Question about Texas Instruments TI-83 Plus Calculator
Ti-83 won't turn on - Texas Instruments TI-83 Plus Calculator
    Novelist:
  • 100 Answers
Make sure you have the batteries in correctly. You may want to put fresh ones in for these procedures to work. The batteries alternate negative, positive, negative, positive. The first time I put my batteries in, I had one backwards and, it was hard to see that it was in backwards.
Make sure the IO ports at the top or, button of the calculator are clean. You don't want a dirty connection missing the procedure up later on.
Please be prepared to re-install the calculator's OS if you run through this process.
Press and release the 2ND key. Press and hold the Up-arrow key for a few seconds. Now, Pressing the [2nd] key followed by pressing and releasing the up arrow; repeat as necessary. Is the screen showing any activity? If not continue the process.
  1. Remove one of the AAA batteries. Press and hold the [CLEAR] key. While holding [CLEAR],
    reinsert the AAA battery and then turn the calculator on. The calculator should display the
    message "RAM Cleared". Release the [CLEAR] key and then press it one more time to remove the message. If calculator did not display the message try pressing and releasing the [2nd] key followed by pressing and releasing the up arrow for one second. Goto step 2.
  2. Remove one of the AAA batteries. Press and hold the [DEL] key. While holding [DEL], reinsert the AAA battery and then turn the calculator on. The calculator should display
    "Waiting...Please install calculator software now". Follow the instructions for the
    TI-83 family or TI-84 Plus family to reinstall the calculator operating system. If the calculator did not turn on connect the calculator to the computer and open Ti Connect. Next, open Device Explorer. Is the calculator asking to be installed? goto step 3.
  3. Steps to re-installing the operating system:
    ~Connect the TI Connectivity cable between the PC and the calculator.
    ~Click on Start >> Programs >> TI Tools >> TI Connect >> TI OSDownloader
    ~Follow the on-screen directions to reinstall the calculator's OS. When or, if the calculator install the fresh OS goto step 4.
  4. Remove all of the batteries including the round lithium battery for 5 minutes. After the 5 minute period, reinsert all of the batteries and turn the calculator on. Adjust the contrast if necessary.
If this process did not work for. Try re-doing the process and, extend the time by 5 minutes before you put all the batteries back in the calculator.
Posted on Dec 31, 2010
  • charles williams
    charles williams Jan 01, 2011
    If the above procedure didn't help you try the instructions below.
    Re-do the procedure above but, substitue this step (2) below for step 2 in the procedure above.
    2. Remove one of the AAA batteries. Press and hold the [ON] key for 20 seconds. Reinsert the
  • John Doe
    John Doe Mar 09, 2014
    I have tried all of these steps over and over (yes the batteries are in correctly and have been replaced multiple times with brand new ones including back-up) and my screen literally will not show a single thing. No messages, no showing saying it is corrupted (constantly checked the contrast) its like it is off. Any advice what to do after this?
SOURCE: my ti-83 plus has OS problem
the buttons are *hold clear and take the battery out then put it in dont release clear until you turn on the device* OR * the same with the DEL button
Posted on Nov 21, 2007
  • 32 Answers
SOURCE: TI-83 Plus Silver Edition 1.14
That means that you know your calc crashed. This can be caused by taking out the batteries durring running time, happened just randomly. Well nothing to fear just press clear and it should go away but if it stays on that screen you have problems and is best to try some of these methods. Take out all the bateries and press and hold the on button for 30 seconds. Put the batteries back in and it should have reset. Warning you should archive everything incase this happens. To archive go to 2nd mem and hit enter to put a astrick next to the app (meaning archived)
Posted on Sep 16, 2008
  • 7993 Answers
SOURCE: TI-83 Plus will not let me view a table
I have just done what you said you had done, but I got a nice, correct table of values. You might have discoverd a secret command to clear memory.
Cheers.
Posted on Sep 09, 2009
  • 7993 Answers
SOURCE: ti-83 plus silver edition. calc won't turn on.
Well, if screen shows the RAM CLEARED message, that means your calculator is working. Just press the [CLEAR] key, message will be erased and you are ready to crunch numbers.
Hope it helps.
Posted on Oct 17, 2009
  • 7993 Answers
SOURCE: ti-83 plus ram cleared message when turned on
It calculator tells you Ram Cleared each time you turn it on, the most likely reason is that the backup battery is depleted. Its role is to keep the memory modules electrically refreshed when calculator is turned off. If the backup battery is dead, the memory is erased when you turn calculator OFF. Main batteries no longer supply power and the contents of the memory are cleared.
  1. Check that main batteries are good and inserted in calculator.
  2. Turn calculator OFF.
  3. Replace the backup battery.
  4. Turn calculator ON.
  5. Press the [CLEAR] key to erase the "Ram Cleared" message.
Posted on Jan 21, 2010
It just won't work with the new batteries!
TI calculators have an annoying habit of dimming the screen when the batteries are changed so that it appears as if the calculator isn't turning on. Turn the calculator on (or at least press the ON key). Press and release the 2ND key. Press and hold the Up-arrow key for a few seconds and see whether the screen becomes legible.
Sep 11, 2012 | Texas Instruments TI-83 Plus Calculator
TI-83 Plus "waiting ...please install message then "error message
Please Install Calculator Software Now error
This message means that the operating system has been corrupted. These steps will allow you to update the OS.
Unit to Unit
• Connect two TI-83 Plus units by means of the data cable (short black cable that was prepackaged with the TI-83 Plus)
• Make sure that at least one of the TI-83 Pluses contains the current Operating System
• Select [2nd] Link
• Select "Send OS" option from the Link menu
• Make sure that the other unit still reads "Waiting Please Install"
• The OS should be downloading.
From the Computer
• Make sure you have the latest version of the TI Connect™ Software
• Download the latest version of OS for the TI-83 Plus to the desktop of the PC.
• Connect the appropriate TI-GRAPH LINK™ cable between the PC and TI-83 Plus.
• Since the TI-83 Plus is currently off, the TI-83 Plus will automatically turn on when the TI-GRAPH LINK Cable is inserted.
• On your computer, choose Start, Programs, TI Tools, TI Connect, TI OS Downloader.
Dec 10, 2007 | Texas Instruments TI-83 Plus Calculator
My ti-83 plus won't turn on,
Having gone over a month without a reply to my query, I assume the suggested contrast adjustment solved the problem.
Sep 10, 2011 | Texas Instruments TI-84 Plus Silver...
New batteries and won't turn on
You might want to check the batteries, and make sure that they're in the correct way. If they are, then you either purchased bad batteries, or your 83 suffered a catastrophic failure/broke
Aug 19, 2011 | Texas Instruments TI-83 Plus Calculator
What is the different between ti-86 and ti-83
The 86 has more memory. It also has some advanced calculus capabilities the 83 doesn't. However you're much more likely to see examples for the 83 in textbooks and other references.
TI-83:
http://www.ticalc.org/basics/calculators/ti-83.html
TI-83 Plus:
http://www.ticalc.org/basics/calculators/ti-83plus.html
TI-86:
http://www.ticalc.org/basics/calculators/ti-86.html
Aug 09, 2011 | Texas Instruments TI-86 Calculator
My ti 83 calculator turns on but nothing shows
TI calculators have an annoying habit of dimming the screen, especially when the batteries are changed, so that it appears as if the calculator isn't turning on. Turn the calculator on (or at least press the ON key). Press and release the 2ND key. Press and hold the Up-arrow key for a few seconds and see whether the screen becomes legible.
May 20, 2010 | Texas Instruments TI-83 Plus Silver...
TI-83 Plus Calculator: My TI-83 reads "INVALID DIM" when I try to graph a...
You're probably trying to graph a function that does not involve stat plot features. You can correct this by turning off the stat plot features. Press "2ND" "STAT PLOT" and then select 4:PlotsOff.
May 17, 2010 | Texas Instruments TI-83 Plus Calculator
My TI-83 is all messed up
Sorry to hear that you are having problems with your TI-83. The TI-83 is a discontinued calculator, so I really don't think that it can be repaired/replaced.
See TI's website below for more information:
http://epsstore.ti.com/OA_HTML/csksxvm.jsp?nSetId=71440&nUsePub=NO&jttst0=6_23871,23871,-1,0,&jtfm0=&etfm1=&jfn=ZGEE602C53EA628B70E47DD2DD6878A5ABD632AD5834DE8ADC18D66ABBC9F888CBF7FB517A0B05B0984776B37370A28975B2
Feb 24, 2008 | Texas Instruments TI-83 Plus Calculator
Texas Instruments TI-83 Plus Calculator Logo
890 people viewed this question
Top Texas Instruments Office Equipment & Supplies Experts
k24674
Stevan Milanovic
Are you a Texas Instruments Office Equipment and Supply Expert? Answer questions, earn points and help others
