Question about Frigidaire ATF6000ES Front Load Washer
Machine won't do anything and showing error 23
  • 1,772 Answers
Sorry to read about your problem, I hope this helps you out.
An E23 error code on your Frigidaire washer indicates a failure of the drain pump relay.
Depending upon the model, your washer may be under warranty for up to 25 years, so check your warranty's status before attempting any repairs yourself.
    Try to Clear the Code
  1. A power outage can cause error codes to display on the screen, even if there's no problem. Hold down the "Cancel" button for three seconds, or unplug the machine briefly to see if the code goes away. If it returns, the problem is real.
  2. Check the Pump
  3. Unplug the machine and remove the service panel. Locate the pump on the floor of the machine, to the left of the tub, towards the front. Inspect the wiring for burns, breaks or loose connections, and replace as necessary. Use only appliance-grade wire.
  4. Replace the Control Panel
  5. If the wiring is fine, the problem is a severed relay on the control panel. Unfortunately, this cannot be repaired and must be replaced. Remove the control panel from the upper portion of the back of the machine, and replace with an identical part from Frigidaire.
I tried to help you. Please help me and Rate/Vote on my response. We take the time to answer your question. take the time to rate us.Thanks and good luck
4 Thumbs - Very Helpful
3 Thumbs - Helpful
Posted on Dec 30, 2010
I am using a machine Konica Minolta 920. its showing an error of 2350 which i could not find in the list of Machine Manual can any one please help me on this.
Have you thought that perhaps contacting the manufacturer thru their website or a phone call and asking tech support , might get you some results .
Jul 29, 2016 | Konica Minolta Office Equipment & Supplies
What does error code 23 mean on the Saeco Minuto Coffee machine
I believe error 23 is a sensor error for the lever on the front of a minuto.. It cannot be repair at home and would have to go to a service center.
Service Center for Saeco Gaggia Rancilio Spidem Starbucks Espresso Machines
Jun 10, 2015 | Saeco Coffee Makers & Espresso Machines
I would like to know what Error300 means on a Canon Super G3.
there is no error 300 on this model
g3 is a fax standard---all current fax machines on the market are G3 not a machine model
Jan 12, 2015 | Canon imageCLASS D-480 - 23 PPM...
Error code 4 on baumatic bkd64ss what does this mean ?
Baumatic E4 error is caused by a float switch triggering in the sump of the machine. Anything over about 1/2 a pint in the bottom of the machine will lift the polystyrene float and the fault code will show. If the water has been caused by over enthusiastic cleaning or a drip or two over time then all that is required is for the water to be removed. For a built in machine (DISCONNECT THE POWER) then just unclip the front bottom right hand black plastic cover (behind your kitchen kickboard). Using a jcloth or similar mop up and the fault will clear. Replace the cover and restore the power and kickboard.
Feb 14, 2010 | Baumatic 23 in. BFD61SS Free-standing...
Sony DSR error code C31:30 & C31:23
Error codes definitions are bit technical and as follows...
C:31:30 error code shows problem of No FG signal when starting capstan motor.
C:31:23 error code shows problem of No S reel signal to system control.
Above info were taken from service manual and picture of service manual can be seen below...
Need further info, let me know.
Oct 28, 2008 | Sony DSR-45 Mini DV VCR
Hotpoint ultima wt741
washing machine WT741 ultima all light are flashing and it won't do anything else
Nov 12, 2007 | Washing Machines
Frigidaire ATF6000ES Front Load Washer Logo
146 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Jason Harris
Jason Harris
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
