Question about Braun 360° Complete 8985 Electric Shaver
Braun clean and charge base always shows empty even when a new catridge is installed.
SOURCE: Braun 360 Cleaning base
When you are looking top down into the cleaning base you want to look to the left side of the hole where you put your razor. That is were the solution drains out after your razor is cleaned and there is probably a blockage there. I used a toothpick to clean mine out every once in awhile when gunk would build up there.
Posted on Oct 28, 2007
SOURCE: Cleaning base thinks it's empty
I had the same problem. Try taking out the cartridge and in the compartment where the razor sits in to get clean, there is a drain hole on the left side. Try cleaning the hole out with a toothpick or something similar. It seems that the drain hole clogs and causes this problem. I just did it and all seems to be working fine.
Cheers
Posted on Feb 17, 2009
Cytherian
  • 124 Answers
SOURCE: I have a Braun 360
In your case, it's hard to know exactly what might be wrong without more information. Was the shaver exposed to undue heat, such as left in a car or in a place that wasn't air conditioned in the hot summer?
I have a couple of vintage Braun shavers (over 15 years old) where the batteries do not hold a charge, but the shavers still work when plugged in. One of them will show a low charge level but still work.
Although the batteries in these shavers are fairly robust, if fully discharged and not used for 18 months, it might be that they've got a "low level memory" and will need replacing. If you are handy, you could disassemble the shaver and replace the batteries. They are NiMh AA flat top batteries that you can buy on websites like onlybatteries.com. If you're handing with soldering, you can replace them yourself. If you're unsure about that, you can buy the batteries along with the circuit board as a complete unit that drops right into place. Shaveroutlet.com sells these for the 360 complete shavers. Good luck!
Posted on Oct 22, 2009
  • 5 Answers
SOURCE: Red "empty" light on Braun Clean & Renew fluid turns on too soon
Put a few drops of tap water in the solution if the light goes red until it goes out. Cheap, green way to reuse the plastic container!
Total Cartridge Size = 170 ml
DIRECTIONS:
1.) Clean old cartridge with 70% Isopropyl alcohol
2.) Add 3 ml of Lemon oil
3.) Add 3 ml of glycerin
4.) Add 2 ml of water
5.) Add 70% Isopropyl alchohol to 3/4 of the top of the cartridge
COST ANALYSIS:
16oz (473ml) 70% Isopropyl alcohol = $1
16oz (473ml) Glycerin = $10
16oz (473ml) Lemon oil = $8
Cost Savings on one unit
Normal = $11
Homebrew = $0.81
Savings = $10.19 per refill
Posted on Dec 26, 2009
brector3
  • 1612 Answers
SOURCE: Braun 790cc Shaver battery not holding charge
the item has a 2 year warranty. if you have proof of purchase date, you should call Braun for warranty service. Phone number is in your owner manual
Posted on Jan 16, 2010
I cannot click the top on when i try to charge it ....
The latch on the 'arm' of the clean and charging base is broken. You can either change out the top portion of the clean/charge base or replace the whole thing if you don't thisnk you can do the repair.
Both itemsare available at shaveroutlet.com. See links below. Basic instructions for installing the top part are included on the item page
http://shaveroutlet.com/shaver-replacement-parts/braun-7000-series-syncro-clean-charge-base-replacement-part-p-118.html
http://shaveroutlet.com/shaver-replacement-parts/braun-7000-series-syncro-clean-charge-base-p-122.html
Sep 26, 2010 | Braun Syncro 7570 Electric Shaver
Just replaced motor assembly now always shows liquid in cleaning station empty even with new cartrige
The motor assembly and the fluid level indicators are completely independent components and any coincidence between the timing of the problem with the cleaning base and your repair of the motor unit is likely pure coincidence. More likely, the cleaning base is at fault and will need replaced.
May 06, 2010 | Braun Activator 8595 Electric Shaver
Unable to charge the shaver. The charging unit is plugged in, but it doesn't seem to be able to charge the shaver.
The cleaning base is the problem. It probably got wet inside and the circuitry is damaged. This is almost always why these go bad. You dont have to replace it to use your shaver as you now know that you can charge the shaver directly from the cord.
If you want the convenience of the cleaning station, you will need to replace it. You can find a new one at shaveroutlet.com. See link below
http://shaveroutlet.com/braun-8000-series-360-complete-clean-charge-base-p-116.html
Feb 16, 2010 | Braun 360° Complete 8985 Electric Shaver
Shows catridge empty
If you want to use this non-
HP print cartridge, press
(Cancel Job) to continue printing.
Dec 16, 2008 | HP Color LaserJet 2550n printer + HP Color...
Need a new Clean and Charge Base
yes, you can find it online , also you can find it on ebay if you search for braun 8585 .
Nov 25, 2008 | Braun 8585 Electric Shaver
360 is saying empty
I just fixed it now .. when the cartridge is inside and full turn the whole bas upside-down for less than a sec .. ( while the power plug is disconnected ).. then try plugging and cleaning again
Dec 24, 2007 | Braun 360° Complete 8985 Electric Shaver
Braun 360° Complete 8985 Electric Shaver Logo
249 people viewed this question
Top Braun Health & Beauty Experts
shaveroutlet.com
shaveroutlet.com
Gary
Gary
Kazim ERGUNEY
Kazim ERGUNEY
Are you a Braun Health and Beauty Expert? Answer questions, earn points and help others
