Question about Husqvarna "Chain Saw - 16" Bar, 3 Hp
Chainsaw not developing a spark - Husqvarna "Chain Saw - 16" Bar, 3 Hp
    Brigadier General:
  • 4,088 Answers
Remove the left side cover after trying a fresh spark plug (gapped at 0.020") with no results. This will expose the flywheel and ignition module. Remove the stop switch wire from the module body and retry for spark. If you get spark, check the switch wire and the switch itself for grounding. If still nothing replace the ignition module using a thin business card for a gap gauge. Turn the flywheel magnets under the module poles, insert the card into the pole gaps, loosen the module screws to allow the module to contact the magnets. Tighten the screws and turn the flywheel somewhat to release the card. Turn the flywheel one full turn to make sure the gaps don't close further. Hope this helps!
Posted on Dec 30, 2010
One cylinder keeps cutting out and in and it is not the spark plug.
is this question about a two cylinder saw ? if so its an oldie but I like em !! seems that two cylinder 2 strokes can develop points issues that fire the coil twice on one cylinder only (sometimes saw will run , with little power) , ck points time, this assumes of course that you've got a single coil with two wires exiting it , dual coil saw? id ck the coil that doesn't fire with a ohm meter
Jul 23, 2015 | Garden
Poulan chainsaw not getting any spark???
you might have a broken wire to the spark plug. Use a meter to check continuity on the wire.
Aug 08, 2014 | Poulan 16" 38cc Gas Chain Saw P3816
How do you check the spark on a Husqvarna 240 chainsaw?
Buy yourself a spark tester from the local chainsaw dealer, these will clip to the cylinder to create an earth, the plug cap fits to the end, it will have a large gap to load the ignition unit, if there is a spark when the engine is cranked the unit is ok.
Aug 08, 2013 | Poulan Pro 42CC 2 Cycle Chainsaw, 18"
Chainsaw will only run with choke on and cant get it to idle back
there is a jet inside the carb that is plugged up leaning it out
Aug 18, 2012 | RTO Spur Sprocket For Stihl 017, 021...
My poulan saw will only run for 30 seconds and then quits. It ran for about 30 minutes before developing this problem. Plug is dry with tan color. Air filter is clean.
Try a few simple things first, clean the air filter, remove and replace the filter inside the fuel tank on the end of the fuel hose,check the fuel hose up to the carb for cracks and leaks, fit a new spark plug.
Jun 27, 2011 | Poulan 14" Chainsaw
Gas leaks out of poulan 3400 counter vibe chainsaw handle.
The fuel tank is integral with the plastic housing of the saw. A leak has obviously developed, I would say its time to replace the plastic housing and go from there.
May 29, 2011 | Poulan Pro 16-Inch 38 cc Anti-Vibration...
Husqvarna Chain Saw Rope Pulls Very Hard, what is the cause?????????
Has it always done this or has it developed?
Some saws have a decompression button to make it easier to pull over.
Oct 03, 2008 | Garden
Husqvarna "Chain Saw - 16" Bar, 3 Hp Logo
136 people viewed this question
Top Husqvarna Garden Experts
Jim Parker
Jim Parker
Phil Walker
Phil Walker
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
