Question about Logitech Notebook Cooling Pad N100 Model 939-000119 CPU Fan
I have a logitech cooling pad n100 that just stopped working
4 Suggested Answers
Crenshow
  • 250 Answers
SOURCE: My logitech cooling station stopped working! The
Hi, I suggest you to contact the Logitech support for a replacement this is an hardware failure and it's covered by
warranty terms.
If you are not under warranty you still can contact them as I know for instance in Europe they can offer you some
good deal on nowadays products for out of warranty people.
US/Canada support: http://www.logitech.com/en-us/contact
European support: http://www.logitech.com/en-gb/contact
Thanks and have a nice day ! J -
Posted on Jun 15, 2010
  • 105 Answers
SOURCE: I just bought a cooling
Hi Andries, I would suggest to try on different usb ports, but you've already did on two laptops and i don't think possible all of their ports are not working.
I can say that the N110 is often thought not to be working because it's really really quiet and as for keeping low consumption levels the fan doesn't move a big deal of air, so it may seems switched off also if it's working. Anyways, if you double check and see it's completely off don't waste your time (also because there are NO switches on it, it's supposed to work instantly when you plug it) the only thing you can do is to bring it back to your retailer and get a new one or ask for a refund. Regards, Peter
Posted on Aug 06, 2010
bronk50
  • 27725 Answers
SOURCE: my logitech N100 cooling
first check the connetions at both ends of your cooling pad make sure the connection into your laptop is securely seated and its not faulty
click start control panel administrive tools computer management device manager scroll down universal serial bus controllers you could see a yellow question mark?
right click to reinstall drivers
if you can see your usb pad but its not working
ports(com&lpt)right click update driver if this fails to fix the problem
check the USB leads that attach to the motherboard usually red white green black make sure they are securely seated and have no dust build up on them dust will cause static and a lot of unforeseen problems for a computer and its parts
click start control panel administrive tools ,computer management ,device manager look through all of your devices if you see a yellow question mark?or exclamation mark ! or red x
hope this helps
Posted on Jun 01, 2011
How do I disassemble my logitech cooling pad for cleaning?
Hi, I just did clean my logitech pad without any sratch. Here is how I did dissemble it.
There are 10 screws. 3 at the back of the pad, which can be removed very easy. Another 7 are under the shiny plastic part with whole for the airflow in front of the pad. It is easy to remove it. I used a wrapping ribbon (the ordinary for wrapping presents) and put it through the wholes in the top middle part of the cover, in the way you end up holding both ends of the ribbon. And gently pull the cover apart of the pad. It goes quite easy. Then remove the 7 screws (2 are hidden in the wholes with the white plastics)...and you can start cleaning. I did not remove the fen part itself. Its easy to clean it with an old toothbrush.
I hope this helps.
Feb 24, 2012 | Logitech Notebook Cooling Pad N100 Model...
My logitech N100 cooling pad has stopped working
hope this helps
Jun 01, 2011 | Logitech Inc 939-000119 N100 Cooling Pad...
How do i install web cam driver for 3000 N100
Try on this page for Lenovo 3000 N100 drivers:
http://www-307.ibm.com/pc/support/site.wss/migr-63572.html
If I could be offurther assistance, let me know. If this helps or solves the issue, please rateit and give a testimonial for my response.
Mar 05, 2011 | Logitech QuickCam Express Web Camera
The laptop is overheating and the fan is extremely loud. should i return it?
Hello
Are you keeping it on your lap? on a flat hard surface? or what? Most people use a laptop cooling pad. I do. The one I use is a logitech one and it works great.
Here it is on amazon.com: http://www.amazon.com/Logitech-Notebook-Cooling-Green-Accent/dp/B001U3ZH7W/ref=sr_1_1?ie=UTF8&qid=1296929244&sr=8-1
If that does not work then you can contact lenovo at the number listed for your country below: http://www-307.ibm.com/pc/support/site.wss/document.do?lndocid=MIGR-68585
or you can return it to the place you bought it if its within the time limit and you have a receipt. Most likely tho it just needs a cooling pad so it can breathe and get some air.
Feb 05, 2011 | Lenovo IdeaPad U160 Laptop Computer...
I have a Logitech cooling pad for my Dell 17" Studio laptop with 4 GB RAM and Vista Home Premium. It mysteriously stopped working. When I plug the cooling pad in other laptops, it works fine. I have...
Seems that your laptop's USB ports are not providing enough power to the cooling pad. This could be due to you connecting too many USB peripherals to your laptop. Test if you can get the cooling pad to work by disconnecting all other USB devices.
As a permanent fix, you can buy an active USB hub (one powered by external power source) & connect your cooling pad to it.
Dec 18, 2010 | Computers & Internet
I just bought a cooling pad Logitech n100. The usb-cable is connected correctly to my notebooks (I tried it with 2 Dell laptops, the Inpiron 640m and the Latitude E6500), but .I don't see the fan spinning
Aug 06, 2010 | Logitech Notebook Cooling Pad N100 Model...
My logitech cooling station stopped working! The fan for my logitech usb cooling pad N1000 stopped spinning and now my laptop is overheating. Is there anyway to fix this? Do I have to get a new one?
warranty terms.
Jun 15, 2010 | Logitech Notebook Cooling Pad N100 Model...
Spare feet for logitech ex110
Suggest anyone who has this problem pick up a pair of 'laptop legs'. They're designed to prop up laptops to improve cooling, but they do the trick.
E.g.:
http://cgi.ebay.com.au/Notebook-Netbook-Laptop-Cooling-Cooler-Ball-Leg-pad-/360269274791?cmd=ViewItem&pt=LH_DefaultDomain_0&hash=item53e1b8dea7
May 17, 2010 | Logitech EX110 SP CORDLESS Keyboard/Mouse
My logitech game pad shifts my mouse pointer erratically
Hi, This seems to be a USB bandwith issue, do you have printers, scanners, external HDD connected to your computer ? If yes please unplug them and see if it works better. If not, try only to unplug the Dual action, and see, if it stops behave this way, then you might want to uninstall LGS and reinstall it.
Thanks and have a nice day J -
May 03, 2010 | Logitech Dual Action for Pc (963292-0403:)...
Logitech Notebook Cooling Pad N100 Model 939-000119 CPU Fan Logo
1,540 people viewed this question
Top Logitech Computers & Internet Experts
micky dee
Are you a Logitech Computer and Internet Expert? Answer questions, earn points and help others
