Question about Samsung Computers & Internet
I have a SOD14C4LN monitor when plugged in and the switch in back is turned "on" it seems to be repeatedly be "turning on" over and over, whether the power button in the front is pressed or not. It is useless in this state, I would like to get it working again!
  • 11,361 Answers
It may have dying power supply due to bad caps, that will be the first place to check.
Please learn more here:
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors: http://s807.photobucket.com/albums/yy352/budm/
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Posted on Dec 31, 2010
LCD monitor turns off
I have had the same problem as others seem to have had with the dell flat panel. After leaving the screen on for some time, the monitor brightens for a moment, then goes black, while the green light stays on. When I reboot, it works again for some time, or if I remove the cable for a few minutes and plug it back in (with monitor turned off) it will come back on...only to repeat the black screen. I have changed the power features, screen resolution, downloaded updated drivers from dell, and viewed dells troubleshooting advice on the monitor cd that came with the computer. Nothing directly advises on this problem, but I have read here and in other online message boards the exact same problem. Anyone able to fix this?
Nov 02, 2012 | Computers & Internet
The screen flickers and looks "bluish" or
If this is a screen with a removeable vga cable, try using a different cable (borrow one from a friend for an hour just to test). Then try another laptop on this monitor to see if the monitor is ok. if the monitor is ok, I would suggest that there is a bad connection between the motherboard and the vga socket (bad solder joint) You may be able to re-solder it yourself (if you're that way inclined) or a shop repair shouldn't be expensive.
Hope this helps.
Jan 19, 2011 | LG 22" FLATRON LCD Monitor
My soyo television is hooked up to cable . the 2 other televisions in the house work fine. I turned it on theis morning and got a message "no signal"
Turn off the monitor,Unplug the power cord.Unplug the cables at both ends. If is plug in to a PC ,turn off the PC.Plug the cables back and plug the power.Turn on the PC.
Dec 19, 2010 | Soyo DYLM2286 Monitor
Brand New. Plugged in, first of all buttons don't seem to respond to touch or anything. Issue: runs a "test" as far as i can tell (Analog, then Digital, then HDMI, then repeats again), then goes...
It is not seeing a good signal from your computer (that is what it is doing looking at analog, the digital, the hdmi) Could be a bad cable, or plugged into the wrong connector on the computer. Computer is on right?
Try turning off computer plug in monitor then turn on computer see if you get any reaction.
Another suggestion if your are using the digital cable, try the analog (or visa versa)
Let me know if that doesn't help.
Dec 03, 2010 | Samsung B2330H LCD Monitor
Not able to turn it on. for no apparent reason the screen was black after setting overnight. The pilot light was on. tapped the space bar a couple of times thinking the computer would wake up and desk top...
I have the same monitor & just had same problem. Did you find a solution to your problem? This is the second time my monitor has done this. The first time I had problem i unplugged it and disconnected it from pc. Plugged it into power source and blue pilot light came on then went off. I did see the LG logo on screen before it shut down. After several times doing this and pressing the power switch repeatedly it seemed to reset and recognized it was not receiving a signal and indicated this. I then reconnected monitor to pc and all appeared to work fine for several days. Now I again have same problem after sitting over night.
Dec 02, 2009 | LG W2252TQ Monitor
Samsung Syncmaster 204T flashing
Please check that all the cables are plugged in firmly on the back of the monitor and on the back of the computer.
However....
It sounds like the back light on the screen is faulty. If this is the case it is definitely a return for repair problem. You should be able to find the warrantly procedure for your area on the samsung website.
Cheers
Dave
Jun 21, 2009 | Samsung 204T 20" LCD Monitor
Dell LCD TV won't turn on
check the cable who comes from the cpu
May 07, 2009 | Dell E173FP 17" LCD Flat Panel Monitor
The monitor turns off and on repeatedly.
Is it desktop or laptop computer?
If its desktop the data cable might be loose on the back of the desktop computer.
Apr 26, 2009 | Acer Computers & Internet
LCD powers off and on repeatedly
Your monitor power supply is unstable and needs your expert attention. Check out for bad capacitors.
Apr 02, 2017 | Scanport GL 821A 17 in. Flat Panel LCD...
Computers & Internet Logo
175 people viewed this question
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
