Question about LG Studioworks 77M Monitor
My screen just go into shtink mode with three lines vertivcal across the screen. The screen then 1/3 of normal size....Divisions look like beams from the inside of monitor...
    Genius:
  • 1,288 Answers
If your graphics card is working ok, this is almost certainly an internal fault in the monitor. Not sure exactly what the cause is.
Posted on Dec 30, 2010
What can i do to fix the Acer Aspire BlackScreen Problem for the internal Screen?
Screen problems on laptops come down to three issues. Most common is the inverter, next is the cable that connects the screen to the motherboard and last is the motherboard. If you can see the image on the screen with a flashlight, it is not the cable or the motherboard.
Mar 03, 2017 | Acer Aspire Computers & Internet
Split screen, kind of inverted w/white wavy lines
It is a calibration problem, let me see if I can find some schematics for your tv.
Jul 19, 2008 | Panasonic CT-32SL14 32" TV
My screen when starting up Modern Warfare 2 and 3 (Not Sure About 1, Dont Have It) All have a black line in the middle, and its split up into two divisions, but not equally, therefore preventing me from...
Sounds like your game is loading in split screen mode, or you system in trying to render the game twice on the same screen, replace game, or get system serviced.
Aug 04, 2013 | Video Game Consoles & Games
Error sc 329
This is for a Ricoh copier. You did not indicate machine.
SC 329: Laser Beam Pitch Adjustment Error
The LD unit home position sensor does not detect an on condition while changing the LD unit position for correcting the LD position or changing the DPI.
Instructions from the Service Manual below...
5.4.3 LASER BEAM PITCH ADJUSTMENT
There are two laser beam pitch adjustment procedures: one for 400 dpi, and one
for 600 dpi. These adjustments use the following SP modes.
· SP2-109-1: Laser Beam Pitch Adjustment - 400 dpi
· SP2-109-2: Laser Beam Pitch Adjustment - 600 dpi
· SP2-109-3: Laser Beam Pitch Initial Setting - 400 dpi
· SP2-109-4: Laser Beam Pitch Initial Setting - 600 dpi
· SP2-902-2, no.12: IPU Test Pattern - Cross Stitch - 400 dpi
· SP2-902-2, no.13: IPU Test Pattern - Cross Stitch - 600 dpi
1. Perform SP2-109-8 (Beam Pitch Data Reset).
2. Input the value for 400 dpi that is printed on the LD unit into SP2-109-1.
Use the value printed after "P" on the new LD unit as shown below.
NOTE: Do not use values printed after a "V".
(These value numbers are on a sticker inside the machine with a UPC code on it. The numbers are just under the UPC barcode. And example number looks like this: "15980300151P: 120, 172", so the example 400 dpi value here is "120".)
3. Press the "Enter" key.
4. Perform SP2-109-3.
5. Print the 400-dpi test pattern onto A3 (11"x17") paper using SP2-902-2 no.12
(cross stitch). (See Service Tables - Test Pattern Printing - Section 4.2.3, pasted below.)
6. Write the value of SP2-109-1 on the test pattern which was input at step 2.
7. Change the value of SP2-109-1 and print another test pattern, repeating steps
2 to 5. Print about 5 patterns with different values for SP2-109-1 (e.g. "48", "96",
"192", "240").
8. Check this test pattern. If the laser beam pitch is not correct, the image looks
like a black vertical stripe pattern.
NOTE: If the laser beam pitch is correct, the vertical stripe is not so noticeable.
If the value is not correct, the vertical stripe pattern is darker.
9. Adjust the laser beam pitch position until the thin lines are of uniform thickness
(no striping effect should appear on the printout), doing steps 2, 3, and 4. (In
step 2, input a value which is estimated to be correct, then do steps 3 and 4,
then if necessary go back to step 2 and try another value.)
10. After adjusting the laser beam pitch for 400 dpi, adjust the laser beam pitch for
600 dpi, using the same procedure as for 400 dpi (use the SP modes for 600
dpi).
4.2.3 TEST PATTERN PRINTING (SP2-902)
NOTE: Do not operate the machine until the test pattern is printed out completely.
Otherwise, an SC may occur.
1. Access the SP mode which contains the test pattern you need.
2. Press exit, then touch the "Copy Mode" key on the operation panel to access
the copy mode display.
3. Select the paper size.
4. Press the "Start" key to print the test pattern.
5. After checking the test pattern, exit copy mode by touching the "SP Mode" key.
Reset the test pattern to 0.
6. Exit the SP mode.
Test Pattern Table (SP2-902-2: Test Pattern Printing - IPU)
No. Test Pattern
0 None
1 Grayscale 1
2 Grayscale 2
3 Grayscale 3
4 Grayscale 4
5 Grayscale 5
6 Vertical Lines (256-greyscale) 13 Cross Stitch (600 dpi)
7 Vertical Lines (1-dot)
8 Vertical Lines (2-dot)
9 Hatch Pattern
10 Cross Pattern
11 Slant Pattern
12 Cross Stitch (400 dpi)
Test Pattern Table (SP2-902-3: Test Pattern Printing - Printing)
No. Test Pattern
0 None
1 Vertical Line (1-dot)
2 Horizontal Line (1-dot)
3 Vertical Line (2 dot)
4 Horizontal Line (2-dot)
5 Grid Pattern (Single-dot)
6 Grid Pattern (Double-dot)
7 Alternating Dot Pattern
8 Full Dot Pattern
9 Black Band
10 Trimming Area
11 Argyle Pattern
12 16 Grayscales (Horizontal)
13 16 Grayscales (Vertical)
14 16 Grayscales (Vert./Hor.)
15 16 Grayscales (Vert./Hor Overlay)
16 Not used
17 Horizontal Line (1-dot)
18 Grid Pattern (Single-dot)
19 Grid Pattern (Double-dot)
20 Alternating Dot Pattern
21 Blank Page
These adjusments listed in the manual require removal of a service panel and mechanical adjustment of the laser mounts, so it should be done by a qualified technician.
However, these test procedures can indicate whether or not this is the problem with your printer.
Sep 05, 2012 | Office Equipment & Supplies
Vizio 42 in TV LCD HDTV white line across to of
That white line (usually jagged) is actuallly part of the transmitted picture. However, you are not intended to see it because it is located in what is known as the 5% overscan area. Your TVs today are more than just cable ready... they are a versital, technology filled multimedia display. You can see that line because the screen size or wide mode you are using is intended for 1080p/24 signals. You have 0% overscan with this screen size setting. This allows you to see ALL of the picture, including portions of the picture the broadcaster did not intend for you to see. You can change your screen size using the Wide feature in the Setup menu. See pg.62 of your user manual for details and descriptions of the various wide modes.
Mar 14, 2010 | Vizio VW42LF 42 in. LCD HDTV
SAmsung has two white lines across screen with no picture
If the 2 white lines are in the centre of the screen it sounds like you have a fault called 'field collapse' . The 'x' or horizontal circuit on the tv deflects the beam across the screen which in your case is ok because the line runs across the screen ok. The 'y' or field circuit on the tv deflects the beam down the screen. Without a circuit diagram for your tv i cannot point to individual components.
Aug 07, 2009 | Samsung Televison & Video
I have a toshiba tv 27 with a line across the middle of the scree
Definitely not. You have the symptom called 'field collapse' . What happens is a beam of excited electrons is traced across the screen and when it reaches the end the beam flys back and traces the next line down. Because you have a line across then the beam is scanning across but the field circuit isnt making the beam move down as it traces across a new line. The fault lies either in your field deflection driver chip or...the power supplying it has disappeared at around 27 volts..or the booster or voltage doubler circuit connected to the chip has goe faulty.. Another fault could be the yoke connection b roken but hardly likely unless youve dropped the tv at some point :)
Aug 03, 2009 | Toshiba Televison & Video
SC 329 code Aficio 550
· SP2-109-1: Laser Beam Pitch Adjustment – 400 dpi
· SP2-109-2: Laser Beam Pitch Adjustment – 600 dpi
· SP2-109-3: Laser Beam Pitch Initial Setting – 400 dpi
· SP2-109-4: Laser Beam Pitch Initial Setting – 600 dpi
· SP2-902-2, no.12: IPU Test Pattern – Cross Stitch – 400 dpi
· SP2-902-2, no.13: IPU Test Pattern – Cross Stitch – 600 dpi
Use the value printed after “P” on the new LD unit as shown below.
NOTE: Do not use values printed after a “V”.
3. Press the “Enter” key.
5. Print the 400-dpi test pattern onto A3 (11”x17”) paper using SP2-902-2 no.12
2 to 5. Print about 5 patterns with different values for SP2-109-1 (e.g. “48”, “96”,
“192”, “240”).
dpi).
2. Press exit, then touch the “Copy Mode” key on the operation panel to access
4. Press the “Start” key to print the test pattern.
5. After checking the test pattern, exit copy mode by touching the “SP Mode” key.
Test Pattern Table (SP2-902-2: Test Pattern Printing – IPU)
No. Test Pattern
0 None
1 Grayscale 1
2 Grayscale 2
3 Grayscale 3
4 Grayscale 4
5 Grayscale 5
9 Hatch Pattern
10 Cross Pattern
11 Slant Pattern
Test Pattern Table (SP2-902-3: Test Pattern Printing – Printing)
No. Test Pattern
0 None
8 Full Dot Pattern
9 Black Band
10 Trimming Area
11 Argyle Pattern
16 Not used
21 Blank Page
Dec 12, 2008 | Xerox WorkCentre 490CX All-In-One InkJet...
Olevia 32 inch. The picture is larger than the screen.
You should have a screen resulation menu and a vertical size (high) control also on the r/c[remote control] menu.
If not you could have a vertivcal (electrical) problem. Let a technician take a peek at it.
Nov 11, 2008 | Olevia LT42HVi 42 in. LCD Television
White lines across TV screeen
if these lines are just at the top of the picture then i would suspect an electrolytic capacitor in the vertical circuit.
May 08, 2008 | Televison & Video
LG Studioworks 77M Monitor Logo
Top LG Computers & Internet Experts
Alun Cox
Are you a LG Computer and Internet Expert? Answer questions, earn points and help others
