Question about Philips AJ100 Clock Radio
How to swich radio band? - Philips AJ100 Clock Radio
Why won't FM radio work on the Motorola 6310 two-way radio?
It's a two way communications radio, not a broadcast radio, hence it won't receive FM/AM broadcast radio stations.
You should not confuse the two as they work on different radio bands, most FM broadcast radios are on the 86-108MHz bands, whereas two way radios operate on the following bands:
1-86MHz, 108-174MHz, 220-520MHz & 865-920MHz
I don't know which band your radio works on, but not broadcast bands I'm sure.
The only exception to this is the smaller hand helds, which may have FM broadcast programmed, but if this is the case with yours, This issue is out of the realm of two way radio queries, as Broadcast radio is not two way radio, but one way radio, and I'm not competent enough to answer Broadcast radio issues.
Cheers, Peter@FixYa Team
Nov 17, 2012 | Radio Communications
Fix my connex 3400 hb sideband button
Hi there, if you are talking about the Connex CX 3400 HP there is no sideband or SSB on this radio. It is only AM and FM 10 meter Ham radio. Many people do modify these radios to include the 11 meter frequencies which is the CB band. Maybe knowing the actual bands and their frequencies will help some too this radio does have 6 different bands ranging from (Band A. 28.015 thru 28.455) (Band B. 28.145 thru 28.585) (Band C. 28.115 thru 28.555) (Band D. 28.085 thru 28.525) (Band E. 28.055 thru 28.495) (Band F. 28.025 thru 28.465.) I hope this will help you. Bob
May 13, 2012 | Connex CX-3400hp AM/FM 10 Meter Amateur...
Can this radio communicate with cb channels?
hello unfortunetly not as these radios are resonating on the marine band which is vhf high band cb band is resonating on 27mhz ,marine band 157mhz so will not work .
Apr 02, 2011 | Standard Horizon HX471S (824 Channels)...
I need to know what each knob and switch on front of radio should be set at. i know about the squelch setting and mic gain (at least i think I do) but not sure about all the other settings for your...
To use this radio on the CB band, you set the 10 Khz switch to OFF, and then turn the band switch to A/E.
Here is a Frequency Chart.
When the 10 Khz switch is on OFF, the band switch is E,F,G,H. When the 10 Khz switch is in the ON position, then the band switch is A,B,C,D.
So when you are on band E, which is when the 10 Khz is OFF, and the band switch is in the first position, it is on the E band.
I would get your self a Frequency counter. It makes using a radio like that much easier.
Hope this helps!
Oct 08, 2010 | Galaxy Radios DX-44V 40-Channels Base CB...
What frequency do these run?? am or fm??
CB or citizen's band is in the 27 MHZ band. Its 40 channels long, AM typically, and on some models side band, or SSB.
It is only legal in the US to have a radio that operates in the 27 MHZ band on the designated 40 channels using AM or single side band only.
The MCB-30 is an AM only radio.
Mar 25, 2010 | Maxon MCB-30 40-Channels Base CB Radio
Locked radio
Visit http://www.radio-code.com/index.htm
Good luck.
Jan 02, 2010 | 2004 Chevrolet Impala
Hi i have a maxon Radio i am not sure what model it is as it does not say the model. I was wondering how i would programme the radio so that it would work on a certain frequency
if it is a CB radio, you are stuck on the 27mhz band, and the channels that it comes with. I am not familiar with maxon radio's. Some radio's the PLL chip can be controlled to shift the band the radio works on. This is still limited to the 10-11 meter bands. You can go a band up, and a band down usually.
I have no clue if this radio is capable. So I couldn't tell you how to do it.
I can tell you, that you cannot just pick a frequency and make it work on it.
Oct 24, 2009 | Radio Communications
Band selection an freq. doesnt align galaxy 33hml
sounds to me someone was tampering with it ,your best bet is to get a frequency counter and realine the radio .start from 27.185 centre band you can do this by tuning the ossolator be very careful not to damage this should realine the radio for you goodluck
Oct 16, 2009 | Galaxy Radios DX-33HML 40-Channels Base CB...
SONY VO-9800P U-Matis SP compatibility
No, this U-Matic VO-9800p ist a PAL Model, it only Records in SP and High Band Mode. If a SP Tape is inserted, it Records SPMode, otherwise High Band. Low Band Mode is only for Playback !
(Low Band Playback is of very poor Quality, do not use this for Digital DVD Captureing )
Oct 19, 2007 | Sony VO-9800 VCR
Philips AJ100 Clock Radio Logo
89 people viewed this question
Top Philips Audio Players & Recorders Experts
Gyula Lacz
 Grubhead
Grubhead
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
