How old is an admiral top load super capacity washer, model # LNC6764A71 ?
We got ours in 2001. So most are 10 years old.
Posted on Jan 03, 2011
Heavy duty super capacity plus
Check water level switch and associated hose, see my other posts on this solution.
Aug 19, 2013 | Admiral AW22 Top Load Washer
My model # is LNC6764A71 and won't drain. There is just a clicking sound. What is the problem? What can I trouble shoot?
This is a single belt washer. Tip it back and remove the belt. Turn the pump and see if that is what is locked up (very common) If that is fine then your main drive pulley needs to be swapped out using a thrust washer kit
service manual
Sep 11, 2011 | Admiral AW22 Top Load Washer
Hi, I have an Admiral Capacity plus washer model no LNC6764A71. Earlier today it ran fine, but now has filled and isn't running. I've tried turning the dial to another setting like agitate or...
Feel the motor. If it is real hot after it quit it could be toast. Or something in the pump could have over heated it. Take the belt off and turn the pump to see if it is hard to turn, look in it to see if something got in it. Tip the washer back and you will see this:
Check the motor shaft for play or stiffness. If it works after it cools down then the motor overload tripped it. Might be the pump might not be.
Maytag product single belt washer service manual
Jul 10, 2011 | Admiral AW22 Top Load Washer
I have an admiral heavy duty super capacity plus 2 speed. I hear a grinding sound when the washer is washing whats the problem?
load lite, and if the problem still is there let run empty a couple of times, if there is still a problem it is off track and a professional needs to go inside of it you can do it yourself but not recommended so call a pro!!!
Apr 21, 2010 | Admiral AW22 Top Load Washer
Admiral 6.5 Cu. Ft. Super Capacity Electric Dryer not drying load
does the admiral aed4475tq have a reset button it will not turn on it is only 9 months old
Nov 29, 2009 | Dryers
Won't agitate
Ours did this and it was because the bearings had busted. I called a local repair guy and he told me over the phone just by listening to the sound. Maybe you could do the same. I do know this, if it is your bearings, buy a new washer. It's not worth the repair...trust me.
Jul 24, 2008 | Admiral AW22 Top Load Washer
My admiral super capacity washing machine
remove the front panel and check the securing springs at the bottom, probably one has snapped, replace the set.
Check for dust - evidence that the snubber washer has worn also
Jun 02, 2008 | Admiral AW22 Top Load Washer
Washer Clicking/Ticking Noise
Washer is four years old. It makes a loud noise when agitating and now the drum is jammed. What can I do to fix it?
Thanks,
Apr 15, 2008 | Washing Machines
WHAT IS THE LOAD CAPCITY SIZE OF WASHER MODEL 110.20702990
On newer, and sometimes a little newer, Whirlpool and Kenmore (Kenmore is made by Whirlpool) considers a few things in determing capacity. Most of the inner baskets are the same size, but they also add in agitator action into the mix. A Kenmore with an auger top agitator would have higher capacity than a Kenmore with just a normal agitator, even though it has the same sized drum. So a super capacity washer would have theoretically less CLEANING CAPACITY than a super capacity plus. The agitator action is actually what determines capacity on these models. So, with that in mind, cubic load should be about the same on both units. Sorry that I had to go into "Bill Nye The Washer Guy" mode, but thats about the only way to describe. Let me know if I can confuse you any more haha. Seriously though, if you need further help or info, write back, and will try to get you some other information. Remember, this theory only works on top load "normal people" washers, not the front loaders.
Nov 22, 2007 | Kenmore 3.2 cu. ft. Plus Top Load Washer
Washing Machines Logo
95 people viewed this question
Top Washing Machines Experts
