Question about Honeywell Heating & Cooling
I have installed a Y8610U Intermittent pilot retrofit kit in my old boiler. The unit is working fine when there is a call for heat. When the unit is in the idle state the green led flases 8 times then after 5 or so cycles of this, I hear a faint beebing and the igniter engages for a couple of seconds. In the manual it refers to a low secondary voltage supply but does not give any info on the igniter. I metered the voltage and it is 24 volt in the idle state.
SOURCE: Low Voltage Wires - MSZ-A24NA Mr. Slim Heat pump
does the fan come on at all
Posted on Jan 13, 2007
  • 8 Answers
SOURCE: RCA L26W11 26 in. HDTV
try pts or vance baldwin
Posted on Feb 12, 2008
SOURCE: I have a Carrier 38tra048340
Blank screen sounds like a fried thermosat. Abrupt outages can affect certain types of thermostats. Make a jumper wire and jump across R and G. See if you get any action from anywhere. If a fan or compressor kicks in you know you have a burned out thermosat...
Posted on Jun 23, 2008
  • 85 Answers
SOURCE: will not go into defrost
Did you change the thermostat in heat pump? or did you change it when you replaced the board?
Posted on Dec 06, 2008
bunnydawg
  • 5158 Answers
SOURCE: Volt meter on 01 Dakota is low but truck runs fine
i presume you live in a warm climate for one thing. the voltage regulator appears to be going bad... the problem with that is most modern alternators have them built into the starter. you may be able to r&r that part or you may have to replace the alternator.
If i remember right autozone will test it for free tho i'm not in the states myself so i'm not sure.
Robert
Posted on Dec 16, 2008
Boiler won't fire the pilot is lit.
Flame sensor not picking up flame and won't release /open gas valve
Mar 16, 2016 | Hydrotherm Gas Fired Boiler Hvx-105 Power...
Tip
This tip is 100% correct for newer heaters that have the electronic ignition...
On a call for heat, the 24 volt thermostat sends a signal to the control module. The control module will indicate a call for heat with a light on the control either blinking or remain solid depending upon model. The inducer (exhaust) blower will purge all gasses from the furnace and pressurize a pressure switch. Once the pressure switch tells the module to continue, the electronic ignition will energize and send 120 volts to the igniter. The igniter will glow and you will be able to see it if viewed through the small inspection port. Once the igniter gets hot enough, it sends a signal to the module opening up the gas valve (24 volts). Either a pilot will come on or the burner tube will ignite then spread the flame to all burners. Lastly a safety sensor will be looking for a certain temperature within a few seconds and the furnace will continue to operate and the room air blower will turn on in a minute or two.
What could go wrong? The unit will not run if there is no signal from the thermostat (bad thermostat or broken wire), the control module does not sense a signal from the thermostat (bad control), the inducer does not energize (bad motor), the pressure switch does not close (blocked vent piping, bad switch, plugged condensate hose), the igniter does not energize (bad control, bad igniter), the gas valve does not open or there is no gas (bad gas valve, broken wire, no gas), the pilot does not light (dirty pilot), the burner does not light (bad burner, plugged orifice, not enough combustion air), the flame does not spread to each burner (bad flame spreader, dirty flame spreader, more bad burners), the flame safety sensor does not detect flame (dirty or bad flame spreader, bad flame sensor, broken wire, bad control), or the room air blower does not energize (bad fan motor, bad control).
Many newer furnaces have a diagnostic light viewed through a small window in either the top panel or bottom panel. If you remove a panel to see it, you may erase the code. If that happens, tape down the door safety switch and cycle the furnace with the panel off until the code appears again. Find the wiring diagram that is glued on one of the panels. There will be a diagnostic or error code chart that will give you a starting point where to look based upon the number of blinks the circuit board flashes.
Check out other tips at www.chandlerrepair.com.
on Jan 23, 2010 | Heating & Cooling
Have a problem with a laars boiler the pilot keeps
How long does it stay lit (if at all)? It sounds like the thermocoupler (about 10 bucks). Good luck
Dec 25, 2009 | Lite On Laars Lite 2 Heaters: 250,000BTU...
Have a problem with a laars mini therm ii boiler. the pilot keeps
hi. i have mini temp boiler 150 btu 5yers old . it is burning with know radiation .it is up to thempitio .but it will not shut off.flame is good radietor is hot ,help?
Nov 04, 2009 | Lite On Laars Lite 2 Heaters: 250,000BTU...
Dayton Heater M/N 3E227E
Hard to believe they sell a retrofit kit for a Gas furnace to a Customer....This is ahrd to advise you on with out seeing the schematic and if it is indeed intended for that furnace....the Spark mounting location is CRITICAL for safety so make sure that is correct above all.....OK The wire coming off the transformer and tied to the red wire going to the heat excghanger would most likely be a High Limit switch...cuts the gas off if the blower doesnt work etc or you would have a fire...so this switch must be in series with the transformer to cut power when the switch opens....the wire MV/PV coming from the "Electronic control box" needs to go to the New Gas Valve you should have which will have a termional marked MV/PV (Main valve/Pilot/valve) as your old one was for a standing pilot application and when you have electronic ignition you req a Gas valve for Intermittent pilot .....you should also have 2 more terminals on the valve MV and PV which will have seperate lines from the ignition control as well....basicvally there will be another wire coming from MV/PV going back to the transformer...make sure all wiring is correct and I would strongly advise you have a technician check your work before you attempt to use it....if wired incorrectly you could have a serious delayed ignition as its possible to power the main burner instead of the pilot if you wire it up wrong below is a typical spark wiring diagram....may not apply totally to your system but it will give you the general idea79f9627.gif
Oct 31, 2009 | Heating & Cooling
Honeywell s861ou 3009 intermittent pilot module, i just installed this control on my furnace. I have one wire left from my old johnson control. this wire either goes to the draft fan or the burnham logic...
What is the wire on the old control.....what terminal is it on??....When replacing old controls the new ones often have different terminals and sometimes incorporate some terminal internally etc....the Wiring Diagram included should be followed exact....if it's working fineit's likely ok....if you have any doubt have it looked at by an expert
Oct 21, 2009 | Honeywell Electronic Programmable...
Won't ignite!!!
If the igniter is not sparking on the pilot assy the pilot will not ignite all the time. You or anyone needs to see if the spark is hitting the pilot assy. be careful not to get shocked. My best recomendation would be call a professional to check unit...
Jan 31, 2009 | Heating & Cooling
Very Hot water coming out of overflow pipe
Is your boiler heating your domestic hot water if so i would turn water off to water maker and see if your boiler pressure stays down below 20 psi. If so water maker is bad. The other thing that could cause this problem would be the boiler pump is out.
Jan 22, 2009 | Protech Systems FasNSeal FSWMKE4 4" Vent...
Furnace gas pilot light keeps going out when windy outside
Honeywell makes an electronic ignition conversion kit. (White rodgers also has one but it uses a mercury switch which can be expense if it goes bad). A good service man can install the "Honeywell Y86 Universal Intermittent Pilot Retrofit Kit". This is a "complete" kit for converting a standing pilot system to electronic ignition. It includes a new gas valve, ignition cables with connectors. ignition module and a pilot assembly. It does not include pilot tubing (pilot tubing is cheap). This kit also comes equipped for either natural gas or propane. Your heating guys probably don't know about it because they are to young and not familiar with the old days. Or they just don't care and would rather sell you a furnace. I think that they just don't care. I live in Ohio I just opened up the "new" Johnstone Supply catalog. This part is "not" outdated its on page 450. Do not let these heating guys buffalo you into a new furnace. You are to smart for that! If you weren't you would have believed them and bought something you don't need. Instead of researching on the internet.
The bad news is this kit lists for $456. plus labor.
Nov 20, 2008 | Heating & Cooling
No heat!
Ger, do you get your hot water off the same boiler and it that working alright? How many zones and are they controled by zone valves (little boxes mounted on the pipes) or circulators (small pumps)?
Boiling water sounds can indicate hard water deposits in the boiler or that your aquastat is set too high allowing the water to heat up higher than it should. Check your boiler guage and let me know what temperature you are recording. Get back to me with the answers to my questions, we'll figure it out.
Nov 27, 2007 | Honeywell Programmable Thermostat Heater
Heating & Cooling Logo
93 people viewed this question
Top Honeywell Heating & Cooling Experts
Bill Long
paulcarew
Brandon Berry
Brandon Berry
Are you a Honeywell Heating and Cooling Expert? Answer questions, earn points and help others
