Bosch wfo2867gb motor not turning for wash or spin, does not seem to be a capicitor problem as it will not start if you rotate it manually, how do I check the motor or brushes?
  • 8 Answers
SOURCE: remove carbon brushes from bosch washing machine
bad news im affraid mackem , depending on what motor your bosch has there is no way to change the carbons without removing the motor .
Posted on Feb 25, 2008
barkencoa
  • 3463 Answers
SOURCE: changing brushes on motor of Bosch WFL 2450 washing machine
Remove rear panel of washer, and undo 2 screws that secure the motor, lever motor back with a screwdriver or similar, and unplug motor lead.
Be sure to keep hold of the motor so it does not drop on the floor.
You will see the brushes at the terminal end of motor, remove and replace.
Plz rate my solution.
Thanks.
Posted on Jan 05, 2009
SOURCE: beko wma 510 w washing
new pump washing machine will not spin or empty. what could be the problem
Posted on May 20, 2009
nikeananth
  • 267 Answers
SOURCE: Bosch WFF1800 - not spinning
HI,
move the kicking plate on the front-bottom of the machine. You will see o circular lid there, turn it on anti-clockvise to open. All of the water blocked will come from there, be careful. Look carefully that there are some objects blocking the water draining. Then turn on the machine on draining programme, the plastic rotor should turn fastly when the machine is on. If it is not running, change the pump motor. If it is running, but machine is not draining again you can understand that there is an objeck stuck on the hose between drum and pump motor. Lay down the machine on its rear facade, you will see a large and black hose between drum and pump motor. When you remove it, you will see that there is something that blocks water running.
thank you for using fixya,rate my answer,
vijay
Posted on Oct 04, 2009
  • 50 Answers
SOURCE: bosch classixx 1000 express wont spin
Check the motor housing for an overload button, usually on the back and coloured black or red. Give it a push and if it clicks then the motor might have just been a bit stressed out and popped it.
Next two things are more serious unfortunately. The relay on the circuit board might have burnt contacts from switching the motor over the machines life, or, one of the motors windings has developed a fault. (these are both pretty rare though).
Posted on Jul 29, 2010
WFL 2260 Fills hot, fills cold, no wash action, move control to drain, empties, move control to spin, no spin but goes thro. cycle ends program door unlatches, any suggestions?
Motor brushes, worse case scenario motor complete. Run the following motor test.
1. Put main dial to off
2. Press and hold start button whilst turning dial one click to left (easycare 30).
3. When display show 8.88 or two of the progress light come on, release the start button
4. Turn dial anticlockwise to 60 cotton (take the long way, NOT thru OFF or you'll have to start over)
5. Press start
6. Motor should rotate in both directions, pump runs, motor kicks up to full spin.
7. No motor action and two lights flashing on progress lights (separated by a light that's not on) indicates a motor fault.
As suggested brushes or complete motor.
Hope this helps
Mar 27, 2013 | Bosch WFL 2063 Front Load Washer
Bosch washing machine will not spin
check belt if you can still here the motor but doesent do any thing its the belt if no noise motor
Aug 24, 2012 | Bosch Washing Machines
F43
Hi.
If you have Bosch, Baumatic, or any other machine built by Bosch, then F43 is a motor issue:
Error F43 : Motor fault: do an emergency drain through the drain access in the front bottom side (see manual). Open door and check ig the drum rotates free when spin by hand. Disconnect power before performing maintenance.
Regards.
Ginko
Sep 14, 2011 | Washing Machines
Have a Model 100 bosch washing machine will fill but does nothing after that .Doesn't seem to wanna spin or move Drum/
Try rotating the load size / water level selector switch back and forth. If this works, then your switch is going out. If it keeps on filling and doesn't stop, then your selector switch OR the level sensor (both located in compartment behind controls) is bad (probably level sensor).
The motor is locked out until the water level requirement is met, then the level switch allows the motor to be turned on.
Sep 10, 2010 | Bosch Washing Machines
F05 Fault code
this will be the motor brushes
Jul 07, 2009 | Bosch Axxis WFL 2060 Front Load Washer
Washing machine won't spin or rotate
Sounds like the motor brushes need replacing, you will have to remove the motor to do this.
Hope this helps.
Please leave feedback.
Nov 29, 2008 | Bosch Axxis+ WFR 2460 Front Load Washer
Bosch WFMC2100UC Washer stops in mid-cycle
Hi, it seems its about time to replace the motor carbon brushes.
Thanks
Aug 31, 2008 | Bosch WFMC2100UC Nexxt Essence Washer
Bosch WFMC3200UC
I'm having a hard time understanding what is happening with my Bosch. Mine is filling and then immediately emptying out. Then the door unlocks but the timer indicates 45 minutes left (or so) and the door lock light is still on. Usually the only cycle that spins now is the spin cycle, but this doesn't help me get the soap out of the clothes still in the drum.
When the machine fills but doesn't rotate, the water level seems low as well. I had a repair man out who thought it might be the door latch sensor needing replacing (honestly, my toddler was pushing that button repeatedly), but I don't think that's it.
What does work: I unplug it for a while. Then if I'm lucky and the laundry Gods are shining down on me, I can wash normally (usually I'm luckier on Permanent Press but I always used to use the Cotton side). However, once I turn the machine "off," that's it all the problems persist so I have to wash it all, one load after another.
Jul 25, 2008 | Bosch Nexxt Premium WFMC6400UC Front Load...
Drum will not rotate or spin
oooops - the motor was stuck under the carriage. Once
moved it came off easily.
Jun 17, 2008 | Bosch WFK 2401
Washing Machines Logo
Top Washing Machines Experts
