Question about Pioneer Audio Players & Recorders
My Pioneer PL-220 turntable was spinning too fast after I took it apart and put it back together. Upon re-opening it I found the two trimmer pots that access through the top of the table (under the platter) to have been broken (by me using too much force, I am sure, when screwdriving them). Also, a nearby pawn shop said there may have been a magnet(?) that might have come loose from the turntable that helps the speed control. Is this something you know about? Great help is appreciated! Thanks!
5 Suggested Answers
  • 45 Answers
SOURCE: Pioneer turntable Pl-560 and Pioneer Receiver VSX-D409
No phono inputs?? You will need a phono to line level preamp to use aux input.
Posted on Nov 05, 2007
  • 105 Answers
SOURCE: motor for pioneer Pl 120 turntable
Start with eBay, craigslist.org, perhaps local Goodwill store. It might be easier to just by another turntable that is not in fantastic shape but has a working motor...then swap.
Posted on Mar 28, 2008
SOURCE: Low volume from Akai turntable attached to Pioneer Surround Sound Receiver
If you receiver doesn't have phono inputs,you will need to buy an inline phono amplifier.Phono inputs have a built in amplifier,all others don't.Try Crutchfield.com.If they don't carry them,they will tell you who does.
Posted on Jan 27, 2009
  • 4234 Answers
SOURCE: have a teac p-a 400 turntable,that was just given to me. i see a rubber pad that goes on top of turntable, the turntable made out of metal, and a oversized rubber band. I put the rubber band around th
I'm guessing that the belt is too large (stretched). Normally it should be small enough to stay on the platter itself. Install the platter and place the belt around the motor hub (white plastic), If the belt is too loose, it will just sit and not turn the platter. Try a new belt first as that is the least expensive option to try.
Keep us posted.
Dan
Posted on Apr 13, 2009
19samtann61
  • 12 Answers
SOURCE: Pioneer pl 50 turntable it
Try changing out the capacitor on the underside of the platter. They will lose their rated value over time.......
The schematic shows a 1000 volt rating. I have three that I am referbing and all of them came from Pioneer with a 450 volt CAP.
Try replace it with one that is rated at least 450 volts.
Also - the closer the tolerance the better. See if you can find one that has a K rating, meaning it is +- 10%. The M rated ones are +-20%.
Posted on Aug 20, 2009
Clock is running fast
if digital not much can be done
go back to units setup
reset the clock
Jan 13, 2017 | Audio Players & Recorders
What is wrong with my pioneer pdpro6u media receiver?it shut off and wont power up,and there is a blinking blue light what does it mean?
  • there might be speaker wires touching somewhere
  • check all ventilation slats in Receiver make sure dust free
  • Check all connections maybe cable connections mixed up
  • Make sure power cord plugged in all of the way. Also make sure that the cord does not have exposed wires (this could cause a short
  • Make sure the wall outlet you are using is not overloaded (Too much power being used)
  • If this problem persists call customer service
This is the link to the manual
https://www.pioneerelectronics.com/pio/pe/images/portal/cit_11221/276752973PDP5060HDOperatingInstructions.pdf
Jan 08, 2017 | Pioneer Audio Players & Recorders
Pioneer media receiver pdpro6u shut off and won't turn on,now there is a blinking blue light
Check and replace the damaged component/s at its audio output stage circuit. An IC short or like that can cause this fault. If you wish to get some details; visit the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/ Search the site by type in the "brand name" of your device, in the "Search box at the top right of the Homepage" to get gathered related posts.
Pioneer audio video receiver VSX-D710S but there is sound to the speaker, but no audio coming from the player
Try to check the audio setting of the player. If you user using optical or coaxial then the audio out put format setting should be Raw other wise it should be PCM. You will see the setting if you go through the menu of the player
If you wish to get some details; visit the site linked here. Pull up older posts. http://electro-medical.blogspot.com/
Jan 07, 2017 | Pioneer Audio Players & Recorders
How do I open a UC-280 2.0CH USB Powered speaker system to reconnect the broken cable.
Once you open the speaker it will destroy the acoustic properties and make the speaker useless. The speakers are assembled with takp and glue and have to be pried apart.
Mar 14, 2015 | Audio Players & Recorders
My headphones connect with the adapter, the blue light is on on both but nothing comes from the ipod. I have performed the factory reset but it still doesn't work. The headphones had worked fine and then...
I have same issue....just took my transmitter apart - the wires connecting the male jack to the silicon board are frayed, disconnected.....you might check that...it's only 2 small screws holding the outercase together....be careful though
Jul 07, 2009 | Logitech Bluetooth Wireless Headphones
Sound problem with JBL Creature II
I had a problem with the speakers not working properly. The green lights lit, but the amount of sound coming from the speakers compared to that of the sub was much lower.
I decided to take it the speakers apart.
I found that the magnets on the speakers had moved forward slightly in the plastic cage they sat in. I pushed them back as far as they would go, and Hey Presto! working again!
I hope this helps someone!
Feb 23, 2007 | JBL CREATURE II Computer Speakers
269 people viewed this question
Top Pioneer Audio Players & Recorders Experts
 Grubhead
Grubhead
John
John
Dennis McCollum
Are you a Pioneer Audio Player and Recorder Expert? Answer questions, earn points and help others
