Question about Vacuums
Fan and light buttons are pushed in and won't come back out.
  • 56 Answers
Try spraying them with some of that compressed air we use on our computer key boards. Don't spray anything that may be flamable or contain anything that will conduct electricity.
Posted on Dec 30, 2010
Red exclamation light is on and brushes not turning
On my Electrolux Precision, the exclamation light indicates that it detected an obstruction and will stay lit until the obstruction is cleared AND the "reset" button is pushed. The reset button is on the black part (same side as the exclamation light) about half-way back on the side of the vac.
Apr 17, 2013 | Electrolux Vacuums
My Electrolux Rapido wet&dry won't start. The battery is empty and the blue light flashes when I plug in the charger.
this sounds totally silly but is the power button on the vacuum actually off? Had the same problem, where the battery was completely empty i didn't know my son had switched the vacuum on put it on charge and the light was flashing. I took it off the charging stand pressed the power button then put it back....now charging perfectly. Anyone who doesnt have this appliance will think you sound stupid but its just a clicky button so visually the button looks the same on or off.
Apr 04, 2013 | Electrolux Zb4106wd Rapido Wet And Dry...
The vacuum won't turn on. Overheat light and filter lights alternately flashing.
some motors have a reset button that has to be pushed to get power back to motor after over heat. it is ussually located near the rear of the motor
Oct 20, 2012 | Electrolux EL7020A Oxygen 3 Ultra Canister...
Is there a reset button for Kirby G6?
One set button on your Kirby. Remove the head to check for blockage in the fan.
Aug 14, 2012 | Kirby G6 Bagged Upright Vacuum
Why won't my Rival vacuum sealer vacuum?. It just hums when I push the vacuum button.
see the next steps and follow with common sense: God bless you
If the noise is coming from the motor area it may be a broken fan blade, if it's broken replace it. If the noise is coming from the brush area then it may be a defective brushroller bearing or brushroller, if either is defective it needs to be replaced.
Inspect a) power cord b) outlet wall c) thermal FUSE very important.d) see any debris see diagram attached.
Jul 27, 2012 | Vacuums
Dyson DC 25 power switch replacement
It a fairly straightforward procedure. Remove the accessory hose to expose 4 torx screws from behind that hold the front switch cover in place. After removing the screws, gently pull the front switch cover and carefully pry two plastic tabs apart using a small screwdriver that "snap" cover in place. The switches will be exposed. The electrical connectors each have a tiny lock button at the base of the terminal that you need to push to remove. Otherwise they won't pull off easily. Assembly is reverse with one note: You'll have to hold the plastic cover and push buttons together so they don't fall out as you place the the cover back on. Once you get it on, the plastic tabs will hold until you install the torx screws. Be sure to retest the push buttons to make sure there was no binding in reassembly.
If I may add one more thing- I believe all DC25's carry a 5 year warranty and switch failure is covered. I replace these routinely. If you call Dyson, they will likely refer you to an authorized repair center for replacement at no charge.
Regards
Feb 16, 2012 | Vacuums
I removed the power head and when I connected it back, it won't work. Is there a reset button?
No, you just need to clean the connections - or make certain you have a good connection.
Nov 18, 2011 | Fantom Vacums Lighting Canister Vacuum
How can you set the Caixing CX-2158 to 12 hr time instead of the military time?
for clock settings
Clock buttons from the left.
[1] Set
[2] Shift
[3] Modify
[4] Alarm
[5] End
[6] Reset - (use paperclip to push button in hole.)
Light indicators
[A] A.M.
[C] P.M.
[B] Alarm(s) active.
[D] Hour Notice
To set time and date
1.Push SET, push SHIFT to transfer from YEAR to MONTH to DAY to HOUR to MINUTE
2. Push MODIFY to change to desired value in every field (blinking)
3. Press SET or END to save.
To change from 24 - 12 hour format
1. Press MODIFY continously for about 3 to 5 seconds
NOTE: in 24-hour format, both the A.M and P.M light is OFF
TO SET ALARM
1. Push ALARM, and alarm setting number 1 will show, push ALARM again to show alarms up to 8 or 9 (depending on model)
2. When desired alarm number is chosen, Press SET
3. Push SHIFT to transfer from HOUR to MINUTE
4. Push MODIFY to change desired value in every field( blinking)
5. Push END to save, (Please note Red ALARM light will lit)
TO CANCEL ALARM
1. Push ALARM until the desired alarm to cancel is shown.
2. Press MODIFY ( the dispaly will show --:--)
3. Press END (NOTE: Alarm light would only turn off only if all alarm is cancelled)
TO SET HOURLY NOTIFICATION OFF AND ON
1. Push MODIFY button once (hour notice light would lit) - hourly notice is turned ON
2. Push MODIFY button again (hour notice light is off) - hourly notice is OFF
Oct 01, 2011 | Vacuums
The light on a fan is flickering. It doesn't appear to be the light bulbs. This fan has a remote control and it controls the fan OK and turns the light on and off but it flickers. What could be...
Try changing or testing the batteries in the remote or take the remote out of the fans range. See if this stops the flickering. It can also be the individual bulb. Sometimes the monofillament wires become loosened. It won't hurt the fan to use a broken bulb but it will shorten the life of the bulb. They do get the daylights shook out of them! If all the bulbs flicker it can be the twist connects. These are located under the ceiling plate cover. To check, shut off the fan or turn off the braker switch to make sure you don't get a shock (but I really doubt it). Remove the face plate ceiling screws to expose the wiring. There should be a black and a red cap that holds wires together. Black is ground red is power. One at a time hold the wires of the black cap with one hand and give the cap a gentle clockwise twist with your other hand to see if they need tightening. Repeat with the other colored cap. Push the wires back up inside the housing if needed and replace the cover.
These are the simpelist things to try before calling an expert. I hope this helps?
Sep 22, 2011 | Vacuums
Vacuums Logo
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
