Question about Hotpoint Washing Machines
My washing machine is saying f5 washing machine blocked?
4 Suggested Answers
SOURCE: washing machine says its blocked
take the block off it and it wil work just fine.
Posted on May 14, 2008
57 varieties
  • 1653 Answers
SOURCE: Hotpoint washine machine ERROR F5 machine blocked
Do the following.
  1. Switch off the machine, unplug or disconnect the mains power to the machine and turn off the water supply to the machine.
  2. Remove the filter and make sure that the filter is not blocked and is clean and clear of all debris. Clean as required. Note that if the machine has stopped and not fully drained then you may be able to drain out the excess water by removing or disconnecting the waste hose and laying it on the ground in a tray. It may take a few minutes to empty but it will save a small flood. Alternatively bale out the sump under the main screen filter plate.
  3. Proceed by checking the drain hose for proper connection and kinks and make sure that it is not blocked or restricted.
  4. Also check that the main waste drain pipe and one way valve to a sink waste connection if you use one, is not blocked and clean if required.
  5. Access the pump from under the lower rotor arm and protective grille and check that the impeller is free to move and is not clogged or restricted by debris or sludge. Clean as required.
  6. Reconnect the power and switch the machine on.
If the problem persists then do the following.
7. Switch off the machine and disconnect the mains power. It is a good idea to take digital pictures of the pump assembly before attempting to work on it or remove it so that you can refer back to it when you reassemble the unit or replace it with a new unit at a later date / time.
8. Remove and check the electrical connections to the pump and make sure they are in good order.
9. Remove the connecting hoses, and expect water to drain out and make sure the pipes are not blocked with debris or any object blockage. If they are then clean them thoroughly.
10. Then remove the pump and check motor is OK and that the motor turns OK. Also check that the pump impeller vanes are in good order and not blocked. If necessary replace the pump with a new and identical unit.
11. Carefully reassemble the pump observing the correct placement of gaskets, seals, O Rings, hoses and securing straps, electrical wiring.
12. Reconnect the hoses and then reconnect power and switch the machine on.
Also see additional info to follow.
Posted on Nov 14, 2009
barkencoa
  • 3463 Answers
SOURCE: while on a cotton wash machine continues until the
You need to clean the filter.
Remove lower rear panel of washer/
Locate and remove large black hose on bottom of drum.
Remove and clean filter inside hose.
Rempve hose onto pump, and check for blockage and or obstruction here as well.
This should solve the problem.
Please leave feed back for my solution.
Thankyou.
Posted on Jan 11, 2010
Bravos X. How can I correct error codes F5 E1, F5 E2, and F5 E3?
remove the relimates/connectors and clean with CTC and refix the same or check the pressure sensor connection , replace the pressure sensor and see
Feb 11, 2016 | Maytag Washing Machines
What does f5 mean
F05 - Pressure switch jammed on full* consult with repair tech.
this is for the EV01 model.
Jul 29, 2014 | Hotpoint Washing Machines
Hotpoint f5 machine is block
Possible fault with the controller unit
Check this link for tips to probe: controller unit
Nov 20, 2013 | Washing Machines
F 51 code
my hhot point washing machine door won't open and is displaying F5 and door block
Nov 20, 2013 | Whirlpool Cabrio WTW6600SBT Top Load...
My washing machine keeps flashing F5... It works for the cycle but when it starts to get to the spinning process it flashes F5 and doesn't work
Sounds like a blocked pump, unfortunately unless you are very handy they make it impossible for you to do it as it involves leaning the machine back and taking off hoses etc and it can be tricky to get back on unless as I say you are a DIY'er.
Sep 05, 2011 | Hotpoint Washing Machines
Hotpoint aquarius stopped working full of washing F5 showing on screen
hi im pretty sure f5 is pump blockage try filter on the front bottom right hand corner behind the kick plate if its not blocked it could be the level switch this is located under the lid its a round switch with a plastic tube going into it this could be faulty thankyou
Jan 18, 2011 | Hotpoint Aquarius WF000 Front Load Washer
Says F5 on display, wont empty.
just had F5 blockage warning on hotpoint aqualtis. Removed front panel on the bottom and unscrewed filter, cleaned and replaced. checked all outlet pipe was clear. Laid washing machine on to its back and removed black pipe from pump and checked and finally removed the other end of the pipe that joins to the drum. large ball acts a valve and a missing sock was found in the drum end! replaced all parts and washing machine works a treat! before the f5 warning the machine leaked from the door on a couple of occasions, no problem since and may have been a build up of water finding its only way out.
Jul 12, 2010 | Hotpoint Washing Machines
Washing machine is saying f 5 and wont drain or pine but it will wash
f5 means pressure switch jammed on full , check filter and pump for blockages.
Jul 13, 2009 | Hotpoint Ultima WF860 Front Load Washer
F5 BEING DISPLAYED
check pump or pressure switch
Jun 07, 2009 | Hotpoint Aquarius WD640 Front Load...
Aqualtis AQGD 169 S F12 problem Please help :-(
ok, I have just had the 'blocked pump message and after much playing around I have solved it.
Pull the machine out and take the drain out and place in a bucket. Then tilt the machine on its side about 30 to 45 degrees so you can get a hand underneath. At the front there is a black rubber pipe-squeeze this a few times and then run the machine on a pump cycle. Put water in machine (i used a bucket) and repeat. You should get the foul smelling gunk out of the pump. I did this about 4 times and finally the water comes out clean and you should be ok.
Regards and good luck,
Matt
Jul 01, 2008 | Hotpoint Aquarius WD640 Front Load...
Washing Machines Logo
20 people viewed this question
Top Hotpoint Washing Machines Experts
puggy666
Level 1 Expert
ptpumpman
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
