Question about Sirius Stiletto 2 Satellite Radio Receiver
I'm having the exact same problem with my Stiletto 2 freezing up after about 20 minutes to an hour of use (usually goes to dog logo when it tries to do a task like recording). I'll take the battery out and put it back in and sometimes it restarts and sometimes I get an error message. I connect to my PC, go through recovery and then the exact same thing happens. I'm confused on how this could be a fuse. Could it be a faulty hard drive? is there any way to do a real format/sector check, etc.? Has anyone brought their SL2 back from the dead or is my best bet complaining to Sirius and seeing what they'll do for me. I've gone through 3 S50s and now this!
    Scholar:
  • 149 Answers
Continuity check your fuses, they're tiny green SMD fuses located near your dock connector. However, it sounds more like a bad internal connection than a fuse. This was a problem that plagued ST1 sirius radios: solder on the chips' pins would crack, and when the unit heated or cooled it would no longer make a connection, thus requiring a reboot. Long story short, most of them can't be fixed without reworking the connections (and that's a lot of effort for something that will break again).
I'd advise you to send the unit back to sirius if you're still under warranty.
Posted on Dec 31, 2010
  • josh429 Jan 04, 2011
    Thanks Switch 998. I called Sirius and they said I was out of warranty. Customer care has no more Stilettos. One other sympton I was getting was a flickering of the screen (sort of a ghost image) and then a reset. If I were to sodder the connections, might this make it work again? I really have nothing to lose because the radio is basically not functional and they aren't going to swap it.
  • Chris M. Jan 04, 2011
    Well, if you have nothing to lose go ahead and do this:
    If you have a heat gun, set it to 1000 F; if you have a toaster oven set it to broil.
    Disassemble your radio, remove the PCB from the front cover and remove the LCD and buttons from the PCB. Be careful of the ribbon cables connecting them to the board, and place them back into the faceplate.
    Fip the PCB to the back side (where the EMI shield should be) pry the metal shield away from the metal frame and set it aside. Cover up any plastic parts on the radio, especially the flat cable clip connector.
    Place the board in your oven, or go over it with the heatgun for about a minute (you will see the solder turn shiny). Let it cool for 10 minutes. If you are using the oven, be careful to not overheat it. Any smoke produced is from flux, and it is normal.
Class action lawsuit every update they do this to about 100,000 s-50s in order for you to purchase new ones very very shady class action seems like the only recourse. I spent 5 hours and 4 diffrent calls with them not cool and when I asked for corporates number they told me I could not get it because nobody has it? What the hell is that way to take care of your legacy customers with lifetime activation.
Posted on Aug 22, 2011
2002 mercury grand marquis wont start when engine at normal temperature must wait 15-20 minutes
I have exactly the same problem started last winter, ran fine all summer then as soon as it got below freezing again if I start it and run for 15 20 minutes wont restart I have to let it sit for 20 minutes or so and then it will start again. no codes and just turns over without starting. cant be fuel pump like i said had this problem last winter then ran fine all spring summer and fall! Anybody got the answer for this one??
Mar 09, 2012 | 2002 Mercury Grand Marquis
I have installed amicro SD card in my Stiletto 2
I don't know about you but I had to plug and unplug my 4GB PNY card in 6 times before I could get past the white dog. Only supports up to 8GB per manual.
Dec 23, 2009 | Sirius Stiletto 2 Portable Satellite Radio...
Froze at the dog logo
exact same problem here. the fuse inside is blown, according to sirius tech support. I have a new one "on order" as a warranty replacement. They said it could take up to a month (in canada) i read many bad reviews about this unit... now I agree with them completely. 3 months of light home use before a fuse blows? Pathetic. A month wait for a new one? Unforgivable.
Jun 23, 2009 | Sirius Stiletto 2 Satellite Radio Receiver
I have stiletto 10 will not charge when plugged in
Did you try the back ,off radio slot too.Also check contacts andturn it off anlet it come on,let it charge with opening (dog and stars),Good Luck. union kk
Feb 21, 2009 | Sirius STILETTO 100 MP3 Player
Stiletto2 sometimes has static while playing mp3's from exp. card
I also own a Stiletto 2 and I have noticed this same problem, but only when playing MP3's in my car. What I have found is that if the volume on the Stilletto is too high it creates distortion. The solution is to turn down the volume on the actual Stilletto and just use the volume on the car stereo. Problem solved everytime.
Nov 21, 2008 | Sirius STILETTO 100 MP3 Player
I'm recieving a strong signal on my stiletto 2 but no sound on the radio. The MP3 player works with headphones and so does internet radio.
You need the firmware upgrade from the Sirius website:
Bug Fixes
· Reduced incidence of “acquiring signal” and “antenna not detected” messages
while the radio is installed in the Stiletto Vehicle dock (SLV2)
· Improved audio quality and distortion reduction
· Reduced incidence of long block recording and Radio Replay corruption
How to Get this Release
Updating over WiFi:
Subscribers may update Stiletto 2 over WiFi by following these steps:
1. Power cycle the Stiletto 2 by holding the power/lock switch down for 5 seconds
and releasing.
2. Turn on the Stiletto 2 and press the HOME button
3. Use the MEDIA DIAL to scroll to Internet Radio
4. Press the SELECT button to connect to Internet Radio
5. Tune to your favorite station and let it play for several hours.
6. Follow prompts on screen to complete the update, then power cycle your radio to
apply the updates.
7. Next go to HomeSettingsDeviceDevice info, if the baseband version is
already 00.14.94 you are done. If not, continue to the next step.
8. Reconnect to Internet Radio and listen for at least 15 minutes.
9. Disconnect, and tune to Satellite Radio. Updating Sirius will be displayed for
approximately 5 minutes.
10. Once the message clears, your update should be complete. Go to the Device
Info screen to verify the update has been successful.
Updating using My Sirius Studio™:
Customers without WiFi access may update using My Sirius Studio™ running on a PC
with an active internet connection:
1. Launch My Sirius Studio™ on your computer. Be sure you are running the latest
version of My Sirius Studio, currently version 1.5.1.
2. Power cycle the Stiletto 2 by holding the power/lock switch down for 5 seconds
and releasing.
3. Turn on the Stiletto 2 and connect it to your computer using the USB cable
supplied with your device
4. In My Sirius Studio, click on the gear icon next to the device or go to File
Device Settings Check for Software Update.
5. Follow the instructions that appear in My Sirius Studio™ to complete the update.
Please Note: During the update, your media library must be re-built. If you have a
large amount of content stored or a microSD™ card installed, the process can last
for as long as 10 minutes. During this time the message “updating media library” or
may be displayed.
6. After disconnecting from your PC it will be necessary to power cycle your Stiletto
and connect to Satellite Radio to refresh your channel list.
For additional questions regarding your Stiletto 2 or the SIRIUS service, please refer to
the product manuals. You can also reach the dedicated Stiletto Technical Support Team
at 1-800-869-5364 from 10 AM to 10 PM Eastern Time Monday through Saturday, or by
email at customercare@sirius-radio.com.
Jul 06, 2008 | Audio Players & Recorders
My stiletto records for about 18 minutes then stops
Daylight savings time change a few months ago messed up the timer recording schedule - you must now fix it. Daylight savings time changes will always mess up this recorder. You must reset your recording schedule.
For more info on fixing, go to:
http://shop.sirius.com/edealinv/servlet/ExecMacro?nurl=control/StoreItem.vm&ctl_nbr=2640&siId=1745656&catParentID=7874&scId=7874&oldParentID=&cid=SL100PK1
2 other remote possibilities:
If no signal is present at the time the recording is scheduled to start, the recording will be skipped.
Make sure you have followed all instructions on pp. 55-58
-Tha Mp3 Doctor
Jun 03, 2008 | Sirius STILETTO 100 MP3 Player
Stiletto only records for about 18 munutes
-Tha Mp3 Doctor
Sirus S50 stuck on dog logo, no other response to on button
I am most certain that you have to return the radio most likely you do have a faulty radio and you have only one or two choices here. Return or take it to a tech...I would use the warrenty and send it back...sounds very faulty...this is common with these radios.
Apr 27, 2008 | Sirius Satellite Radio S50-TK1 Satellite...
Sirius Stiletto 2 Satellite Radio Receiver Logo
964 people viewed this question
Top Sirius Audio Players & Recorders Experts
Steve
Oloyede Monsuru
Are you a Sirius Audio Player and Recorder Expert? Answer questions, earn points and help others
