fits inside the cover perfectly. Here are my notes:
Grainger Item 2MDR5
MFD Rating: 189-227
Voltage: 110-125
Hz: 60/50
Shape: Round
Dia. (In.): 1-7/16
Case Height (In.): 2-3/4
Overall Height (In.): 2-3/4
Original start capacitor was:
CD60
125/156V AV
200 UF
Blue shrink wrapped can with pigtails.
Length: 81mm (3.19")
Diameter: 34mm (1.34")
Feb 02, 2011 | Delta 31 - 120 12" Disc Sander
Hello, I just bought a second hand Hobart 110 "Handler" wire welder. The fan comes on, but when i pull the feed trigger, it clicks ,and pulls the lights in the shop way down, but the feed moter...
I have a suspicion. Remove the sheet metal housing (unplugged of course) and look for a large cylindrical object, probably in a clamp on the floor of the unit and it will have two large terminals with fairly heavy wires attached. It could be ~ 6-7 inches high and 3-4" diameter. It will have markings on it indicating capacitance and voltage and could be around 20-30,000 uFd and 60-70 volts. This is a filter capacitor and I have replaced several of the (naturally) Chinese units in other welder brands. Figure on $40-60 for a new one of these pieces of ****. They often do not even meet the given values by a large percentage but unfortunately, no American mfrs. have survived to compete with them. I have several large US made capacitors that are 30-40 years old that measure nearly like new.
Feb 01, 2011 | Hobart Welding Tools
There is a message that reads "replace waste toner box" on my lexmark C540 n. Where is it and how do I replace it? Thanks Toni Tomasino Naylor School Hartford,...
Try the link below. This will show you how to replace your toner box. http://bitly.com/rkjxWz
If you need further assistance, please contact Lexmark Technical Support Center.
Jan 03, 2011 | Lexmark C540N PROD SPECS TBD Printer
METZ 60 CT-4 batteries and capacitors
Although you can still get lead acid batteries from Sonnenschein (the original oem manufacturer) for the Metz CT60 units, a better choice are the Lithium ferrite phosphate or Lithium ion batteries, now available on ebay. For example sales8phd on ebay sells a drop in replacement 6 or 7Ah battery with a charger for ~$75. In general these batteries produce more flashes per charge than the lead acid oem batteries,particularly when shooting a lot of flashes in rapid sucession.
Jun 01, 2010 | Metz Mecablitz 60CT4 TTL Flash
My Metz units have sat a long while. I now need them again and and have fresh batts but I guess my capacitor is going it takes about 14 seconds to recycle from discharge to full power on manual. I would...
About 8 seconds is normal. Metz actually instruct owners to discharge the flash at full power every month to preserve the capacitor, which you haven't done. I confess I don't always do that either. But just fire it off till the battery goes flat, and then recharge and try again. This has always improved the performance when I have done it. Basically, they like to do heavy work, and like muscles, get better for it. That sounds silly, but it is true. There is an electrochemical explanation. As you are not sure what capacitor to use, I would recommend taking the unit to Foto Reisel in Sydney if it is near you. They can get the unit serviced for you. You can also send an email to Metz. They understand English, and if servicing the unit is difficult in your location, and you sound capable of fixing it yourself, they may sell you or tell you an equivalent part. BE CAREFUL THOUGH. THAT THING CAN EASILY STOP YOUR HEART!
Jul 08, 2008 | Metz Mecablitz 60CT4 TTL Flash
Metz 60-4 flash takes much longer than normal for the ready light to come on to allow me to take another photo.
It is likely the capacitor in the battery pack. If they are not powered up every month, they dry out resulting in long power up and recycle times. You'll need to get it replaced to rejuvenate your 60 CT-4 to its original spec.
Oct 06, 2006 | Metz 60CT-1 Flash
Metz Mecablitz 60CT4 TTL Flash Logo
315 people viewed this question
Top Metz Cameras Experts
Doberman
Neil
Level 1 Expert
Are you a Metz Camera Expert? Answer questions, earn points and help others
