Question about HP Computers & Internet
Hp pavilion dv2000 laptop screen doesnt light up, but keyboard lights all work?
  • HP Master
  • 6,771 Answers
Hook a external monitor to the video output on the back of your laptop, if it works then you have a lcd issue with the laptop screen. Now if you have no change, the motherboard would be suspect. I recommend a professional look at it with an estimate.
Posted on Dec 30, 2010
    Genius:
  • 1,288 Answers
DV series all suffered from the famous Nvidia graphics chip failure ( I'm trying to repair one as I type).
To eliminate this though, try connecting the laptop to an external monitor and see if you get an image.
If this does not work, then I'm afraid the graphics chip has unsoldered itself from the motherboard and will need "reballing". which usually costs about £70.00.
If it does however work on an external monitor, you have 3 possible issues.
1) The screen backlight has failed
2.) The inverter has failed
3.) There is a problem with the vdu cable from the screen to motherboard.
New or 2nd hand screen is the same price as getting it reballed
2 Suggested Answers
LaptopExpert
  • 458 Answers
SOURCE: hi my laptop is HP Pavilion dv2000 And light on
You have Video Failure... As A Result Of A Faulty Nvidia Graphics Chip..
Look to See If Your Make/Model Is On HP's Extended Service Warranty, To Replace Your Motherboard At No Cost...
Posted on Dec 02, 2009
HP Pavilion Entertainment PC Laptop DV2000
when you say some times it keeps going does this mean the unit turns off ??,,,,this model has the gpu problem,,,dry solder joint of the graphics card, of which you can have the board repaired or replace the board
Oct 06, 2012 | HP Pavilion Computers & Internet
Hp pavilion dv2000 lights switch on but boot or
Hi
Thank you for your query
Please try the folowing
1) Remove ALL wires and then press and hold the power button in for approx 20 seconds
2) Plug everything back in and then rerty
This may sort the issue out however from what you are descrbing, if there is no boot or display it is highly likely the motherboard and/or the CPU is faulty
I would recommend that you book the PC into a reputable PC repair shop if the above does not work
If this has been useful please leave postive feedback/vote/testimonial - Thank You Again
Feb 15, 2010 | HP 417035-001 - HP Pavilion dv2000 Series...
I have a HP pavilion DV2000 and i changed the
Reset your memory if not in properly it will not show video. if that doesn't work then plug a external monitor in the side port. if you get video then your LCD is bad if you dont then *********** board is bad
Feb 03, 2010 | HP Pavilion dv2000t Notebook
Black screen on HP Pavilon dv2000. It does have the power from both ac adapter and battery as I can see all the lights on keyboard. I can hear the fan when press power button. Does not make any sound when...
Unplug the computer from the wall, hold the power button in for 1 minute. This will reset somehow the bios and remove any electricity left inside.If still doesnt work take a look to the cpu and heatsink
Jan 18, 2010 | HP Pavilion dv2000 Series Laptop Full...
Hi my laptop is HP Pavilion dv2000 And light on
Dec 02, 2009 | HP Pavilion dv2000t 14.1" Notebook Laptop...
Black screen
check AGP size. if its so low then extended it from ur bios setup. besides u can format ur operating system, install motherboard driver software and hope i will be solved if no hardware problems.
Jul 23, 2009 | HP Pavilion dv2000t 14.1" Notebook Laptop...
I have a dv2000. It turns on, but see no bios screen.
TRY TO GO THE BIOS SETTING THEN LOAD DEFUALT.. IF THE LOGO SCREEN NOT SHOW SOME PROBLEM FOR THE DISPLAY THE DEFAULT SETTING IS THE LOGO SCREEN WILL SHOW ON START UP THE SCREEN..
CHECK THE DISPLAY,,,, INVERTER, OR VGA CABLE,, VIDEO CARD..
Jun 25, 2009 | HP Pavilion dv6000z Notebook
My hp pavilion dv2000 lights up but screen never comes on... what do i need to do?
The problem could be with your screen. It looks like the led light of your screen is dead you could follow up this solution. I have had this same problem with a HP DV2000 and the problem is not the contrast light. What it is, is that the laptop thinks that the screen is been shut down that is why the light does not come on. The best way to solve this is to remove your keyboard first. You can remove the keyboard by removing exactly 7 screws from your laptop back, there are 5 screws located under your battery and other two that are in the location of your RAM'S. Just open them up and then you will notice that the key board pops out abit then just simply take it up and then just below the keyboard, on the same line where HP brand logo is on your machine there are two small clip types of pind, that you can remove and put back. There is a clip that is hidden abit under the metal plate, so just try and remove that clip from its place using a needle or any long and thin object. That will make the laptop not have the problem. But once you remove that the laptop constantly will think that the screen is open even if you close it. then after like a week or two you can put it back and all shall be fine if not then just remove it and keep it out. You can then set your power options to shut down the screen light every 2 minutes or something like that so as to avoid the backlight being switched on all the time. Hope this solves your problem.
Jun 08, 2009 | HP Pavilion dv2000t Notebook
Hp pavilion dv2000 notebook will not boot up
hi,
i m in Hong Kong. The stupid HP repair center charged US 90 just for inspection!!!!! They they said the whole motherboard had to be replaced, thts additional US 630 dollars, the thing is just 1.5 yr old. They also said i don get to keep the broken mother board after replacement. This is simply irresponsible, unethical, sleazy and UNJUST!!
Thanks. right now the computer is fixed for US70. when i hv time, i'll open it up and see if i can figure it out how it was fixed. The shop suggested tht the computer wont last too long. This is such bad quality for HP... Sorry, i hv to do the following for other victims to find this easily:
(can some creative netizen bring this to the public light to pressure HP to do the ethical things??)
bad quality HP. hong kong HP pavilion dv2000 series manufacture problem. HP unethical.
Sep 21, 2008 | Computers & Internet
HP Pavilion DV2000
first replace the inverter to correct the lighting problem ok. then move to the other problem both can be recovered from
so ebay dv2000 lcd inverter buy it get a screw driver link me bakerandre2000@yahoo.com
Apr 14, 2008 | HP Pavilion dv2000t 14.1" Notebook Laptop...
Computers & Internet Logo
236 people viewed this question
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
