Question about Riso RZ390 Duplicator
Hi is it? the ink for gestetner Duplicator to be able riso Duplicator. Is the material same materials? thanks yoel
  • 55 Answers
Be aware that not all people would agree with my explanations ...
All inks for duplicators are nearly the same and therefore they are mostly interchangeable. Have a look at the DPI the ink is made for. Lower resolution ink may have bigger pigments and these may become stuck in the mesh of drum or the master. At least you have to fill the ink in an original bottle to use it. Avoid air bubbles!
Please weigh the risks before you continue. Techical difficulties may apply. So only courageous people should use foreign ink. - I have done often and my risographs still work very well!
Posted on Apr 27, 2011
Riso EZ 200E model gives error message A-01 -211
A-01-211 basically means there is master material under the position sensor while in standby. Referring to the manual open the master drawer and clamp rewind the master material back on it roll and close the lid/clamp. This allows the master unit to reset or to say "return home" action. Now open and re-insert the master material in its proper place. This is similar to A-34-218 code.
Nov 07, 2013 | Riso RZ220 Duplicator
Error A-01-211. Master roll not feeding properly.
Error type A01: Master feed error Error point 211: Master-positioning sensor in ON during standby.
OR replace it
Feb 22, 2013 | Riso RZ220 Duplicator
My riso is showing A-17 & -209
A17-209 means: Cutter HP switch is OFF when master-making starts or when master material is set in the master making unit.
Mar 24, 2011 | Riso RZ220 Duplicator
Riso EZ 200E model gives error message A-34 -218 but all seems fine at master roll installation. What can we try ?
It means to reset the master material in the master making unit. Should be ok after that.
Jul 27, 2010 | Riso RZ220 Duplicator
What does the error code E 01 stand for?risograph 4050
If its CR or TR, E-01 is main motor lock. turn off machine and hold reset button in while you turn the machine on again. Make sure your master removal unit and master feed unit are closed corectly.
Apr 07, 2009 | Riso RZ220 Duplicator
MY Duplo copy machine is DP-24SII.my problem is the ink con`t run out from the drum surface or the ink con`t transfer to my clothes
We AEBO is professional manufacturer of compatible duplicator ink and master for Riso ,Ricoh,Gestetner,Duplo.
For Risograph : RZ/GR/RA/KS/CR/RN/RP/RZ/TR/FR /GRHD/RPHD
For Ricoh: VT/JP-6/JP-12/JP-500/JP-10
For Gestetner: CPI2/CPI7/Stencil ink 217 /CP15/18
For Duplo: 504/51F4/544/744/ND 24
With high quality at economical price . We have been awarded USA SGS certificate and China Excellent Brand.
AEBO packing ,neutral and your customized packagings are all available.
Sincerely hope a pleasant cooperation with you .
meachell@chinaaebo.com
Mar 19, 2009 | Duplo DP21L Copier
Got error code e104 duplo DP-460H
Jan 08, 2009 | Duplo DP460H Copier
RISOGRAPH RN2030 THERMAL HEAD PROBLEM
I think that you should check the connectors and ground wire, and clean surface of TPH. I have not seen one of these fail completly.
Dec 31, 2008 | Riso RZ220 Duplicator
Lexmark 4039 10r
I'm pretty sure this is a printer not a copier.
Take out the cartridge and turn it upside down, you will see a (Usually) green cylinder, does it have a ring of toner, or does it appear to have been scrathed ?
Take the copy and put it next to the drum, does the lines match? Then replace cartridge.
If not open back and take out fuser ( two screws for cover and two screws for fuser, are the rollers o.k? replace fuser.
Oct 02, 2007 | Riso RZ310 Duplicator
55 people viewed this question
Top Riso Office Equipment & Supplies Experts
CheckitRight
CheckitRight
Marius Chiriac
Are you a Riso Office Equipment and Supply Expert? Answer questions, earn points and help others
