Question about Kenmore Dryers
My Kenmore Dryer is not heating up and it is maybe 10 years old.
  • Kenmore Master
  • 7,482 Answers
ALWAYS UNPLUG YOUR DRYER BEFORE ATTEMPTING TO DO ANY WORK ON IT.
Check to make sure you are getting full 220 Volt power to the dryer, if you are then:
Check your Wiring
Often the main wiring connection from the house, at the dryer, burns and the connection breaks. If this has happened to your dryer, you need to replace the power cord and the terminal block inside the dryer to which the wire is attached.
Check the Door Switch
If the door switch or the door-switch actuator is defective, the dryer won't work and you need to replace the failed component. The switch is inside the dryer main housing near the door frame. Sometimes you need to raise or open the top or front of the dryer to reach the switch. Check for continuity you should have none with door open, and should have a reading when closed. If not replace the door switch.
Check to make sure you heating problem is not a lint build up in the discharge hose or the dryer,as this condition can cause heater/thermistor problems such as overheating of the heating coil leading to failure of the coil and burnout of the thermostat/thermistor due to overheat.
Remove the back/or front just under the door of the machine and try to locate the air duct going from the blower to the drum. Normally inside/outside the air duct you will find the heating coil and the thermostats/thermistors. Once you have located the heating coil, remove the two wires from it and check the coil with an ohm meter across the two terminals of the coil.
You should read continuity across the terminals, if not you will need to replace the coil as it is faulty.
If the heating coil is ok, then:
You can check the thermostat/thermistor one at a time by removing the two wires and taping them together with electrical tape or with an ohm meter to test the thermostat/thermistor. (Should have/show continuity)
If the coil heats up then replace the thermostat/thermistor.
(Thermal fuse.If it overheats the dryer will not operate. It's located on the blower housing. It cannot be reset. A vent clogged with lint can cause it to overheat. You can test it with an Ohm meter or continuity checker, if no continuity, replace it)
DO NOT LEAVE THE WIRES TAPED TOGETHER AFTER THE TEST.
This could cause a FIRE, as you have removed the safety of overheat from the machine.
Right after replacing a dryer element, always run the dryer on 'air fluff' / 'no heat', and go outside to verify there's plenty of air coming out your vent system.
If the vent's clogged, that new element can burn out very quickly.
For video and pictures on how to replace the element go to the following website:
davesrepair.com/DIYhelp/DIYreplacingWPLdryels.htm
This is a FREE answer, Please rate me
Posted on Dec 31, 2010
Dryer warms..... but not enough heat to dry...about 10 years old 80 series Kenmore electric dryer
Probably has a broken heating coil...as the temperature goes up it expands and moves from natural position of touching....that would give the false indication of continuity in the coil when it cools back down and touches again. Visually inspect coil.
Nov 02, 2013 | Kenmore 800 7982 Dryer
I have a 10 year old kenmore dryer d433. it heats but the drum will not turn. thank you
I would unplug the dryer and pop the top to see if the belt is on there.
I would take that dryer outside and give it a good clean inside and out
Service manual and more here
Jul 11, 2011 | Kenmore 7942 Dryer
10 year old kenmore model 110 gas dryer drum turns but will not dry clothes
I have a Kenmore Model 110.74612200 it came with the house and needs another service call-not heating- how old is this model? Wondering if it might be time to buy a new one. Dryer has seen a lot of use in the past 5 years from a household of six.
Feb 21, 2010 | Kenmore 63942 Dryer
1 year old Kenmore dryer tumbles but doesn't heat.
If it is 1 year old, call Kenmore , they will probably fix it as a courtesy call.
If not quote that the machine is not fit for purpose as it should not have gone wrong so quick
Sep 24, 2009 | Kenmore Dryers
Kenmore Gas Dryer is 7 years old. It will heat up
Replace the gas valve coils. Common problem after 3-4 years.
Jul 05, 2009 | Kenmore Dryers
Kenmore Dryer won't heat up
thermal fuse is bad. replace fuse. clean out vent duct. thermal fuse usually blows when there is restricted air flow over heating element.
Jun 24, 2009 | Dryers
Where is the fuse in kenmore elite dryer
Check your breakers first. Turn off then back on. Then check trhe wiring from the receptacle to the dryer and to the heating elements. The thermal fuse is located under the top. You will have to remove some screws to get to it. Bypass the fuse and if it works, then replace it. It is only 15 dollars. If all is O.K., then check the heating element. It may be bad especially if the dryer is over 10 years old.
Jan 28, 2009 | Kenmore 85871 Electric Dryer
Kenmore dryer takes to long to dry
You may have to get inside the exhaust assembly ...somtimes there are lint buildups that occur and cause long drying times. Also make sure you don't have a DUAL heating element model. I had one and only one of the elements worked when I repaired the second one it worked great. Most likely is the exhaust block however. Hope this helps.
Jan 18, 2009 | Kenmore 659 Electric Dryer
Dryers Logo
64 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal DeAngelo
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
