Question about Metz Mecablitz 60CT4 TTL Flash
My Metz units have sat a long while. I now need them again and and have fresh batts but I guess my capacitor is going it takes about 14 seconds to recycle from discharge to full power on manual. I would like to replace the capacitors but they have no stats on them. all I see is "Frako, Kapazitatskonstant, 333 39 0010-1, 87 26" can some one tell me a suitable replacement? or what the V and uf was for this capacitor? Thank you Dave
    Problem Solver:
  • 14 Answers
About 8 seconds is normal. Metz actually instruct owners to discharge the flash at full power every month to preserve the capacitor, which you haven't done. I confess I don't always do that either. But just fire it off till the battery goes flat, and then recharge and try again. This has always improved the performance when I have done it. Basically, they like to do heavy work, and like muscles, get better for it. That sounds silly, but it is true. There is an electrochemical explanation. As you are not sure what capacitor to use, I would recommend taking the unit to Foto Reisel in Sydney if it is near you. They can get the unit serviced for you. You can also send an email to Metz. They understand English, and if servicing the unit is difficult in your location, and you sound capable of fixing it yourself, they may sell you or tell you an equivalent part. BE CAREFUL THOUGH. THAT THING CAN EASILY STOP YOUR HEART!
Posted on Jul 15, 2008
    Champion:
  • 254 Answers
Capacitor is no longer available or being sold.
The people that designed this great flash have retired and passed away.
I am one of the few that's still around.
atdlee@netzero.com
Posted on Oct 08, 2012
Metz 44AF-4C ready light will not come on or flash,all others functions work
If the unit will flash at all then you may be able to "re-condition" the capacitors or condensers. If so, then make sure you have a fresh set of batteries and trigger the flash in manual mode full light. As the capacitors heal and are able to hold more energy the light output will increase. If you are able to recover them then the voltage level will increase to where the light comes on. Otherwise they likely need replacing and this is work best left to a technician. This work is also expensive so you need to decide if it is worth it or simply replace the unit. Good luck.
Feb 24, 2014 | Metz Mz 54434c 44af-4c Flash For Canon...
Have to manually reset constantly the Metz 76 MZ-5 with SCA 3202 unit.
ya you can try the Metz p76 battery pack this will overcome the problem
May 16, 2008 | Metz mecablitz 76 MZ-5 TTL Flash
METZ 60 CT-4 batteries and capacitors
Although you can still get lead acid batteries from Sonnenschein (the original oem manufacturer) for the Metz CT60 units, a better choice are the Lithium ferrite phosphate or Lithium ion batteries, now available on ebay. For example sales8phd on ebay sells a drop in replacement 6 or 7Ah battery with a charger for ~$75. In general these batteries produce more flashes per charge than the lead acid oem batteries,particularly when shooting a lot of flashes in rapid sucession.
Jun 01, 2010 | Metz Mecablitz 60CT4 TTL Flash
I cant push the SAT button to control the satellite
Try pressing and holding the SAT button for about 6 seconds to see if it lights up, if not remove batts and hold SAT in till lights go out then replace batts and try again. your remote may need repalced if you have good batts and sat will still not light up.
Nov 30, 2009 | DISH Network IR Remote Control
The lens wont go in and when i turn on the camera, it dies within seconds. how do i get it to work again?
Make sure that you are installing a fresh/ full charge battery
Remove the battery
Clean the metal contacts on the battery using a clean cloth
Pls test with an alt. batt.
If you do not have access to a dif. battery.
Pls. take the batt out of the camera. Insert the charger into the unit from the main socket and turn the camera on. If the camera works you will need to replace the batt. If not you will need to order a No power repair.
Contact KODAK:
http://www.kodak.com/eknec/PageQuerier.jhtml?pq-path=14563&pq-locale=en_US&_requestid=3490
Nov 11, 2009 | Kodak EasyShare M1033 Digital Camera
I have not used my Metz 45ct-5 flash for over a year.
You may have to install new batteries, a few times. The Capacitor will **** the life out of the batteries as it builds up its charge. I have a Hasselblad D-Flash 40 this happened to. Bought as Mint. Not used in over 1 year. When I received it, I was absolutely pissed that I bought more ebay junk. But, I persisted. I think I went through 30 batteries, before the Capacitor rejuvenated itself. Try. Best of luck.
Apr 05, 2009 | Cameras
Metz CL-4 recharging problem
Some info about batteries.. I've successfully used both NiCd and NiMH batteries loose in the alkaline holder, and in rebuilt old NiCd battery packs, in my 45CL-4. There doesn't seem to be any difference in performance or recycle time with either type of battery, but NiMH give more flashes, as they are higher capacity. The normal Metz charger is ok for NiCds, but isn't the best for NiMH, which need to be charged by a peak-detection charger. When NiCd and NiMH batteries are fully charged, their voltage reaches a peak, then drops slightly, The charger detects this drop and turns off. NiCd can stand some overcharge, but NiMH will be damaged if overcharged or overheated. I charge NiMH when taken out of the alkaline holder, in a special charger designed for NiMH. In the rebuilt packs, I charge NiMH directly onto the battery contacts, which is the top when it's in the flash gun. I use a piece of circuit board with two 3mm screws to reach the contacts, connected to a NiMH charger, and a rubber band to hold it on. It sounds funny, but it works well. I recently did a wedding and used only one 900mAh NiCd pack and one 2500mAh NiMH pack, for over 2000 shots. I used the Metz 45CL-4 on a Canon 40D.
Nov 10, 2008 | Metz mecablitz 45 CL-4 TTL Flash
Recycling time
Buy any capacitor with same rating and with or higher working voltage.
atdlee@netzero.com
Apr 06, 2008 | Metz Mecablitz 60CT4 TTL Flash
Electronic flash capacitors
Maybe I can help.
Is it the main capacity?
atdlee@netzero.com
Dec 10, 2007 | Cameras
Metz 60-4 flash takes much longer than normal for the ready light to come on to allow me to take another photo.
It is likely the capacitor in the battery pack. If they are not powered up every month, they dry out resulting in long power up and recycle times. You'll need to get it replaced to rejuvenate your 60 CT-4 to its original spec.
Oct 06, 2006 | Metz 60CT-1 Flash
Metz Mecablitz 60CT4 TTL Flash Logo
365 people viewed this question
Top Metz Cameras Experts
Doberman
Neil
Level 1 Expert
Are you a Metz Camera Expert? Answer questions, earn points and help others
